Direct LU solver
Hong Zhang hzhang at mcs.anl.gov
Thu Feb 28 14:57:24 CST 2008
or ~petsc/src/ksp/ksp/examples/tutorials/ex5.c to avoid using
matrix data file, e.g.
mpiexec -np 2 ./ex5 -ksp_type preonly -pc_type lu -mat_type superlu_dist
Hong
On Thu, 28 Feb 2008, Matthew Knepley wrote:
> I would recommend using KSP ex10 and then customizing with options.
> That way we know it should work. For SuperLU_dist,
>   Matt
> On Thu, Feb 28, 2008 at 1:07 PM,  <Amit.Itagi at seagate.com> wrote:
>> Hi,
>>  I need to do direct LU solves (repeatedly, with the same matrix) in one of
>>  my MPI applications. I am having trouble implementing the solver. To
>>  identify the problem, I wrote a short toy  code to run with 2 processes. I
>>  can run it with either the spooles parallel matrix or the superlu_dist
>>  matrix. I am using C++ and complex matrices.
>>  Here is the code listing:
>>  #include <iostream>
>>  #include <complex>
>>  #include <stdlib.h>
>>  #include "petsc.h"
>>  #include "petscmat.h"
>>  #include "petscvec.h"
>>  #include "petscksp.h"
>>  using namespace std;
>>  int main( int argc, char *argv[] ) {
>>   int rank, size;
>>   Mat A;
>>   PetscErrorCode ierr;
>>   PetscInt loc;
>>   PetscScalar val;
>>   Vec x, y;
>>   KSP solver;
>>   PC prec;
>>   MPI_Comm comm;
>>   // Number of non-zeros in each row
>>   int d_nnz=1, o_nnz=1;
>>   ierr=PetscInitialize(&argc,&argv,PETSC_NULL,PETSC_NULL); CHKERRQ(ierr);
>>   // Initialization (including MPI)
>>   comm=PETSC_COMM_WORLD;
>>   ierr=MPI_Comm_size(PETSC_COMM_WORLD,&size); CHKERRQ(ierr);
>>   ierr=MPI_Comm_rank(PETSC_COMM_WORLD,&rank); CHKERRQ(ierr);
>>   // Assemble matrix A
>>   if(rank==0) {
>>     ierr=MatCreateMPIAIJ(comm,1,1,2,2,0,&d_nnz,0,&o_nnz,&A); CHKERRQ(ierr);
>>     val=complex<double>(1.0,0.0);
>>     ierr=MatSetValue(A,0,0,val,INSERT_VALUES);CHKERRQ(ierr);
>>     val=complex<double>(0.0,1.0);
>>     ierr=MatSetValue(A,0,1,val,INSERT_VALUES);CHKERRQ(ierr);
>>   else {
>>     ierr=MatCreateMPIAIJ(PETSC_COMM_WORLD,1,1,2,2,0,&d_nnz,0,&o_nnz,&A);
>>  CHKERRQ(ierr);
>>     val=complex<double>(1.0,1.0);
>>     ierr=MatSetValue(A,1,1,val,INSERT_VALUES);CHKERRQ(ierr);
>>     val=complex<double>(0.0,-1.0);
>>     ierr=MatSetValue(A,1,0,val,INSERT_VALUES);CHKERRQ(ierr);
>>   ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>>   ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>>   cout << "============  Mat A  ==================" << endl;
>>   ierr=MatView(A,PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
>>   cout << "======================================" << endl;
>>   // For spooles
>>   //ierr=MatConvert(A,MATMPIAIJSPOOLES,MAT_REUSE_MATRIX,&A); CHKERRQ(ierr);
>>   // For superlu_dist
>>   ierr=MatConvert(A,MATSUPERLU_DIST,MAT_REUSE_MATRIX,&A); CHKERRQ(ierr);
>>   // Direct LU solver
>>   ierr=KSPCreate(comm,&solver); CHKERRQ(ierr);
>>   ierr=KSPSetType(solver,KSPPREONLY); CHKERRQ(ierr);
>>   ierr=KSPSetOperators(solver,A,A,SAME_NONZERO_PATTERN); CHKERRQ(ierr);
>>   ierr=KSPGetPC(solver,&prec); CHKERRQ(ierr);
>>   ierr=PCSetType(prec,PCLU); CHKERRQ(ierr);
>>   ierr=KSPSetFromOptions(solver); CHKERRQ(ierr);
>>   //============  Vector assembly ========================
>>   if(rank==0) {
>>     ierr=VecCreateMPI(PETSC_COMM_WORLD,1,2,&x); CHKERRQ(ierr);
>>     loc=0;
>>     ierr=VecSetValues(x,1,&loc,&val,ADD_VALUES);CHKERRQ(ierr);
>>   else {
>>     val=complex<double>(-1.0,0.0);
>>     loc=1;
>>   ierr=VecAssemblyBegin(x); CHKERRQ(ierr);
>>   ierr=VecAssemblyEnd(x); CHKERRQ(ierr);
>>   cout << "============== Vec x ==================" << endl;
>>   ierr=VecView(x,PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
>>   VecDuplicate(x,&y);  // Duplicate the matrix storage
>>   // Solve the matrix equation
>>   ierr=KSPSolve(solver,x,y); CHKERRQ(ierr);
>>   cout << "============== Vec y =================" << endl;
>>   ierr=VecView(y,PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
>>   // Destructors
>>   ierr=KSPDestroy(solver); CHKERRQ(ierr);
>>   ierr=VecDestroy(x); CHKERRQ(ierr);
>>   ierr=VecDestroy(y); CHKERRQ(ierr);
>>   ierr=MatDestroy(A); CHKERRQ(ierr);
>>   // Finalize
>>   ierr=PetscFinalize(); CHKERRQ(ierr);
>>   return 0;
>>  When I run the program with spooles, I get the following output.
