Slow speed after changing from serial to parallel
Ben Tay zonexo at gmail.com
Tue Apr 15 10:56:52 CDT 2008
Oh sorry here's the whole information. I'm using 2 processors currently:
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
-fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance
Summary: ----------------------------------------------
./a.out on a atlas3-mp named atlas3-c05 with 2 processors, by g0306332
Tue Apr 15 23:03:09 2008
Using Petsc Release Version 2.3.3, Patch 8, Fri Nov 16 17:03:40 CST 2007
HG revision: 414581156e67e55c761739b0deb119f7590d0f4b
                         Max       Max/Min        Avg      Total
Time (sec):           1.114e+03      1.00054   1.114e+03
Objects:              5.400e+01      1.00000   5.400e+01
Flops:                1.574e+11      1.00000   1.574e+11  3.147e+11
Flops/sec:            1.414e+08      1.00054   1.413e+08  2.826e+08
MPI Messages:         8.777e+03      1.00000   8.777e+03  1.755e+04
MPI Message Lengths:  4.213e+07      1.00000   4.800e+03  8.425e+07
MPI Reductions:       8.644e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N
--> 2N flops
                            and VecAXPY() for complex vectors of length
N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts
%Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.1136e+03 100.0%  3.1475e+11 100.0%  1.755e+04
100.0%  4.800e+03      100.0%  1.729e+04 100.0%
See the 'Profiling' chapter of the users' manual for details on
interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops/sec: Max - maximum over all processors
                       Ratio - ratio of maximum to minimum over all
processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush()
and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this
phase
      %M - percent messages in this phase     %L - percent message
lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
      #                          WARNING!!!                    #
      #   This code was run without the PreLoadBegin()         #
      #   macros. To get timing results we always recommend    #
      #   preloading. otherwise timing numbers may be          #
      #   meaningless.                                         #
Event                Count      Time (sec)
Flops/sec                         --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
MatMult             8776 1.0 1.5701e+02 2.2 2.43e+08 2.2 1.8e+04 4.8e+03
0.0e+00 10 11100100  0  10 11100100  0   217
MatSolve            8777 1.0 2.8379e+02 2.9 1.73e+08 2.9 0.0e+00 0.0e+00
0.0e+00 17 11  0  0  0  17 11  0  0  0   120
MatLUFactorNum         1 1.0 2.7618e-02 1.2 8.68e+07 1.2 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   140
MatILUFactorSym        1 1.0 2.4259e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
1.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin       1 1.0 5.6334e+01853005.4 0.00e+00 0.0 0.0e+00
0.0e+00 2.0e+00  3  0  0  0  0   3  0  0  0  0     0
MatAssemblyEnd         1 1.0 4.7958e-02 1.0 0.00e+00 0.0 2.0e+00 2.4e+03
7.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 1.0 3.0994e-06 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 3.8640e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
2.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         1 1.0 1.8353e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
KSPGMRESOrthog      8493 1.0 6.2636e+02 1.3 2.32e+08 1.3 0.0e+00 0.0e+00
8.5e+03 50 72  0  0 49  50 72  0  0 49   363
KSPSetup               2 1.0 1.0490e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve               1 1.0 9.9177e+02 1.0 1.59e+08 1.0 1.8e+04 4.8e+03
1.7e+04 89100100100100  89100100100100   317
PCSetUp                2 1.0 5.5893e-02 1.2 4.02e+07 1.2 0.0e+00 0.0e+00
3.0e+00  0  0  0  0  0   0  0  0  0  0    69
PCSetUpOnBlocks        1 1.0 5.5777e-02 1.2 4.03e+07 1.2 0.0e+00 0.0e+00
PCApply             8777 1.0 2.9987e+02 2.9 1.63e+08 2.9 0.0e+00 0.0e+00
0.0e+00 18 11  0  0  0  18 11  0  0  0   114
VecMDot             8493 1.0 5.3381e+02 2.2 2.36e+08 2.2 0.0e+00 0.0e+00
8.5e+03 35 36  0  0 49  35 36  0  0 49   213
VecNorm             8777 1.0 1.8237e+0210.2 2.13e+0810.2 0.0e+00 0.0e+00
8.8e+03  9  2  0  0 51   9  2  0  0 51    42
VecScale            8777 1.0 5.9594e+00 4.7 1.49e+09 4.7 0.0e+00 0.0e+00
0.0e+00  0  1  0  0  0   0  1  0  0  0   636
VecCopy              284 1.0 4.2563e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet              9062 1.0 1.5833e+01 2.6 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY              567 1.0 1.4142e+00 2.8 4.90e+08 2.8 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   346
VecMAXPY            8777 1.0 2.6692e+02 2.7 6.15e+08 2.7 0.0e+00 0.0e+00
0.0e+00 16 38  0  0  0  16 38  0  0  0   453
VecAssemblyBegin       2 1.0 1.6093e-04 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
6.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         2 1.0 4.7684e-06 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterBegin     8776 1.0 6.6898e-01 6.7 0.00e+00 0.0 1.8e+04 4.8e+03
0.0e+00  0  0100100  0   0  0100100  0     0
VecScatterEnd       8776 1.0 1.7747e+0130.1 0.00e+00 0.0 0.0e+00 0.0e+00
VecNormalize        8777 1.0 1.8366e+02 7.7 2.39e+08 7.7 0.0e+00 0.0e+00
8.8e+03  9  4  0  0 51   9  4  0  0 51    62
Memory usage is given in bytes:
Object Type          Creations   Destructions   Memory  Descendants' Mem.
