strange convergency behavior with petsc (intialy produces good result, suddenly diverges)
Shengyong lua.byhh at gmail.com
Tue Aug 19 01:07:42 CDT 2008
If do not use PETSc or laspack,the result is fine. I have comparied with
some literature results.
Maybe there are some bugs in my coeffient matrix generation code. I will try
to fix it.
Thanks.
On Tue, Aug 19, 2008 at 3:23 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Again, what happens with -pc_type lu? Does the simulation run for any
> number of time steps with correct answers?
>  Barry
> On Aug 18, 2008, at 12:02 PM, Shengyong wrote:
>  Hi, Barry
>> Thanks for your help!
>> What I mean is that both of your suggested method converge for a while
>> then stagnant.  Once stagnation happens, then after maximum iteration number
>> reaches, PETSc fill  the solution with exactly zero. So error occurs in the
>> next time step.  I am a newbie and can not explain why this happens since I
>> have set the initial guess is not zero in my code. E.g, I have called  this
>>  function KSPSetInitialGuessNonzero(userctx.ksp, PETSC_TRUE);
>> For the stagnation, it seems that the rounding error dominates during
>> iteration in some special situations since the coefficient Matrix A is very
>> ill-conditioned(the Cond number over 10^6 in some cases). Although with null
>> space method by project B vector to R(A) will remede the stagnant phenomena.
>> Actually it does not. I have read a paper in J. Comp. Appl. Math. in year of
>> 1988 : 'preconditioned conjugate gradient for solving singular systems'. The
>> author suggests not only project B to R(A) space, but also X(i+1) (solution
>> vector during iteration) and  r(i+1) ( residual vector during iteration) to
>> R(A*) (A* refers to preconditioned A). I am not clear about how icc and cg
>> method are implemented in PETSc. Above is just my not so mature guess.
>> My simulation code could run unlimited time steps with self-coded SOR
>> method. The SOR method is implemented as matrix free method. In this method,
>> the Neumann BC is not directly discretized in equations, but this way is
>> adopted: assuming P[0] is BC, then P[0] cell does not particpate in any
>> iteration, but rather after one step iteration ends, I set P[0] = P[1] while
>> P[1] cell is inner fluid cell.  While with PETSc method, I directly discrete
>> the Neumann BC into boundary cells' equation.  I think this difference does
>> not matter the converge stuff at all since the initially severay time steps
>> PETSc solver gives nice results.
>> Best Regards,
>> On Mon, Aug 18, 2008 at 11:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Aug 18, 2008, at 12:35 AM, Shengyong wrote:
>> hi, Barry
>> Thanks for your kindly reply!
>> Here I report some experiments accoording to your hints.
>> -pc_type sor -pc_sor_local_symmetric _ksp_type cg failed.
>>  What does failed mean? Converged for a while then stagnated? Diverged
>> (the residual norm got larger and larger)? Never converged at all?
>> icc(1) also failed.
>>  I suggest running with -pc_type lu (keep the -ksp_type gmres) and see
>> what happens? Does you simulation run fine for an unlimited number
>> of timesteps? If not, how does it fail?
>>  Barry
>> When using -ksp_monitor_true _residual with icc(0), I have found the
>> precond residual is osillation around some value about 1.06e-004, the true
>> residual norm almost staying at 7.128 e-004.  The ||Ae||/||Ax|| also
>> stagnent at 6.3e-005.
>> After the maximum number of iterations (=2000) reached, the iteration
>> fails. Even when I set iteration number to 10000, it seems that petsc also
>> fails.
>> Below is some resiual information near iteration number 2000 when with
>> ksp_monitor_true_residual.
