sub_pc lu zero pivot
Andrew T Barker Andrew.Barker at Colorado.EDU
Fri Feb 8 12:34:27 CST 2008
I apparently was explicitly changing the PC in my code after PCSetFromOptions, so the options weren't getting set properly (which I found out by using -snes_view).  Sorry to bother.
Andrew
---- Original message ----
>Date: Fri, 8 Feb 2008 12:02:45 -0600
>From: "Matthew Knepley" <knepley at gmail.com>
>Subject: Re: sub_pc lu zero pivot
>To: petsc-users at mcs.anl.gov
>We would like to see:
>  1) The complete error message
>  2) The output of -snes_view so we can see exactly what solver setup you have
>  Thanks,
>     Matt
>On Feb 8, 2008 11:46 AM, Andrew T Barker <Andrew.Barker at colorado.edu> wrote:
>> For my code on a single processor, using the options
>> -ksp_type gmres -pc_type lu
>> works fine, but
>> -ksp_type gmres -pc_type asm -sub_pc_type lu
>> produces a zero pivot.  On one processor I would expect these two to be identical, and in fact when I print out the asm submatrices (there is only one) in the second case and the original matrix in the first case, they are identical.  Even stranger is that
>> -ksp_type gmres -pc_type lu -sub_pc_type lu
>> also produces a zero pivot.  I would expect it to ignore the sub_pc in this case.
>> Thanks for any help,
>> Andrew
>> Andrew T. Barker
>> andrew.barker at colorado.edu
>> Applied Math Department
>> University of Colorado, Boulder
>> 526 UCB, Boulder, CO 80309-0526
>What most experimenters take for granted before they begin their
>experiments is infinitely more interesting than any results to which
>their experiments lead.
>-- Norbert Wiener