              Matrix     4              4   49227380     0
       Krylov Solver     2              2      17216     0
      Preconditioner     2              2        256     0
           Index Set     5              5    2596120     0
                 Vec    40             40   62243224     0
         Vec Scatter     1              1          0     0
Average time to get PetscTime(): 4.05312e-07
Average time for MPI_Barrier(): 7.62939e-07
Average time for zero size MPI_Send(): 2.02656e-06
OptionTable: -log_summary
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8
Configure run at: Tue Jan  8 22:22:08 2008
Configure options: --with-memcmp-ok --sizeof_char=1 --sizeof_void_p=8
--sizeof_short=2 --sizeof_int=4 --sizeof_long=8 --sizeof_long_long=8
--sizeof_float=4 --sizeof_double=8 --bits_per_byte=8 --sizeof_MPI_Comm=4
--sizeof_MPI_Fint=4 --with-vendor-compilers=intel --with-x=0
--with-hypre-dir=/home/enduser/g0306332/lib/hypre --with-debugging=0
--with-batch=1 --with-mpi-shared=0
--with-mpi-include=/usr/local/topspin/mpi/mpich/include
--with-mpi-lib=/usr/local/topspin/mpi/mpich/lib/libmpich.a
--with-mpirun=/usr/local/topspin/mpi/mpich/bin/mpirun
--with-blas-lapack-dir=/opt/intel/cmkl/8.1.1/lib/em64t --with-shared=0
Libraries compiled on Tue Jan  8 22:34:13 SGT 2008 on atlas3-c01
Machine characteristics: Linux atlas3-c01 2.6.9-42.ELsmp #1 SMP Wed Jul
12 23:32:02 EDT 2006 x86_64 x86_64 x86_64 GNU/Linux
Using PETSc directory: /nfs/home/enduser/g0306332/petsc-2.3.3-p8
Using PETSc arch: atlas3-mpi
Using C compiler: mpicc -fPIC -O
Using Fortran compiler: mpif90 -I. -fPIC -O
Using include paths: -I/nfs/home/enduser/g0306332/petsc-2.3.3-p8
-I/nfs/home/enduser/g0306332/petsc-2.3.3-p8/bmake/atlas3-mpi
-I/nfs/home/enduser/g0306332/petsc-2.3.3-p8/include -
I/home/enduser/g0306332/lib/hypre/include
-I/usr/local/topspin/mpi/mpich/include
Using C linker: mpicc -fPIC -O
Using Fortran linker: mpif90 -I. -fPIC -O
Using libraries:
-Wl,-rpath,/nfs/home/enduser/g0306332/petsc-2.3.3-p8/lib/atlas3-mpi
-L/nfs/home/enduser/g0306332/petsc-2.3.3-p8/lib/atlas3-mpi -lpetscts
-lpetscsnes -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc
-Wl,-rpath,/home/enduser/g0306332/lib/hypre/lib
-L/home/enduser/g0306332/lib/hypre/lib -lHYPRE
-Wl,-rpath,/opt/mvapich/0.9.9/gen2/lib -Wl,-rpath,/usr/local/ofed/lib64
-Wl,-rpath,/opt/intel/cce/9.1.049/lib
-Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/3.4.6/ -Wl,-rpath,/usr/lib64
-lstdc++ -lcxaguard -Wl,-rpath,/opt/mvapich/0.9.9/gen2/lib
-Wl,-rpath,/usr/local/ofed/lib64 -Wl,-rpath,/opt/intel/cce/9.1.049/lib
-Wl,-rpath,/usr/local/topspin/mpi/mpich/lib
