Direct LU solver
Thu Feb 28 16:58:16 CST 2008
On Thu, 28 Feb 2008, Amit.Itagi at seagate.com wrote:
> Matt and Hong,
> I will try to customize the example. However, since my application involves
> multiple ksp solvers (using different algorithms), I would really like to
> set the options with in the code, instead of on the command line. Is there
> a way of doing this ?
-ksp_type preonly -pc_type lu -mat_type superlu_dist
There are 2 ways of doing this.
One is within the code:
    MatCreate(&mat);
    MatSetType(mat,MATSUPERLU_DIST);
    MatSetFromOptions(mat);
    KSPSetType(ksp,KSPPREONLY);
    KSPGetPC(ksp,&pc);
    PCSetType(pc,PCLU);
    KSPSetFromOptions(ksp);
etc..
Another way is to give each object a prefix [if you have multiple
objects of the same type. You can use this prefix with the command
line options.
For eg:
    KSPCreate(&ksp1)
    KSPCreate(&ksp2)
    KSPSetOptionsPrefix(ksp1,"a_")
    KSPSetOptionsPrefix(ksp2,"b_")
Now you can use -a_ksp_type gmres -b_ksp_type cg
etc..
Satish
