Poor performance with BoomerAMG?
Mon Feb 18 12:10:04 CST 2008
    Please send the code to petsc-maint at mcs.anl.gov
    Something is not right.
    Barry
On Feb 18, 2008, at 1:57 AM, knutert at stud.ntnu.no wrote:
> Thank you for the reply, Barry.
> The same thing happens if I use hypre with the DMMG solver.
> As you say, with hypre, the convergence is extremely slow, requiring
> a lot of iterations, 1413 iterations (1820 if I use richardson) for
> a 257x257
> problem, while the default only needs 5.
> I use the same way of handling boundary conditions in the two codes.
> I've also compared the coeff matrix and rhs, and they are equal.
> -Knut Erik-
> Siterer Barry Smith <bsmith at mcs.anl.gov>:
>>  Run with the DMMG solver with the option -pc_type hypre
>> What happens? Then run again with the additional option -ksp_type
>> richardson
>> Is hypre taking many, many iterations which is causing the slow
>> speed?
>> I expect there is something wrong with your code that does not use
>> DMMG.
>> Be careful how you handle boundary conditions; you need to make sure
>> they have the same scaling as the other equations.
>>   Barry
>> On Feb 15, 2008, at 8:36 AM, knutert at stud.ntnu.no wrote:
>>> Hi Ben,
>>> Thank you for answering. With gmres and boomeramg I get a run time
>>> of
>>> 2s, so that is much better. However, if I increase the grid size to
>>> 513x513, I get a run time of one minute. With richardson, it
>>> fails  to converge.
>>> LU gives 6 seconds, CG and ICC gives 7s, and the DMMG solver 3s
>>> for  the 513x513 problem.
>>> When using the DMMG framework, I just used the default solvers.
>>> I use the Galerkin process to generate the coarse matrices for
>>> the multigrid cycle.
>>> Best,
>>> Knut
>>> Siterer Ben Tay <zonexo at gmail.com>:
>>>> Hi Knut,
>>>> I'm currently using boomeramg to solve my poisson eqn too. I'm
>>>> using it
>>>> on my structured C-grid. I found it to be faster than LU,
>>>> especially as
>>>> the grid size increases. However I use it as a preconditioner with
>>>> GMRES as the solver. Have you tried this option? Although it's
>>>> faster,
>>>> the speed increase is usually less than double. It seems to be
>>>> worse if
>>>> there is a lot of stretching in the grid.
>>>> Btw, your mention using the DMMG framework and it takes less than a
>>>> sec. What solver or preconditioner did you use? It's 4 times faster
>>>> than GMRES...
>>>> thanks!
>>>>> Hello,
>>>>> I am trying to use the hypre multigrid solver to solve a Poisson
>>>>> equation.
>>>>> However, on a test case with grid size 257x257 it takes 40
>>>>> seconds  to converge
>>>>> on one processor when I run with
>>>>> ./run -ksp_type richardson -pc_type hypre -pc_type_hypre boomeramg
>>>>> Using the DMMG framework, the same problem takes less than a
>>>>> second,
>>>>> and the default gmres solver uses only four seconds.
>>>>> Am I somehow using the solver the wrong way, or is this
>>>>> performance  expected?
>>>>> Regards
>>>>> Knut Erik Teigen
