PETSC with MPI-GAMMA ??
amjad ali amjad11 at gmail.com
Wed Apr 30 01:24:27 CDT 2008
Hello,
I read that:
Genoa Active Message MAchine (GAMMA <http://www.disi.unige.it/project/gamma>)
is a low-latency replacement for TCP/IP on gigabit and is supported for
Intel platforms on modern Linux kernels (both 32 and 64 bit). It completely
bypasses the Linux network stack to produce record breaking latency figures.
(Please see also http://www.opencfd.co.uk/openfoam/parallel1.4.html that
tells how OPEN-FOAM is/will-be  using GAMMA).
Please comment on that can take benefit of GAMMA (if there is??) with PETSc?
For example, installing PETSc with GAMMA?
regards,
Amjad Ali.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080430/6a2138b0/attachment.htm>
