win64 question
Etienne PERCHAT etienne.perchat at transvalor.com
Wed Mar 5 08:44:02 CST 2008
OK,
Thank you very much Satish for this very fast answer.
Best regards,
Etienne
-----Message d'origine-----
De : owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] De la part de Satish Balay
Envoyé : mercredi 5 mars 2008 15:33
À : petsc-users at mcs.anl.gov
Objet : Re: win64 question
Win32fe [& cygwintools] are used only as part of the build
enviornment.  So 32bit version of these tools don't prevent 64bit
builds.
Internally win32fe will invoke 'cl' with correct options. Here 'cl'
will run in 64 bit mode - thus producing the correct 64bit object
files.
Note: you might have to follow the instructions in the "Using Visual
Studio 2005" section of the installation insctuctions. Make sure when
you use the 'VisualStudio CMD' - its the 64bit compiler version [and
then use win32fe --nodetect' options.
Satish
On Wed, 5 Mar 2008, Etienne PERCHAT wrote:
> Hello,
> I would like to compile Petsc on x64 platforms under windows.
> I guess that win32fe might not be used but I didn't find something like
> win64fe.
> Does somebody have any tips?
> I have browsed the Installation informations as well as the mailing list
> archives without success (sorry to bother everybody if I missed
> something).
> Thanks in advance,
> Etienne Perchat
