any examples to demonstrate how to Spooles package?
Yujie recrusader at gmail.com
Wed Feb 27 11:05:47 CST 2008
Dear Sanjay:
Thank you for your reply. I don't understand what you said. Now, I want to
use spooles package to inverse a sparse SPD matrix. I have further checked
the inferface about spooles in PETSc. I find although spooles can deal with
AX=B (B may be a dense matrix) with parallel LU factorization.
However, PETSc only provide the following:
51: PetscErrorCode MatSolve_MPISpooles(Mat A,Vec b,Vec x)
I don't set b to a matrix even if I use
178: PetscErrorCode MatFactorNumeric_MPISpooles(Mat A,MatFactorInfo
*info,Mat *F) for LU factorization.
Could you have any suggestions about this? thanks a lot.
Yujie
On 2/26/08, Sanjay Govindjee <sanjay at ce.berkeley.edu> wrote:
> from my make file
> -@${MPIRUN} -s all -np $(NPROC) $(PROGNAME) -ksp_type preonly
> -ksp_monitor -pc_type cholesky -mat_type mpisbaijspooles -log_summary
> -on_error_attach_debugger -mat_spooles_symmetryflag 0  -options_left
> -sg
> Yujie wrote:
> > Hi, everyone
> > I have compiled PETSc with spooles. However, I try to find how to use
> > this package in PETSc directory. I can't find any examples for it.
> > Could you give me some advice? I want to use spooles to inverse a
> > sparse matrix. thanks a lot.
> > Regards,
> > Yujie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080227/3b4a6a70/attachment.htm>