>> 1990 KSP preconditioned resid norm 1.064720311837e-004 true resid norm
>> 7.1284721
>> 18425e-004 ||Ae||/||Ax|| 6.302380221818e-005
>> 1991 KSP preconditioned resid norm 1.062055494352e-004 true resid norm
>> 7.1281202
>> 17324e-004 ||Ae||/||Ax|| 6.302069101215e-005
>> 1992 KSP preconditioned resid norm 1.061228895583e-004 true resid norm
>> 7.1277740
>> 15661e-004 ||Ae||/||Ax|| 6.301763019565e-005
>> 1993 KSP preconditioned resid norm 1.062165148129e-004 true resid norm
>> 7.1274335
>> 10277e-004 ||Ae||/||Ax|| 6.301461974073e-005
>> 1994 KSP preconditioned resid norm 1.064780917764e-004 true resid norm
>> 7.1270986
>> 90168e-004 ||Ae||/||Ax|| 6.301165955010e-005
>> 1995 KSP preconditioned resid norm 1.068986431546e-004 true resid norm
>> 7.1267695
>> 37853e-004 ||Ae||/||Ax|| 6.300874946922e-005
>> 1996 KSP preconditioned resid norm 1.074687043135e-004 true resid norm
>> 7.1264460
>> 30395e-004 ||Ae||/||Ax|| 6.300588929530e-005
>> 1997 KSP preconditioned resid norm 1.081784773720e-004 true resid norm
>> 7.1261281
>> 40328e-004 ||Ae||/||Ax|| 6.300307878551e-005
>> 1998 KSP preconditioned resid norm 1.090179775109e-004 true resid norm
>> 7.1258158
>> 36472e-004 ||Ae||/||Ax|| 6.300031766417e-005
>> 1999 KSP preconditioned resid norm 1.099771672684e-004 true resid norm
>> 7.1255090
>> 84603e-004 ||Ae||/||Ax|| 6.299760562872e-005
>> 2000 KSP preconditioned resid norm 1.110460758301e-004 true resid norm
>> 7.1252078
>> 48108e-004 ||Ae||/||Ax|| 6.299494235544e-005
>> On Sun, Aug 17, 2008 at 10:32 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Try using -pc_type sor -pc_sor_local_symmetric -ksp_type cg
>>  Also try running the original icc one with the additional option
>> -ksp_monitor_true_residual, see if funky stuff starts to happen.
>>  You could also try adding -pc_factor_levels 1 to try ICC(1) instead of
>> ICC(0).
>>  Your code looks fine, I don't see a problem there,
>>  Barry
>>  Here is my guess, as the simulation proceeds the variable coefficient
>> problem changes enough so that the ICC produces
>> a badly scaled preconditioner that messes up the iterative method. I see
>> this on occasion and don't have a good fix, the shift
>> positive definite helps sometimes but not always.
>> On Aug 17, 2008, at 3:36 AM, Shengyong wrote:
>> Hi,
>> I am still struggling to use petsc to solve variable coefficient poisson
>> problems (which orinates from a multi-phase(liquid-gas two phase flow with
>> sharp interface method, the density ratio is 1000, and with surface tension)
>> flow problem) successively.
>> Initially petsc produces good results with icc pc_type , cg iterative
>> method and with _pc_factor_shift_positive_define flag.  I follow petsc's
>> null space method to constrain the singular property of coefficient matrix.
>> However,  after several time steps good results of simulation, the KSP
>> Residual Norm suddenly reaches to a number greater than 1000. I guess that
>> petsc diverges. I have also tried to swith to other types of methods, e.g.
>> to gmeres, it just behaves similar to cg method.  However, when I use my
>> previous self-coded SOR iterative solver, it produces nice results.  And I
>> have tested the same petsc solver class for a single phase driven cavity
>> flow problem, it also produces nice results.
>> It seems that I have missed something important setup procedure in my
>> solver class. could anyone to point me the problem ?  I have attached large
>> part of  the code  below:
>> //in Header
>> class CPETScPoissonSolver
>>  typedef struct {
>>     Vec                  x,b;     //x, b
>>     Mat                 A;       //A
>>     KSP                ksp;   //Krylov subspace preconditioner
>>     PC                   pc;
>>     MatNullSpace  nullspace;
>>     PetscInt            l, m, n;//L, M, N
