Multilevel solver
Thu Apr 24 12:13:28 CDT 2008
On Apr 24, 2008, at 8:58 AM, Amit.Itagi at seagate.com wrote:
> Barry,
> I have been trying out the PCFIELDSPLIT. I have not yet gotten it to
> work.
> I have some follow up questions which might help solve my problem.
> Consider the simple case of a 4x4 matrix equation being solved on two
> processes. I have vector elements 0 and 1 belonging to rank 0, and
> elements
> 2 and 3 belonging to rank 1.
> 1) For my example, can the index sets have staggered indices i.e.
> is1-> 0,2
> and  is2->1,3  (each is spans across ranks) ?
> 2) When I provide the -field_split_<n>_pc_type option on the command
> line,
                            There is no underscore here because the PC
name is fieldsplit
and we never split the names into pieces.
> is the index <n> in the same order that the PCFieldSplitSetIS function
> called in ?
>     So if I have  PCFieldSplitSetIS(pc,is2) before
> PCFieldSplitSetIS(pc,is1), will -field_split_0_... correspond to is2
> and
> -field_split_1_... to is1 ?
    You can list them in any order you want but the order determines
how the
multiplicative versions are applied. They are applied always started
from zero
(the first one you put in).
> 3) Since I want to set PC type to lu for field 0, and I want to use
> MUMPS
> for parallel LU, where do I set the submatrix type to MATAIJMUMPS ?
> In this
> case, will a second copy of the submatrix be generated - one of type
> MUMPS
> for the PC and the other of the original MATAIJ type for the KSP ?
     This issue will be fixed in a few days. I think you need to start
with an entire
matrix that is aijmumps and then the subs will also be.
    Barry
> 4) How is the PC applied when I do
> PC_COMPOSITE_SYMMETRIC_MULTIPLICATIVE ?
> Thanks
> Rgds,
> Amit
>             Barry Smith
>             <bsmith at mcs.anl.g
> ov>                                                        To
>             Sent by:                  petsc-users at mcs.anl.gov
>             owner-petsc-
> users                                          cc
>             @mcs.anl.gov
>             No Phone Info
> Subject
>             Available                 Re: Multilevel solver
>             04/22/2008 10:08
>             PM
>             Please respond to
>                  nl.gov
>  Amit,
>     Using a a PCSHELL should be fine (it can be used with GMRES),
> my guess is there is a memory corruption error somewhere that is
> causing the crash. This could be tracked down with www.valgrind.com
>    Another way to you could implement this is with some very recent
> additions I made to PCFIELDSPLIT that are in petsc-dev
> (http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html)
> With this you would chose
> PCSetType(pc,PCFIELDSPLIT
> PCFieldSplitSetType(pc,PC_COMPOSITE_SYMMETRIC_MULTIPLICATIVE
> to use LU on A11 use the command line options
> -fieldsplit_0_pc_type lu -fieldsplit_0_ksp_type preonly
> and SOR on A22
> -fieldsplit_1_pc_type sor -fieldsplit_1_ksp_type preonly -
> fieldsplit_1_pc_sor_lits <lits> where
>    <its> is the number of iterations you want to use block A22
> is1 is the IS that contains the indices for all the vector entries in
> the 1 block while is2 is all indices in the
> vector for the 2 block. You can use ISCreateGeneral() to create these.
>   Probably it is easiest just to try this out.
>   Barry
> On Apr 22, 2008, at 8:45 PM, Amit.Itagi at seagate.com wrote:
>> Hi,
>> I am trying to implement a multilevel method for an EM problem. The
>> reference is : "Comparison of hierarchical basis functions for
>> efficient
>> multilevel solvers", P. Ingelstrom, V. Hill and R. Dyczij-Edlinger,
>> IET
>> Sci. Meas. Technol. 2007, 1(1), pp 48-52.
>> Here is the summary:
>> The matrix equation Ax=b is solved using GMRES with a multilevel
>> pre-conditioner. A has a block structure.
>> A11    A12       *         x1  =  b1
>> A21    A22                  x2       b2
>> A11 is mxm and A33 is nxn, where m is not equal to n.
>> Step 1  :      Solve  A11 *  e1   = b1     (parallel LU using
>> superLU or
>> MUMPS)
>> Step 2:        Solve   A22 * e2    =b2-A21*e1    (might either user
>> a SOR
>> solver or a parallel LU)
>> Step 3:        Solve   A11* e1 = b1-A12*e2   (parallel LU)
>> This gives the approximate solution to
>> A11     A12     *      e1   =  b1
>> A21     A22             e2       b2
>> and is used as the pre-conditioner for the GMRES.
>> Which PetSc method can implement this pre-conditioner ? I tried a
>> PCSHELL
>> type PC. With Hong's help, I also got the parallel LU to work
>> withSuperLU/MUMPS. My program runs successfully on multiple
>> processes on a
>> single machine. But when I submit the program over multiple
>> machines, I get
>> a crash in the PCApply routine after several GMRES iterations. I
>> think this
>> has to do with using PCSHELL with GMRES (which is not a good idea).
>> Is
>> there a different way to implement this ? Does this resemble the
>> usage
>> pattern of one of the AMG preconditioners ?
>> Thanks
>> Rgds,
>> Amit
