Multilevel solver
Wed Apr 23 09:40:39 CDT 2008
If using valgrind - I sugest using MPICH2 [installed with options
--enable-g=meminit --enable-fast]
And valgrind can be invoked with:
mpiexec -np 2 valgrind --tool=memcheck -q ./executable -exectuable-options
Satish
On Wed, 23 Apr 2008, Matthew Knepley wrote:
> On Wed, Apr 23, 2008 at 9:07 AM,  <Amit.Itagi at seagate.com> wrote:
> > Barry,
> > This is what valgrind gives me. Any idea ? What is confusing me is that I
> > get the crash after several GMRES iterations.
> 1) Always start with the simplest case, meaning serial
> 2) When you run valgrind in parallel, you need --trace-children=yes, since
>     MPI usually spawns other processes
> 3) It is possible to corrupt memory so badly that valgrind crashes
> like this, but it is hard.
>    Matt
> > [2]PETSC ERROR:
> > [3]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the
> > batch system) has told this process to end
> > [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> > [3]PETSC ERROR: or see
> > http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[3]PETSC
> > ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to
> > find memory corruption errors
> > [2]PETSC ERROR: Caught signal number 1 Hang up: Some other process (or the
> > [2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> > [2]PETSC ERROR: or see
> > http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[2]PETSC
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the
> > [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> > [0]PETSC ERROR: or see
> > http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC
> > [3]PETSC ERROR: likely location of problem given in stack below
> > [3]PETSC ERROR: ---------------------  Stack Frames
> > [1]PETSC ERROR: [2]PETSC ERROR: Caught signal number 15 Terminate: Somet
> > process (or the batch system) has told this process to end
> > [1]PETSC ERROR: [2]PETSC ERROR: Try option -start_in_debugger or
> > ---------------------  Stack Frames ------------------------------------
> > [1]PETSC ERROR: or see
> > http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[1]PETSC
> > [0]PETSC ERROR: likely location of problem given in stack below
> > [0]PETSC ERROR: ---------------------  Stack Frames
> > [1]PETSC ERROR: likely location of problem given in stack below
> > [1]PETSC ERROR: ---------------------  Stack Frames
> > [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> > [3]PETSC ERROR:       INSTEAD the line number of the start of the function
> > [3]PETSC ERROR:       is given.
> > [2]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> > [3]PETSC ERROR: [2]PETSC ERROR:       INSTEAD the line number of the start
> > of the function
> > [2]PETSC ERROR:       is given.
> > [3] PCApply_Shell line 122 src/ksp/pc/impls/shell/shellpc.c
> > [3]PETSC ERROR: [3] PCApply line 346 src/ksp/pc/interface/precon.c
> > [3]PETSC ERROR: [3] PCApplyBAorAB line 539 src/ksp/pc/interface/precon.c
> > [3]PETSC ERROR: [3] GMREScycle line 133 src/ksp/ksp/impls/gmres/gmres.c
> > [2]PETSC ERROR: [0]PETSC ERROR: Note: The EXACT line numbers in the stack
> > are not available,
> > [2] PCApply_Shell line 122 src/ksp/pc/impls/shell/shellpc.c
> > [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> > [2]PETSC ERROR: [2] PCApply line 346 src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR:       is given.
> > [2]PETSC ERROR: [2] PCApplyBAorAB line 539 src/ksp/pc/interface/precon.c
> > [2]PETSC ERROR: [2] GMREScycle line 133 src/ksp/ksp/impls/gmres/gmres.c
> > [1]PETSC ERROR: [0]PETSC ERROR: Note: The EXACT line numbers in the stack
> > are not available,
> > [0] PCApply_Shell line 122 src/ksp/pc/impls/shell/shellpc.c
> > [1]PETSC ERROR:       INSTEAD the line number of the start of the function
> > [0]PETSC ERROR: [0] PCApply line 346 src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: [1]PETSC ERROR:       is given.
> > [0] PCApplyBAorAB line 539 src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: [0] GMREScycle line 133 src/ksp/ksp/impls/gmres/gmres.c
> > [1]PETSC ERROR: [1] PCApply_Shell line 122 src/ksp/pc/impls/shell/shellpc.c
> > [1]PETSC ERROR: [1] PCApply line 346 src/ksp/pc/interface/precon.c
> > [1]PETSC ERROR: [3]PETSC ERROR: [1] PCApplyBAorAB line 539
> > --------------------- Error Message ------------------------------------
> > [1]PETSC ERROR: [1] GMREScycle line 133 src/ksp/ksp/impls/gmres/gmres.c
> > [2]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: --------------------- Error Message
> > [3]PETSC ERROR: Signal received!
> > [3]PETSC ERROR:
> > [3]PETSC ERROR: Petsc Release Version 2.3.3, Patch 8, Fri Nov 16 17:03:40
> > CST 2007 HG revision: 414581156e67e55c761739b0deb119f7590d0f4b
> > [3]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > Thanks
> > Rgds,
> > Amit
