Direct LU solver
Hong Zhang hzhang at mcs.anl.gov
Tue Mar 4 11:51:31 CST 2008
Amit,
I'll test it and let you know the result.
Hong
On Tue, 4 Mar 2008, Amit.Itagi at seagate.com wrote:
> Here is an example. I am creating the matrices, the vectors and the solver.
> I can do an LU solve on two processes just fine. However, when I destroy
> the entities and repeat the process (without any change), I get a crash.
> #include <iostream>
> #include <complex>
> #include <stdlib.h>
> #include "petsc.h"
> #include "petscmat.h"
> #include "petscvec.h"
> #include "petscksp.h"
> using namespace std;
> int main( int argc, char *argv[] ) {
>  int rank, size;
>  Mat A;
>  PetscErrorCode ierr;
>  PetscInt loc;
>  PetscScalar val;
>  Vec x, y;
>  KSP solver;
>  PC prec;
>  MPI_Comm comm;
>  // Number of non-zeros in each row
>  ierr=PetscInitialize(&argc,&argv,PETSC_NULL,PETSC_NULL); CHKERRQ(ierr);
>  // Initialization (including MPI)
>  comm=PETSC_COMM_WORLD;
>  ierr=MPI_Comm_size(PETSC_COMM_WORLD,&size); CHKERRQ(ierr);
>  ierr=MPI_Comm_rank(PETSC_COMM_WORLD,&rank); CHKERRQ(ierr);
>  //================== LU : First Time =============================
>  // Assemble matrix A
>  PetscInt d_nnz=1, o_nnz=1;
>  ierr=MatCreate(comm,&A); CHKERRQ(ierr);
>  ierr=MatSetSizes(A,1,1,2,2); CHKERRQ(ierr);
>  ierr=MatMPIAIJSetPreallocation(A,0,&d_nnz,0,&o_nnz); CHKERRQ(ierr);
>  ierr=MatSetType(A,MATSUPERLU_DIST); CHKERRQ(ierr);
>  ierr=MatSetFromOptions(A); CHKERRQ(ierr);
>  if(rank==0) {
>    val=complex<double>(1.0,0.0);
>    ierr=MatSetValue(A,0,0,val,ADD_VALUES);CHKERRQ(ierr);
>    val=complex<double>(0.0,1.0);
>    ierr=MatSetValue(A,0,1,val,ADD_VALUES);CHKERRQ(ierr);
>  else {
>    val=complex<double>(1.0,1.0);
>    ierr=MatSetValue(A,1,1,val,ADD_VALUES);CHKERRQ(ierr);
>    ierr=MatSetValue(A,1,0,val,ADD_VALUES);CHKERRQ(ierr);
>  ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>  ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>  cout << "============  Mat A  ==================" << endl;
>  ierr=MatView(A,PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
>  cout << "======================================" << endl;
>  // Direct LU solver
>  ierr=KSPCreate(comm,&solver); CHKERRQ(ierr);
>  ierr=KSPSetOperators(solver,A,A,SAME_PRECONDITIONER); CHKERRQ(ierr);
>  ierr=KSPSetType(solver,KSPPREONLY); CHKERRQ(ierr);
>  ierr=KSPGetPC(solver,&prec); CHKERRQ(ierr);
>  ierr=PCSetType(prec,PCLU); CHKERRQ(ierr);
>  ierr=PCFactorSetShiftNonzero(prec,PETSC_DECIDE);
>  ierr=KSPSetFromOptions(solver); CHKERRQ(ierr);
>  //============  Vector assembly ========================
>  if(rank==0) {
>    ierr=VecCreateMPI(PETSC_COMM_WORLD,1,2,&x); CHKERRQ(ierr);
>    loc=0;
>    ierr=VecSetValues(x,1,&loc,&val,ADD_VALUES);CHKERRQ(ierr);
>  else {
>    val=complex<double>(-1.0,0.0);
>    loc=1;
>  ierr=VecAssemblyBegin(x); CHKERRQ(ierr);
>  ierr=VecAssemblyEnd(x); CHKERRQ(ierr);
>  cout << "============== Vec x ==================" << endl;
>  ierr=VecView(x,PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
>  VecDuplicate(x,&y);  // Duplicate the matrix storage
>  // Solve the matrix equation
>  ierr=KSPSolve(solver,x,y); CHKERRQ(ierr);
>  cout << "============== Vec y =================" << endl;
>  ierr=VecView(y,PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
>  // Destructors
>  ierr=KSPDestroy(solver); CHKERRQ(ierr);
>  ierr=VecDestroy(x); CHKERRQ(ierr);
>  ierr=VecDestroy(y); CHKERRQ(ierr);
>  ierr=MatDestroy(A); CHKERRQ(ierr);
>  //============== LU Second time ==============================
>  //======= Everything is exactly the same =====================
>  if(rank==0) {
>  else {
>  // Direct LU solver
>  if(rank==0) {
>    loc=0;
>  else {
>    loc=1;
>  // Destructors
> // Finalize
>  ierr=PetscFinalize(); CHKERRQ(ierr);
>  return 0;
> Thanks
> Rgds,
> Amit
> Hong Zhang <hzhang at mcs.anl.gov> wrote on 03/03/2008 09:55:43 PM:
>> Are you using petsc-dev or a released version?
