Question on petsc-2.3.3-p13
Thu Jun 12 08:52:31 CDT 2008
Do you gOn Thu, 12 Jun 2008, Tobias Neckel wrote:
> Hi Matthew,
> > I have not seen this problem before. I looked through the code. My only
> > guess
> > is that the compiler is complaining about one of the __*__ variables in the
> > CHKERRQ() definition. I have not seen this before (they have always
> > been defined).
> > What compilers are you using?
> Currently, we are using g++ (GCC) 4.1.1 (Gentoo 4.1.1-r3) with the usual debug
> flags (-g3 -O0) and some warnings (-Wall -Werror -pedantic -pedantic-errors).
Do you get these errors with PETSc example codes aswell - or just your
application code?
Satish
