Direct LU solver
Amit.Itagi at seagate.com Amit.Itagi at seagate.com
Thu Feb 28 13:07:36 CST 2008
I need to do direct LU solves (repeatedly, with the same matrix) in one of
my MPI applications. I am having trouble implementing the solver. To
identify the problem, I wrote a short toy  code to run with 2 processes. I
can run it with either the spooles parallel matrix or the superlu_dist
matrix. I am using C++ and complex matrices.
Here is the code listing:
#include <iostream>
#include <complex>
#include <stdlib.h>
#include "petsc.h"
#include "petscmat.h"
#include "petscvec.h"
#include "petscksp.h"
using namespace std;
int main( int argc, char *argv[] ) {
  int rank, size;
  Mat A;
  PetscErrorCode ierr;
  PetscInt loc;
  PetscScalar val;
  Vec x, y;
  KSP solver;
  PC prec;
  MPI_Comm comm;
  // Number of non-zeros in each row
  int d_nnz=1, o_nnz=1;
  ierr=PetscInitialize(&argc,&argv,PETSC_NULL,PETSC_NULL); CHKERRQ(ierr);
  // Initialization (including MPI)
  comm=PETSC_COMM_WORLD;
  ierr=MPI_Comm_size(PETSC_COMM_WORLD,&size); CHKERRQ(ierr);
  ierr=MPI_Comm_rank(PETSC_COMM_WORLD,&rank); CHKERRQ(ierr);
  // Assemble matrix A
  if(rank==0) {
    ierr=MatCreateMPIAIJ(comm,1,1,2,2,0,&d_nnz,0,&o_nnz,&A); CHKERRQ(ierr);
    val=complex<double>(1.0,0.0);
    ierr=MatSetValue(A,0,0,val,INSERT_VALUES);CHKERRQ(ierr);
    val=complex<double>(0.0,1.0);
    ierr=MatSetValue(A,0,1,val,INSERT_VALUES);CHKERRQ(ierr);
  else {
    ierr=MatCreateMPIAIJ(PETSC_COMM_WORLD,1,1,2,2,0,&d_nnz,0,&o_nnz,&A);
CHKERRQ(ierr);
    val=complex<double>(1.0,1.0);
    ierr=MatSetValue(A,1,1,val,INSERT_VALUES);CHKERRQ(ierr);
    val=complex<double>(0.0,-1.0);
    ierr=MatSetValue(A,1,0,val,INSERT_VALUES);CHKERRQ(ierr);
  ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
  ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
  cout << "============  Mat A  ==================" << endl;
  ierr=MatView(A,PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
  cout << "======================================" << endl;
  // For spooles
  //ierr=MatConvert(A,MATMPIAIJSPOOLES,MAT_REUSE_MATRIX,&A); CHKERRQ(ierr);
  // For superlu_dist
  ierr=MatConvert(A,MATSUPERLU_DIST,MAT_REUSE_MATRIX,&A); CHKERRQ(ierr);
  // Direct LU solver
  ierr=KSPCreate(comm,&solver); CHKERRQ(ierr);
  ierr=KSPSetType(solver,KSPPREONLY); CHKERRQ(ierr);
  ierr=KSPSetOperators(solver,A,A,SAME_NONZERO_PATTERN); CHKERRQ(ierr);
  ierr=KSPGetPC(solver,&prec); CHKERRQ(ierr);
  ierr=PCSetType(prec,PCLU); CHKERRQ(ierr);
  ierr=KSPSetFromOptions(solver); CHKERRQ(ierr);
  //============  Vector assembly ========================
  if(rank==0) {
    ierr=VecCreateMPI(PETSC_COMM_WORLD,1,2,&x); CHKERRQ(ierr);
    loc=0;
    ierr=VecSetValues(x,1,&loc,&val,ADD_VALUES);CHKERRQ(ierr);
  else {
    val=complex<double>(-1.0,0.0);
    loc=1;
  ierr=VecAssemblyBegin(x); CHKERRQ(ierr);
  ierr=VecAssemblyEnd(x); CHKERRQ(ierr);
  cout << "============== Vec x ==================" << endl;
  ierr=VecView(x,PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
  VecDuplicate(x,&y);  // Duplicate the matrix storage
  // Solve the matrix equation
  ierr=KSPSolve(solver,x,y); CHKERRQ(ierr);
  cout << "============== Vec y =================" << endl;
  ierr=VecView(y,PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
  // Destructors
  ierr=KSPDestroy(solver); CHKERRQ(ierr);
  ierr=VecDestroy(x); CHKERRQ(ierr);
  ierr=VecDestroy(y); CHKERRQ(ierr);
  ierr=MatDestroy(A); CHKERRQ(ierr);
 // Finalize
  ierr=PetscFinalize(); CHKERRQ(ierr);
  return 0;
When I run the program with spooles, I get the following output.
row 0: (0, 1)  (1, 0 + 1 i)
row 1: (0, 0 - 1 i) (1, 1 + 1 i)
Process [0]
1
Process [1]
-1
 fatal error in InpMtx_MPI_split()
 firsttag = 0, tagbound = -1
One of the processes started by mpirun has exited with a nonzero exit
code.  This typically indicates that the process finished in error.
If your process did not finish in error, be sure to include a "return
0" or "exit(0)" in your C code before exiting the application.
PID 22881 failed on node n0 (127.0.0.1) with exit status 255.
mpirun failed with exit status 255
When run in the debugger, there is no stack trace. The error is
Program exited with code 0377
With superlu_dist, the output is
Process [0]
1
Process [1]
-1
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC
 ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to
find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 2.3.3, Patch 8, Fri Nov 16 17:03:40
CST 2007 HG revision: 414581156e67e55c761739b0deb119f7590d0f4b
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: lu on a linux-gnu named tabla by amit Thu Feb 28 13:48:54
[0]PETSC ERROR: Libraries linked from
/home/amit/programs/ParEM/petsc-2.3.3-p8/lib/linux-gnu-c-debug
[0]PETSC ERROR: Configure run at Thu Feb 28 12:19:39 2008
[0]PETSC ERROR: Configure options --with-scalar-type=complex
--with-debugging=no --with-fortran-kernels=generic --with-clanguage=cxx
--with-metis=1 --download-metis=1 --with-parmetis=1 --download-parmetis=1
--with-superlu_dist=1 --download-superlu_dist=1 --with-spooles=1
--with-spooles-dir=/home/amit/programs/ParEM/spooles-2.2 COPTFLAGS="-O3
-march=p4 -mtune=p4 -ffast-math -malign-double -funroll-loops -pipe
-fomit-frame-pointer -finline-functions -msse2" CXXOPTFLAGS="-O3 -march=p4
-fomit-frame-pointer -finline-functions -msse2" FOPTS="-O3 -qarch=p4
-qtune=p4" --with-shared=0
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
PID 22998 failed on node n0 (127.0.0.1) with exit status 1.
mpirun failed with exit status 1
The debugger tracks the segmentation violation to
main -> KSPSolve -> KSPSetUp -> PCSetUp -> PCSetUp_LU -> MatLUFactorNumeric
-> MatLUFactorNumeric_SUperLU_DIST -> pzgssvx
Could  someone kindly point out what I am missing ?
Thanks
Rgds,
Amit