>> If petsc-dev with the newly released superlu_dist_2.2,
>> there is a bug in reusing parallel LU symbolic factorization
>> which I've reported to the developer of superlu_dist_2.2.
>>> Your comments were helpful. Now I can do the LU solves multiple times.
>>> However within the program, if I destroy the matrix and the KSP and
> create
>>> them again (for a different matrix), I get an error in superlu.
>> Otherwise,
>> can you send me a simplified code that display the crash?
>> Then I may run it and see if petsc superlu_dist interface has bug.
>> You may also test other parallel direct LU solvers, e.g.,
>> mumps or spooles.
>> Hong
>>> Here is the log from a successful run.
>>>        [1] 0.249931 Event begin: KSPSetup
>>>      [1] 0.24994 Event end: KSPSetup
>>>        [1] 0.249948 Event begin: PCSetUp
>>>          [1] 0.249963 Event begin: MatGetOrdering
>>>        [0] 0.151691 Event begin: KSPSetup
>>>      [0] 0.151699 Event end: KSPSetup
>>> [0] PCSetUp(): Setting up new PC
>>>        [0] 0.151713 Event begin: PCSetUp
>>>          [0] 0.151722 Event begin: MatGetOrdering
>>> [1] PetscCommDuplicate():   returning tag 2147483493
>>> [0] PetscCommDuplicate():   returning tag 2147483493
>>> [1] PetscCommDuplicate():   returning tag 2147483492
>>> [0] PetscCommDuplicate():   returning tag 2147483492
>>>        [1] 0.250169 Event end: MatGetOrdering
>>>          [1] 0.250182 Event begin: MatLUFactorSym
>>>        [0] 0.151885 Event end: MatGetOrdering
>>>          [0] 0.151896 Event begin: MatLUFactorSym
>>> [1] PetscCommDuplicate():   returning tag 2147483491
>>> [0] PetscCommDuplicate():   returning tag 2147483491
>>> [1] MatConvert_AIJ_SuperLU_DIST(): Using SuperLU_DIST for SeqAIJ
>> LU factorization and solves.
>>> [0] MatConvert_AIJ_SuperLU_DIST(): Using SuperLU_DIST for SeqAIJ
>>> [1] PetscCommDuplicate(): Using internal PETSc communicator
>> 1083412768 143685848
>>> [1] PetscCommDuplicate():   returning tag 2147483627
>>> [1] PetscCommDuplicate():   returning tag 2147483626
>>> [0] PetscCommDuplicate(): Using internal PETSc communicator
>> 1083412768 144562608
>>> [0] PetscCommDuplicate():   returning tag 2147483627
>>> [0] PetscCommDuplicate():   returning tag 2147483626
>>>        [1] 0.252072 Event end: MatLUFactorSym
>>>          [1] 0.252098 Event begin: MatLUFactorNum
>>>        [0] 0.153821 Event end: MatLUFactorSym
>>>          [0] 0.153835 Event begin: MatLUFactorNum
>>>      Nonzeros in L       171877
>>>      Nonzeros in U       171877
>>>      nonzeros in L+U-I   342195
>>>      nonzeros in LSUB    52137
>>>        Mat conversion(PETSc->SuperLU_DIST) time (max/min/avg):
>>>                               0.000296116 / 0.00028491 / 0.000290513
>>>        [1] 0.623389 Event end: MatLUFactorNum
>>>      [1] 0.623425 Event end: PCSetUp
>>>      EQUIL time             0.00
>>>      ROWPERM time           0.01
>>>      COLPERM time           0.01
>>>      SYMBFACT time          0.01
>>>      DISTRIBUTE time        0.02
>>>      FACTOR time            0.29
>>>      Factor flops      2.652935e+08      Mflops        924.82
>>>      SOLVE time             0.00
>>>        [0] 0.525149 Event end: MatLUFactorNum
>>>      [0] 0.525167 Event end: PCSetUp
>>> Here is the log from a crash.