-L/usr/local/topspin/mpi/mpich/lib -lmpich
-Wl,-rpath,/opt/intel/cmkl/8.1.1/lib/em64t
-L/opt/intel/cmkl/8.1.1/lib/em64t -lmkl_lapack -lmkl_em64t -lguide
-lpthread -Wl,-rpath,/usr/local/ofed/lib64 -L/usr/local/ofed/lib64
-Wl,-rpath,/opt/mvapich/0.9.9/gen2/lib -L/opt/mvapich/0.9.9/gen2/lib
-ldl -lmpich -libverbs -libumad -lpthread -lrt
-Wl,-rpath,/opt/intel/cce/9.1.049/lib -L/opt/intel/cce/9.1.049/lib
-L/usr/lib/gcc/x86_64-redhat-linux/3.4.6/ -Wl,-rpath,/usr/lib64
-L/usr/lib64 -lsvml -limf -lipgo -lirc -lgcc_s -lirc_s -lmpichf90nc
-Wl,-rpath,/opt/intel/fce/9.1.045/lib -L/opt/intel/fce/9.1.045/lib
-lifport -lifcore -lm -Wl,-rpath,/opt/mvapich/0.9.9/gen2/lib
-ldl -lmpich -Wl,-rpath,/usr/local/ofed/lib64 -L/usr/local/ofed/lib64
-libverbs -libumad -lpthread -lrt -Wl,-rpath,/opt/intel/cce/9.1.049/lib
-L/usr/lib64 -lsvml -limf -lipgo -lirc -lgcc_s -lirc_s -ldl -lc
1079.77user 0.79system 18:34.82elapsed 96%CPU (0avgtext+0avgdata
0maxresident)k
0inputs+0outputs (28major+153248minor)pagefaults 0swaps
387.76user 3.95system 18:34.77elapsed 35%CPU (0avgtext+0avgdata
0maxresident)k
0inputs+0outputs (18major+158175minor)pagefaults 0swaps
Job  /usr/lsf62/bin/mvapich_wrapper time ./a.out -log_summary
TID   HOST_NAME   COMMAND_LINE            STATUS            TERMINATION_TIME
00000 atlas3-c05 time ./a.out -lo  Done                     04/15/2008
23:03:10
00001 atlas3-c05 time ./a.out -lo  Done                     04/15/2008
23:03:10
I have a cartesian grid 600x720. Since there's 2 processors, it is
partitioned to 600x360. I just use:
call
MatCreateMPIAIJ(MPI_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,total_k,total_k,5,PETSC_NULL_INTEGER,5,PETSC_NULL_INTEGER,A_mat,ierr)
        call MatSetFromOptions(A_mat,ierr)
        call MatGetOwnershipRange(A_mat,ksta_p,kend_p,ierr)
        call KSPCreate(MPI_COMM_WORLD,ksp,ierr)
        call
VecCreateMPI(MPI_COMM_WORLD,PETSC_DECIDE,size_x*size_y,b_rhs,ierr)
total_k is actually size_x*size_y. Since it's 2d, the maximum values per
row is 5. When you says setting off-process values, do you mean I insert
values from 1 processor into another? I thought I insert the values into
the correct processor...
Thank you very much!
Matthew Knepley wrote:
> 1) Please never cut out parts of the summary. All the information is valuable,
>     and most times, necessary
> 2) You seem to have huge load imbalance (look at VecNorm). Do you partition
>     the system yourself. How many processes is this?
> 3) You seem to be setting a huge number of off-process values in the matrix
>     (see MatAssemblyBegin). Is this true? I would reorganize this part.
