how to inverse a sparse matrix in Petsc?
Mon Feb 4 08:06:58 CST 2008
   They should be pretty much the same. In both cases the huge bulk of
the time
is spent in the triangular solves.
    Barry
On Feb 4, 2008, at 8:04 AM, Dave May wrote:
> Hi,
>     Does anyone know how much faster (approximately) using
> MatMatSolve is compared
> to using PCComputeExplicitOperator(), when the PC in the latter
> function is defined to be LU?
> Cheers,
>     Dave.
> On Feb 5, 2008 12:10 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    For sequential AIJ matrices you can fill the B matrix with the
> identity and then use
> MatMatSolve().
>    Note since the inverse of a sparse matrix is dense the B matrix is
> a SeqDense matrix.
>    Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080204/1bfa019d/attachment.htm>
