Slow speed after changing from serial to parallel (with ex2f.F)
Ben Tay zonexo at gmail.com
Wed Apr 16 08:44:15 CDT 2008
Am I right to say that despite all the hype about multi-core processors,
they can't speed up solving of linear eqns? It's not possible to get a
2x speedup when using 2 cores. And is this true for all types of linear
equation solver besides PETSc? What about parallel direct solvers (e.g.
MUMPS) or those which uses openmp instead of mpich? Well, I just can't
help feeling disappointed if that's the case...
Also, with a smart enough LSF scheduler, I will be assured of getting
separate processors ie 1 core from each different processor instead of
2-4 cores from just 1 processor. In that case, if I use 1 core from
processor A and 1 core from processor B, I should be able to get a
decent speedup of more than 1, is that so? This option is also better
than using 2 or even 4 cores from the same processor.
Thank you very much.
Satish Balay wrote:
> On Wed, 16 Apr 2008, Ben Tay wrote:
>> Hi Satish, thank you very much for helping me run the ex2f.F code.
>> I think I've a clearer picture now. I believe I'm running on Dual-Core Intel
>> Xeon 5160. The quad core is only on atlas3-01 to 04 and there's only 4 of
>> them. I guess that the lower peak is because I'm using Xeon 5160, while you
>> are using Xeon X5355.
> I'm still a bit puzzled. I just ran the same binary on a 2 dualcore
> xeon 5130 machine [which should be similar to your 5160 machine] and
> get the following:
> [balay at n001 ~]$ grep MatMult log*
> log.1:MatMult             1192 1.0 1.0591e+01 1.0 3.86e+09 1.0 0.0e+00 0.0e+00 0.0e+00 14 11  0  0  0  14 11  0  0  0   364
> log.2:MatMult             1217 1.0 6.3982e+00 1.0 1.97e+09 1.0 2.4e+03 4.8e+03 0.0e+00 14 11100100  0  14 11100100  0   615
> log.4:MatMult              969 1.0 4.7780e+00 1.0 7.84e+08 1.0 5.8e+03 4.8e+03 0.0e+00 14 11100100  0  14 11100100  0   656
> [balay at n001 ~]$
>> You mention about the speedups for MatMult and compare between KSPSolve. Are
>> these the only things we have to look at? Because I see that some other event
>> such as VecMAXPY also takes up a sizable % of the time. To get an accurate
>> speedup, do I just compare the time taken by KSPSolve between different no. of
>> processors or do I have to look at other events such as MatMult as well?
> Sometimes we look at individual components like MatMult() VecMAXPY()
> to understand whats hapenning in each stage - and at KSPSolve() to
> look at the agregate performance for the whole solve [which includes
> MatMult VecMAXPY etc..]. Perhaps I should have also looked at
> VecMDot() aswell - at 48% of runtime - its the biggest contributor to
> KSPSolve() for your run.
> Its easy to get lost in the details of log_summary. Looking for
> anamolies is one thing. Plotting scalability charts for the solver is
> something else..
>> In summary, due to load imbalance, my speedup is quite bad. So maybe I'll just
>> send your results to my school's engineer and see if they could do anything.
>> For my part, I guess I'll just 've to wait?
> Yes - load imbalance at MatMult level is bad. On 4 proc run you have
> ratio = 3.6 . This implies - there is one of the mpi-tasks is 3.6
> times slower than the other task [so all speedup is lost here]
> You could try the latest mpich2 [1.0.7] - just for this SMP
> experiment, and see if it makes a difference. I've built mpich2 with
> [default gcc/gfortran and]:
> ./configure --with-device=ch3:nemesis:newtcp -with-pm=gforker
> There could be something else going on on this machine thats messing
> up load-balance for basic petsc example..
> Satish