>>>        [0] 1.41665 Event begin: KSPSetup
>>>      [0] 1.41666 Event end: KSPSetup
>>>        [0] 1.41668 Event begin: PCSetUp
>>>          [0] 1.41669 Event begin: MatGetOrdering
>>>        [1] 1.51505 Event begin: KSPSetup
>>>      [1] 1.51506 Event end: KSPSetup
>>>        [1] 1.51507 Event begin: PCSetUp
>>>          [1] 1.51507 Event begin: MatGetOrdering
>>> [0] PetscCommDuplicate():   returning tag 2147483226
>>> [1] PetscCommDuplicate():   returning tag 2147483226
>>> [0] PetscCommDuplicate():   returning tag 2147483225
>>> [1] PetscCommDuplicate():   returning tag 2147483225
>>>        [0] 1.4169 Event end: MatGetOrdering
>>>          [0] 1.41692 Event begin: MatLUFactorSym
>>>        [1] 1.51526 Event end: MatGetOrdering
>>>          [1] 1.51526 Event begin: MatLUFactorSym
>>> [0] PetscCommDuplicate():   returning tag 2147483224
>>> [1] PetscCommDuplicate():   returning tag 2147483224
>>>        [0] 1.4187 Event end: MatLUFactorSym
>>>          [0] 1.41872 Event begin: MatLUFactorNum
>>>        [1] 1.51706 Event end: MatLUFactorSym
>>>          [1] 1.51707 Event begin: MatLUFactorNum
>>> MPI_Alltoallv: invalid datatype argument: Invalid argument (rank 0,
> comm 5)
>>> Rank (0, MPI_COMM_WORLD): Call stack within LAM:
>>> Rank (0, MPI_COMM_WORLD):  - MPI_Alltoallv()
>>> Rank (0, MPI_COMM_WORLD):  - main()
>>> If I trace the place of the error in the debugger, the trace gives
>>> KSPSolve() -> KSPSetUp() -> PCSetUp() -> PCSetUp_LU() ->
>> MatLuFactorNumeric() -> MatLuFactorNumeric_SuperLU_Dist()
>>> -> pzgssvx() -> pzCompRow_loc_to_CompCol_global() -> MPI_Alltoallv
>>> I could not make much head-way by looking at the errors. Could you
>> give me some tips on what might be causing this error, and what to look
> for  ?
>>> Thanks
>>> Rgds,
>>> Amit
>>> owner-petsc-users at mcs.anl.gov wrote on 03/03/2008 10:55:21 AM:
>>>> Amit,
>>>>> Thanks for your response. A couple of follow-up questions -
>>>>> I go over the steps
>>>>> MatCreate()
>>>>> MatSetType(MPIAIJ)
>>>>> MatMPIAIJSetPreallocation()
>>>>> MatSetType(MATSUPERLU_DIST).
>>>>> Even though I want to do the direct LU solves repeatedly (with the
> same
>>>>> matrix), I don't want the program to do LU factorization repeatedly.
> I
>>> hope
>>>>> I can get that functionality by using the "SAME_PRECONDITIONER"
> option
>>>>> (along with -ksppreonly), while defining the KSP. When the program
> does
>>> the
>>>>> factorization, does it do it in-place or does it allocate new storage
>>>> allocate new storage unless you call
>>>> MatLUFactor() explicitly.
>>>> It is done by
>>>>   KSPSetUp()
>>>>     which calls PCSetUp() -> PCSetUp_LU()
>>>>       -> MatLUFactorSymbolic() & MatLUFactorNumeric(
>>>> You can do following for reusing factored L and U:
>>>>    KSPCreate()
>>>>    KSPSetOperators()
>>>>    KSPSetFromOptions()
>>>>    KSPSetUp()
>>>>    while ( num_rhs-- ) {
>>>>      KSPSolve(ksp,b,x);
>>>> See src/ksp/ksp/examples/tutorials/ex10.c
>>>>> After doing the LU factorization, are the other operations such as
>>>>> MatMult() preserved ?
>>>> Yes.
>>>> Hong
>>>>> Thanks
>>>>> Rgds,
>>>>> Amit
