x11 on os x 10.5.x
Gideon Simpson grs2103 at columbia.edu
Sun Jun 22 00:17:55 CDT 2008
Does anyone know what flags to feed petsc 2.3.3 to get x11
functionality working with OS X 10.5.x?  The following error shows up
in my configure log:
TEST configureLibrary from PETSc.packages.X11(/opt/petsc-2.3.3-p13/
python/PETSc/packages/X11.py:93)
TESTING: configureLibrary from PETSc.packages.X11(python/PETSc/
packages/X11.py:93)
   Checks for X windows, sets PETSC_HAVE_X11 if found, and defines
X_CFLAGS, X_PRE_LIBS, X_LIBS, and X_EXTRA_LIBS
sh: xmkmf
Executing: xmkmf
sh: imake -DUseInstalled -I/usr/X11/lib/X11/config
sh: /usr/bin/make acfindx
Executing: /usr/bin/make acfindx
sh: X_INCLUDE_ROOT = /usr/X11/include
X_USR_LIB_DIR = /usr/X11/lib
X_LIB_DIR = /usr/X11/lib/X11
         Pushing language C
sh: /opt/bin/mpicc -c -o conftest.o  -fPIC -Wall -Wwrite-strings -Wno-
strict-aliasing -g3  conftest.c
Executing: /opt/bin/mpicc -c -o conftest.o  -fPIC -Wall -Wwrite-
strings -Wno-strict-aliasing -g3  conftest.c
sh:
Possible ERROR while running compiler: error message = {conftest.c: In
function ‘main’:
conftest.c:5: warning: implicit declaration of function ‘XSetWMName’
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
XSetWMName();
   return 0;
                 Pushing language C
                 Popping language C
sh: /opt/bin/mpicc  -o conftest  -Wl,-multiply_defined,suppress -Wl,-
multiply_defined -Wl,suppress -Wl,-multiply_defined,suppress -Wl,-
multiply_defined -Wl,suppress  -fPIC -Wall -Wwrite-strings -Wno-strict-
aliasing -g3  conftest.o -Wl,-rpath,/usr/lib/i686-apple-darwin9/4.2.1 -
Wl,-rpath,/Library/Frameworks/Intel_MKL.framework/Versions/10.0.2.018/
lib/32 -Wl,-rpath,. -Wl,-rpath,/usr/lib/gcc/i686-apple-darwin9/4.2.1 -
Wl,-rpath,/usr/lib/gcc/i686-apple-darwin9/4.2.1/../../../i686-apple-
darwin9/4.2.1 -Wl,-rpath,/usr/lib/gcc/i686-apple-
darwin9/4.2.1/../../.. -lstdc++ -lcrt1.10.5.o -Wl,-rpath,/usr/lib/i686-
apple-darwin9/4.2.1 -L/usr/lib/i686-apple-darwin9/4.2.1 -Wl,-rpath,/
Library/Frameworks/Intel_MKL.framework/Versions/10.0.2.018/lib/32 -L/
Library/Frameworks/Intel_MKL.framework/Versions/10.0.2.018/lib/32 -Wl,-
rpath,. -L. -Wl,-rpath,/usr/lib/gcc/i686-apple-darwin9/4.2.1 -L/usr/
lib/gcc/i686-apple-darwin9/4.2.1 -Wl,-rpath,/usr/lib/gcc/i686-apple-
darwin9/4.2.1/../../../i686-apple-darwin9/4.2.1 -L/usr/lib/gcc/i686-
apple-darwin9/4.2.1/../../../i686-apple-darwin9/4.2.1 -Wl,-rpath,/usr/
lib/gcc/i686-apple-darwin9/4.2.1/../../.. -L/usr/lib/gcc/i686-apple-
darwin9/4.2.1/../../.. -ldl -lgcc_s.10.5 -lSystem -ldl  -lX11
Executing: /opt/bin/mpicc  -o conftest  -Wl,-multiply_defined,suppress
-Wl,-multiply_defined -Wl,suppress -Wl,-multiply_defined,suppress -Wl,-
sh:
Possible ERROR while running linker: ld: library not found for -lX11
collect2: ld returned 1 exit status
  output: ret = 256
error message = {ld: library not found for -lX11
                     Pushing language C
                     Popping language C
  in /opt/bin/mpicc  -o conftest  -Wl,-multiply_defined,suppress -Wl,-
Source:
int main() {
XSetWMName();
   return 0;
         Popping language C
       Could not find X11 libraries
