MatAssemblyBegin/End
Andrew Colombi acolombi at gmail.com
Thu Jun 19 11:12:31 CDT 2008
I'm trying to overlap as much as possible MatAssembly with other
computations, and I'm finding a confusing result.  If I follow my
AssemblyBegin with an immediate AssemblyEnd it takes 31 seconds to
assemble the matrix.  If I interleave a 10 minute computation between
AssemblyBegin and AssemblyEnd I find that executing only AssemblyEnd
still takes 27 seconds.  So it takes 31 seconds to complete the entire
transaction, or after 10 minutes of compute I still find myself stuck
with 27 seconds of wait time.
Now clearly, from the standpoint of optimization, 27 seconds in the
presence of 10 minute computations is not something to waste brain
cycles on. Nevertheless, I'm always curious about discrepancies
between the world in my head and the actual world ;-) Here are some
points that may be of interest:
* I'm using a debug compile of PETSc.  I wouldn't guess this makes
much difference as long as BLAS and LAPACK are optimized.
* One node does not participate in the computation, instead it acts as
a work queue; doling out work whenever a "worker" processor becomes
available.  As such the "server" node makes a lot of calls to
MPI_Iprobe.  Could this be interfering with PETSc's background use of
MPI?
-Andrew
