how to inverse a sparse matrix in Petsc?
Yujie recrusader at gmail.com
Tue Feb 5 11:26:35 CST 2008
Hi, Tim
Thank you for your help. I am really glad to get your help.
According to what you said, if the matrix A has been divided into several
nodes in the cluster, you may use your parallel code to inverse A?
My problem is that what is the distribution of the results?
thanks a lot.
Yujie
On 2/5/08, Timothy Stitt <tstitt at cscs.ch> wrote:
> Yes Yujie, I was able to put together a parallel code to invert a large
> sparse matrix with the help of the PETSc developers. If you need any
> help or maybe a Fortran code template just let me know.
> Best,
> Tim.
> Waad Subber wrote:
> > Hi
> > There was a discussion between Tim Stitt and petsc developers about
> > matrix inversion, and it was really helpful. That was in last Nov. You
> > can check the emails archive
> http://www-unix.mcs.anl.gov/web-mail-archive/lists/petsc-users/2007/11/threads.html
> > Waad
> > */Yujie <recrusader at gmail.com>/* wrote:
> >     what is the difference between sequantial and parallel AIJ matrix?
> >     Assuming there is a matrix A, if
> >     I partitaion this matrix into A1, A2, Ai... An.
> >     A is a parallel AIJ matrix at the whole view, Ai
> >     is a sequential AIJ matrix? I want to operate Ai at each node.
> >     In addition, whether is it possible to get general inverse using
> >     MatMatSolve() if the matrix is not square? Thanks a lot.
> >     Regards,
> >     Yujie
> >     On 2/4/08, *Barry Smith* <bsmith at mcs.anl.gov
> >     <mailto:bsmith at mcs.anl.gov>> wrote:
> >             For sequential AIJ matrices you can fill the B matrix with
> the
> >         identity and then use
> >         MatMatSolve().
> >             Note since the inverse of a sparse matrix is dense the B
> >         matrix is
> >         a SeqDense matrix.
> >             Barry
> >         On Feb 4, 2008, at 12:37 AM, Yujie wrote:
> >         > Hi,
> >         > Now, I want to inverse a sparse matrix. I have browsed the
> >         manual,
> >         > however, I can't find some information. could you give me
> >         some advice?
> >         > thanks a lot.
> >         > Regards,
> >         > Yujie
> > Looking for last minute shopping deals? Find them fast with Yahoo!
> > Search.
> http://us.rd.yahoo.com/evt=51734/*http://tools.search.yahoo.com/newsearch/category.php?category=shopping
> Timothy Stitt
> HPC Applications Analyst
> Swiss National Supercomputing Centre (CSCS)
> Galleria 2 - Via Cantonale
> CH-6928 Manno, Switzerland
> +41 (0) 91 610 8233
> stitt at cscs.ch
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080205/ef5eb69c/attachment.htm>
