Poor performance with BoomerAMG?
knutert at stud.ntnu.no knutert at stud.ntnu.no
Wed Feb 20 01:47:22 CST 2008
Wow, that is embarrassing...I had put -pc_type_hypre instead of
_pc_hypre_type.
Thanks!
-Knut Erik-
Siterer Barry Smith <bsmith at mcs.anl.gov>:
>    BoomerAMG works like a charm. Likely you forgot the -pc_hypre_type
> boomeramg
>    Hmm, I think I'll change the default solver to boomeramg
>    Barry
> barry-smiths-macbook-pro-17:ksp/examples/tutorials] bsmith% ./ex1f
> -ksp_monitor -pc_type hypre -pc_hypre_type boomeramg -m 513 -n 513
> -ksp_type richardson -ksp_view
>  p=           1
>   0 KSP Residual norm 4.213878296084e+03
>   1 KSP Residual norm 2.135189837330e+02
>   2 KSP Residual norm 1.225934028865e+01
>   3 KSP Residual norm 7.255859884400e-01
>   4 KSP Residual norm 4.353504737395e-02
>   5 KSP Residual norm 2.643035146258e-03
>   6 KSP Residual norm 1.628271972668e-04
> KSP Object:
>   type: richardson
>     Richardson: damping factor=1
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
>   left preconditioning
> PC Object:
>   type: hypre
>     HYPRE BoomerAMG preconditioning
>     HYPRE BoomerAMG: Cycle type V
>     HYPRE BoomerAMG: Maximum number of levels 25
>     HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>     HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
>     HYPRE BoomerAMG: Threshold for strong coupling 0.25
>     HYPRE BoomerAMG: Interpolation truncation factor 0
>     HYPRE BoomerAMG: Interpolation: max elements per row 0
>     HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>     HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>     HYPRE BoomerAMG: Maximum row sums 0.9
>     HYPRE BoomerAMG: Sweeps down         1
>     HYPRE BoomerAMG: Sweeps up           1
>     HYPRE BoomerAMG: Sweeps on coarse    1
>     HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
>     HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
>     HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
>     HYPRE BoomerAMG: Relax weight  (all)      1
>     HYPRE BoomerAMG: Outer relax weight (all) 1
>     HYPRE BoomerAMG: Using CF-relaxation
>     HYPRE BoomerAMG: Measure type        local
>     HYPRE BoomerAMG: Coarsen type        Falgout
>     HYPRE BoomerAMG: Interpolation type  classical
>   linear system matrix = precond matrix:
>   Matrix Object:
>     type=seqaij, rows=263169, cols=263169
>     total: nonzeros=1313793, allocated nonzeros=1315845
>       not using I-node routines
>  Iterations:           7
> [barry-smiths-macbook-pro-17:ksp/examples/tutorials] bsmith% ./ex1f
> -ksp_type gmres -ksp_view
>  p=           1
>   1 KSP Residual norm 5.272381634094e+01
>   2 KSP Residual norm 8.107668116258e-01
>   3 KSP Residual norm 1.807380875232e-02
>   4 KSP Residual norm 4.068259191532e-04
> KSP Object:
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
> PC Object:
>   type: hypre
>   Matrix Object:
>  Iterations:           4
> On Feb 18, 2008, at 1:57 AM, knutert at stud.ntnu.no wrote:
>> Thank you for the reply, Barry.
>> The same thing happens if I use hypre with the DMMG solver.
>> As you say, with hypre, the convergence is extremely slow, requiring
>> a lot of iterations, 1413 iterations (1820 if I use richardson) for
>>  a 257x257
>> problem, while the default only needs 5.
>> I use the same way of handling boundary conditions in the two codes.
>> I've also compared the coeff matrix and rhs, and they are equal.
>> -Knut Erik-
>>> Run with the DMMG solver with the option -pc_type hypre
>>> What happens? Then run again with the additional option -ksp_type
>>> richardson
>>> Is hypre taking many, many iterations which is causing the slow speed?
>>> I expect there is something wrong with your code that does not use DMMG.
>>> Be careful how you handle boundary conditions; you need to make sure
>>> they have the same scaling as the other equations.
>>>  Barry
>>> On Feb 15, 2008, at 8:36 AM, knutert at stud.ntnu.no wrote:
>>>> Hi Ben,
>>>> Thank you for answering. With gmres and boomeramg I get a run time of
>>>> 2s, so that is much better. However, if I increase the grid size to
>>>> 513x513, I get a run time of one minute. With richardson, it
>>>> fails  to converge.
>>>> LU gives 6 seconds, CG and ICC gives 7s, and the DMMG solver 3s
>>>> for  the 513x513 problem.
>>>> When using the DMMG framework, I just used the default solvers.
>>>> I use the Galerkin process to generate the coarse matrices for
>>>> the multigrid cycle.
>>>> Best,
>>>> Knut
>>>> Siterer Ben Tay <zonexo at gmail.com>:
>>>>> Hi Knut,
>>>>> I'm currently using boomeramg to solve my poisson eqn too. I'm using it
>>>>> on my structured C-grid. I found it to be faster than LU, especially as
>>>>> the grid size increases. However I use it as a preconditioner with
>>>>> GMRES as the solver. Have you tried this option? Although it's faster,
>>>>> the speed increase is usually less than double. It seems to be worse if
>>>>> there is a lot of stretching in the grid.
>>>>> Btw, your mention using the DMMG framework and it takes less than a
>>>>> sec. What solver or preconditioner did you use? It's 4 times faster
>>>>> than GMRES...
>>>>> thanks!
>>>>>> Hello,
>>>>>> I am trying to use the hypre multigrid solver to solve a
>>>>>> Poisson equation.
>>>>>> However, on a test case with grid size 257x257 it takes 40
>>>>>> seconds  to converge
>>>>>> on one processor when I run with
>>>>>> ./run -ksp_type richardson -pc_type hypre -pc_type_hypre boomeramg
>>>>>> Using the DMMG framework, the same problem takes less than a second,
>>>>>> and the default gmres solver uses only four seconds.
>>>>>> Am I somehow using the solver the wrong way, or is this
>>>>>> performance  expected?
>>>>>> Regards
>>>>>> Knut Erik Teigen
