how to inverse a sparse matrix in Petsc?
Mon Feb 4 07:58:27 CST 2008
    Yes. It uses the LU factorization of the matrix computed with
MatLUFactor().
    Barry
On Feb 4, 2008, at 7:49 AM, li pan wrote:
> hi,
> Does MatMatSolve() use Gauss elimination method?
> thanx
> pan
> --- Barry Smith <bsmith at mcs.anl.gov> wrote:
>>    For sequential AIJ matrices you can fill the B
>> matrix with the
>> identity and then use
>> MatMatSolve().
>>    Note since the inverse of a sparse matrix is
>> dense the B matrix is
>> a SeqDense matrix.
>>    Barry
>> On Feb 4, 2008, at 12:37 AM, Yujie wrote:
>>> Hi,
>>> Now, I want to inverse a sparse matrix. I have
>> browsed the manual,
>>> however, I can't find some information. could you
>> give me some advice?
>>> thanks a lot.
>>> Regards,
>>> Yujie
> ____________________________________________________________________________________
> Never miss a thing.  Make Yahoo your home page.
> http://www.yahoo.com/r/hs
