flexible block matrix
Mon Apr 21 11:47:26 CDT 2008
   I concur with Satish, AIJ with inodes is essentially variable block
size
so trying to force BAIJ when it is not appropriate is unnecessary.
   Barry
On Apr 21, 2008, at 9:53 AM, Jed Brown wrote:
> I am solving a Stokes problem with nonlinear slip boundary
> conditions.  I don't
> think I can take advantage of block structure since the normal
> component of
> velocity has a Dirichlet constraint and this must be built into the
> velocity
> space in order to preserve conditioning.  An alternative formulation
> involves a
> Lagrange multiplier for the constraint, but even with clever
> preconditioning,
> this system is still more expensive to solve according to [1].
> In solving the (velocity-pressure) saddle point problem, many
> approximate solves
> with the velocity system is needed in the preconditioner, hence I
> need a strong
> preconditioner for the velocity system.  Currently, I am using
> algebraic
> multigrid on a low-order discretization which works fairly well.
> Since Hypre
> and ML only take AIJ matrices, perhaps I shouldn't worry about
> blocking after
> all.  Is there a way to use MATBAIJ when some nodes have fewer
> degrees of
> freedom?  Should I bother?
> Note that my method (currently just a single element) uses a high
> order
> discretization on some elements and low order on others.  The global
> matrix for
> the low order elements is assembled, but it is applied locally for
> the high order
> elements taking advantage of the tensor product basis.  For the
> preconditioner,
> a low order discretization on the nodes of the high order elements
> is globally
> assembled and added to the global matrix from the low-order elements.
> Experiments with a single element (spectral rather than spectral/hp
> element)
> show this to be effective, converging in a constant number of
> iterations
> independent of polynomial order when using a V-cycle of AMG as a
> preconditioner.
> Thanks.
> Jed
> [1] Bänsch, Höhn 2000, `Numerical treatment of the Navier-Stokes
> equations with
> slip boundary conditions', SIAM J. Sci. Comput.
