problem in compiling petsc for visual c++ 2005
berry lua.byhh at gmail.com
Tue Aug 12 08:03:46 CDT 2008
Hi, Matt
Previously I installed petsc on cygwin following the official guide from
petsc website. Because I started from cygwin shell, so both' mkdir 'and
'sed' command are transparent for petsc configure script.
But for VC 2005 version, I start from VC 2005 command line prompt, and type:
c:\cygwin\bin\bash , then going to the bash shell. I am not sure why in this
way the installation script can not see the 'sed' and 'mkdir'. By the way,
it also miss python. So I give an absolute path for executing configure.py.
Although it starts to run the configure.py script, it misses some command
line utilities in sub installation script.
thanks
On Tue, Aug 12, 2008 at 7:34 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Aug 12, 2008 at 5:18 AM, berry <lua.byhh at gmail.com> wrote:
>> Hi,
>> I am trying to compile  PETSC  in cygwin for Visual c++ 2005.  I follow
>> the guide exactly from here:
>> http://www-unix.mcs.anl.gov/petsc/petsc-2/documentation/installation.html.
>> and use below command:
>>  /usr/bin/python ./config/configure.py --with-cc='win32fe cl --nodetect'
>> --with-fc='win32fe ifort --nodetect'  --with-mpi=1 --with-f-blas-lapack=1
>> --with-hypre=1
>>  PETSC installation script really starts to run. However, it fails with
>> below errors:
>>              Configuring PETSc to compile on your system
>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
>> detail
>> s):
>> Unable to determine host type using
>> /cygdrive/c/cygwin/home/pangshengyong/soft/p
>> etsc-2.3.3-p13/python/BuildSystem/config/packages/config.sub: Could not
>> execute
>> '/bin/sh
>> /cygdrive/c/cygwin/home/pangshengyong/soft/petsc-2.3.3-p13/python/Build
>> System/config/packages/config.guess':
>> /cygdrive/c/cygwin/home/pangshengyong/soft/petsc-2.3.3-p13/python/BuildSystem/co
>> nfig/packages/config.guess: line 38: sed: command not found
>> nfig/packages/config.guess: line 1272: mkdir: command not found
>> : cannot create a temporary directory in /tmp
>> It seems that the configure script miss to find the correct path. Does
>> anyone could point me out how to set the correct path for configure script
>> please?
>> Btw:  I have successfully compiled petsc library on cygwin for gcc.
> I am not sure how you built PETSc on cygwin before. Perhaps a different
> copy? This
> error seems to occur because you cygwin is missing the command line
> utilities
> 'sed' and 'mkdir'.
>    Matt
>> Thanks.
>> Pang Shengyong
>> Solidification Simulation Lab,
>> State Key Lab of Mould & Die Technology,
>> Huazhong Univ. of Sci. & Tech. China
> experiments lead.
> -- Norbert Wiener
Pang Shengyong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080812/9a9f5622/attachment.htm>