>>  row 0: (0, 1)  (1, 0 + 1 i)
>>  row 1: (0, 0 - 1 i) (1, 1 + 1 i)
>>  Process [0]
>>  1
>>  Process [1]
>>  -1
>>   fatal error in InpMtx_MPI_split()
>>   firsttag = 0, tagbound = -1
>>  One of the processes started by mpirun has exited with a nonzero exit
>>  code.  This typically indicates that the process finished in error.
>>  If your process did not finish in error, be sure to include a "return
>>  0" or "exit(0)" in your C code before exiting the application.
>>  PID 22881 failed on node n0 (127.0.0.1) with exit status 255.
>>  mpirun failed with exit status 255
>>  When run in the debugger, there is no stack trace. The error is
>>  Program exited with code 0377
>>  With superlu_dist, the output is
>>  Process [0]
>>  1
>>  Process [1]
>>  -1
>>  [0]PETSC ERROR:
>>  [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>  probably memory access out of range
>>  [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>  [0]PETSC ERROR: or see
>>  http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC
>>   ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to
>>  find memory corruption errors
>>  [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
>>  run
>>  [0]PETSC ERROR: to get more information on the crash.
>>  [0]PETSC ERROR: --------------------- Error Message
>>  [0]PETSC ERROR: Signal received!
>>  [0]PETSC ERROR:
>>  [0]PETSC ERROR: Petsc Release Version 2.3.3, Patch 8, Fri Nov 16 17:03:40
>>  CST 2007 HG revision: 414581156e67e55c761739b0deb119f7590d0f4b
>>  [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>  [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>  [0]PETSC ERROR: See docs/index.html for manual pages.
>>  [0]PETSC ERROR:
>>  [0]PETSC ERROR: lu on a linux-gnu named tabla by amit Thu Feb 28 13:48:54
>>  2008
>>  [0]PETSC ERROR: Libraries linked from
>>  /home/amit/programs/ParEM/petsc-2.3.3-p8/lib/linux-gnu-c-debug
>>  [0]PETSC ERROR: Configure run at Thu Feb 28 12:19:39 2008
>>  [0]PETSC ERROR: Configure options --with-scalar-type=complex
>>  --with-debugging=no --with-fortran-kernels=generic --with-clanguage=cxx
>>  --with-metis=1 --download-metis=1 --with-parmetis=1 --download-parmetis=1
>>  --with-superlu_dist=1 --download-superlu_dist=1 --with-spooles=1
>>  --with-spooles-dir=/home/amit/programs/ParEM/spooles-2.2 COPTFLAGS="-O3
>>  -march=p4 -mtune=p4 -ffast-math -malign-double -funroll-loops -pipe
>>  -fomit-frame-pointer -finline-functions -msse2" CXXOPTFLAGS="-O3 -march=p4
>>  -fomit-frame-pointer -finline-functions -msse2" FOPTS="-O3 -qarch=p4
>>  -qtune=p4" --with-shared=0
>>  [0]PETSC ERROR:
>>  [0]PETSC ERROR: User provided function() line 0 in unknown directory
>>  unknown file
>>  PID 22998 failed on node n0 (127.0.0.1) with exit status 1.
>>  mpirun failed with exit status 1
>>  The debugger tracks the segmentation violation to
>>  main -> KSPSolve -> KSPSetUp -> PCSetUp -> PCSetUp_LU -> MatLUFactorNumeric
>>  -> MatLUFactorNumeric_SUperLU_DIST -> pzgssvx
>>  Could  someone kindly point out what I am missing ?
>>  Thanks
>>  Rgds,
>>  Amit
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