>>  } UserContext;
>> public:
>>  CPETScPoissonSolver(int argc, char** argv);
>>  ~CPETScPoissonSolver(void);
>> private:
>>  //Yale Sparse Matrix format matrix
>>   PetscScalar*  A;
>>   PetscInt     *   I;
>>   PetscInt     *   J;
>>   // Number of Nonzero Element
>>   PetscInt          nnz;
>>   //grid step
>>   PetscInt          L, M, N;
>>   UserContext    userctx;
>> private:
>>  bool             FirstTime;
>> //in cpp
>> static char helpPetscPoisson[] = "PETSc class Solves a variable Poisson
>> problem with Null Space Method.\n\n";
>> CPETScPoissonSolver::CPETScPoissonSolver(int argc, char** argv)
>>  PetscInitialize(&argc, &argv, (char*)0, helpPetscPoisson);
>>  FirstTime=true;
>> CPETScPoissonSolver::~CPETScPoissonSolver(void)
>>  PetscFinalize();
>> void CPETScPoissonSolver::SetAIJ(PetscScalar *a, PetscInt *i, PetscInt *j,
>> PetscInt Nnz)
>>  A= a; I=i; J=j; nnz = Nnz;
>> PetscErrorCode CPETScPoissonSolver::UserInitializeLinearSolver()
>>  PetscErrorCode ierr = 0;
>>  PetscInt Num = L*M*N;
>>  //Since we use successive solvers, so in the second time step we must
>> deallocate the original matrix then setup a new one
>>  if(FirstTime==true)
>>      ierr = MatCreateSeqAIJWithArrays(PETSC_COMM_SELF,  Num,  Num,  I,  J,
>>  A, &userctx.A); CHKERRQ(ierr);
>>  else
>>        FirstTime = false;
>>        ierr = MatDestroy(userctx.A);CHKERRQ(ierr);
>>  J,  A, &userctx.A); CHKERRQ(ierr);
>>  if(FirstTime==true)
>>      ierr =
>> VecCreateSeqWithArray(PETSC_COMM_SELF,Num,PETSC_NULL,&userctx.b);CHKERRQ(ierr);
>>      ierr = VecDuplicate(userctx.b,&userctx.x);CHKERRQ(ierr);
>>      ierr = MatNullSpaceCreate(PETSC_COMM_SELF, PETSC_TRUE, 0, PETSC_NULL,
>> &userctx.nullspace); CHKERRQ(ierr);
>>      ierr = KSPCreate(PETSC_COMM_SELF,&userctx.ksp);CHKERRQ(ierr);
>>      /*Set Null Space for KSP*/
>>      ierr = KSPSetNullSpace(userctx.ksp, userctx.nullspace);CHKERRQ(ierr);
>>  return 0;
>> PetscErrorCode CPETScPoissonSolver::UserSetBX(PetscScalar *x, PetscScalar
>> *b)
>>    PetscErrorCode ierr ;
>>    //below code we must set it every time step
>>    ierr = VecPlaceArray(userctx.x,x);CHKERRQ(ierr);
>>    ierr = VecPlaceArray(userctx.b,b);CHKERRQ(ierr);
>>    ierr =  MatNullSpaceRemove(userctx.nullspace,userctx.b,
>> PETSC_NULL);CHKERRQ(ierr);
>>    return 0;
>> PetscInt CPETScPoissonSolver::UserSolve()
>>    PetscErrorCode ierr;
>>    ierr =
>> KSPSetOperators(userctx.ksp,userctx.A,userctx.A,SAME_NONZERO_PATTERN);CHKERRQ(ierr);
>>    ierr = KSPSetType(userctx.ksp, KSPCG);
>>    ierr = KSPSetInitialGuessNonzero(userctx.ksp, PETSC_TRUE);
>>    ierr = KSPGetPC(userctx.ksp,&userctx.pc);CHKERRQ(ierr);
>>    ierr = PCSetType(userctx.pc,PCICC);CHKERRQ(ierr);
>>    ierr = PCFactorSetShiftPd(userctx.pc, PETSC_TRUE);
>>    ierr =
>> KSPSetTolerances(userctx.ksp,1.e-4,PETSC_DEFAULT,PETSC_DEFAULT,2000);
>>    ierr = KSPSetFromOptions(userctx.ksp);CHKERRQ(ierr);
>>                        Solve the linear system
>>    ierr = KSPSolve(userctx.ksp,userctx.b,userctx.x);CHKERRQ(ierr);
>>    ierr = VecResetArray(userctx.x);CHKERRQ(ierr);
>>    ierr = VecResetArray(userctx.b);CHKERRQ(ierr);
>>    return 0;
>> PetscErrorCode CPETScPoissonSolver::ReleaseMem()
>>    ierr = KSPDestroy(userctx.ksp);CHKERRQ(ierr);
>>    ierr = VecDestroy(userctx.x);     CHKERRQ(ierr);
>>    ierr = VecDestroy(userctx.b);     CHKERRQ(ierr);
>>    ierr = MatDestroy(userctx.A);    CHKERRQ(ierr);
>>    ierr = MatNullSpaceDestroy(userctx.nullspace); CHKERRQ(ierr);
>>    return 0;
>> Thanks very much!
>> Pang Shengyong
>> Solidification Simulation Lab,
>> State Key Lab of Mould & Die Technology,
>> Huazhong Univ. of Sci. & Tech. China
>> Pang Shengyong
>> Pang Shengyong
Pang Shengyong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080819/d956ea72/attachment.htm>
