KSPSetNullSpace and CG for singular systems
Shao-Ching Huang schuang at ats.ucla.edu
Fri Aug 1 19:52:00 CDT 2008
I am trying to use CG to solve a singular systems (i.e. Poisson
equation with periodic conditions on all boundaries).
The code works when I use GMRES, but it diverges when I switch CG.
Since the null space is a constant vector, in the code I have:
   KSP ksp;
   MatNullSpace nullspace;
   MatNullSpaceCreate(MPI_COMM_WORLD, PETSC_TRUE, 0, PETSC_NULL, &nullspace);
   KSPSetNullSpace(ksp, nullspace);
   MatNullSpaceRemove(nullspace, f->p_rhs, PETSC_NULL);
   KSPSetFromOptions(ksp);
   KSPSetUp(ksp);
   KSPSolve(ksp, f->p_rhs, f->phi);
[f->p_rhs is the RHS vector. f->phi is the solution vector.]
When I use "-ksp_type gmres", it converges (shown by -ksp_monitor).
However, when I switch to "-ksp_type cg", it diverges.
In this case (cg), "-ksp_converged_reason" says:
  Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 1
I also try adding "-sub_pc_factor_shift_nonzero 0.0000000001" but the
CG case still fails.
Am I missing some step in handling the null space when using CG?
Shao-Ching Huang