>   Matt
> On Tue, Apr 15, 2008 at 10:33 AM, Ben Tay <zonexo at gmail.com> wrote:
>> Hi,
>>  I have converted the poisson eqn part of the CFD code to parallel. The grid
>> size tested is 600x720. For the momentum eqn, I used another serial linear
>> solver (nspcg) to prevent mixing of results. Here's the output summary:
>>  *MatAssemblyBegin       1 1.0 5.6334e+01853005.4 0.00e+00 0.0 0.0e+00
>> 0.0e+00 2.0e+00  3  0  0  0  0   3  0  0  0  0     0*
>>  *VecNorm             8777 1.0 1.8237e+0210.2 2.13e+0810.2 0.0e+00 0.0e+00
>> 8.8e+03  9  2  0  0 51   9  2  0  0 51    42*
>>  *VecScale            8777 1.0 5.9594e+00 4.7 1.49e+09 4.7 0.0e+00 0.0e+00
>> 0.0e+00  0  1  0  0  0   0  1  0  0  0   636*
>>  *VecScatterBegin     8776 1.0 6.6898e-01 6.7 0.00e+00 0.0 1.8e+04 4.8e+03
>> 0.0e+00  0  0100100  0   0  0100100  0     0*
>>  *VecScatterEnd       8776 1.0 1.7747e+0130.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0*
>>  *VecNormalize        8777 1.0 1.8366e+02 7.7 2.39e+08 7.7 0.0e+00 0.0e+00
>> 8.8e+03  9  4  0  0 51   9  4  0  0 51    62*
>>         Vec Scatter     1              1          0     0
>>  Average time to get PetscTime(): 4.05312e-07                  Average time
>>  The PETSc manual states that ratio should be close to 1. There's quite a
>> few *(in bold)* which are >1 and MatAssemblyBegin seems to be very big. So
>> what could be the cause?
>>  I wonder if it has to do the way I insert the matrix. My steps are:
>> (cartesian grids, i loop faster than j, fortran)
>>  For matrix A and rhs
>>  Insert left extreme cells values belonging to myid
>>  if (myid==0) then
>>    insert corner cells values
>>    insert south cells values
>>    insert internal cells values
>>  else if (myid==num_procs-1) then
>>    insert north cells values
>>  else
>>  end if
>>  Insert right extreme cells values belonging to myid
>>  All these values are entered into a big_A(size_x*size_y,5) matrix. int_A
>> stores the position of the values. I then do
>>  call MatZeroEntries(A_mat,ierr)
>>    do k=ksta_p+1,kend_p   !for cells belonging to myid
>>        do kk=1,5
>>            II=k-1
>>            JJ=int_A(k,kk)-1
>>            call MatSetValues(A_mat,1,II,1,JJ,big_A(k,kk),ADD_VALUES,ierr)
>>                  end do
>>    end do
>>    call MatAssemblyBegin(A_mat,MAT_FINAL_ASSEMBLY,ierr)
>>    call MatAssemblyEnd(A_mat,MAT_FINAL_ASSEMBLY,ierr)
>>  I wonder if the problem lies here.I used the big_A matrix because I was
>> migrating from an old linear solver. Lastly, I was told to widen my window
>> to 120 characters. May I know how do I do it?
>>  Thank you very much.
>>> On Mon, Apr 14, 2008 at 8:43 AM, Ben Tay <zonexo at gmail.com> wrote:
>>>> Hi Matthew,
>>>>  I think you've misunderstood what I meant. What I'm trying to say is
>>>> initially I've got a serial code. I tried to convert to a parallel one.
>> Then
>>>> I tested it and it was pretty slow. Due to some work requirement, I need
>> to
>>>> go back to make some changes to my code. Since the parallel is not
>> working
>>>> well, I updated and changed the serial one.
>>>>  Well, that was a while ago and now, due to the updates and changes, the
>>>> serial code is different from the old converted parallel code. Some
>> files
>>>> were also deleted and I can't seem to get it working now. So I thought I
>>>> might as well convert the new serial code to parallel. But I'm not very
>> sure
>>>> what I should do 1st.
>>>>  Maybe I should rephrase my question in that if I just convert my
>> poisson
>>>> equation subroutine from a serial PETSc to a parallel PETSc version,
>> will it
>>>> work? Should I expect a speedup? The rest of my code is still serial.
>>> You should, of course, only expect speedup in the parallel parts
>>>  Matt
>>>>> I am not sure why you would ever have two codes. I never do this.
>> PETSc
>>>>> is designed to write one code to run in serial and parallel. The PETSc
>>>> part
>>>>> should look identical. To test, run the code yo uhave verified in
>> serial
>>>> and
>>>>> output PETSc data structures (like Mat and Vec) using a binary viewer.
>>>>> Then run in parallel with the same code, which will output the same
>>>>> structures. Take the two files and write a small verification code
>> that
>>>>> loads both versions and calls MatEqual and VecEqual.
>>>>>  Matt
>>>>> On Mon, Apr 14, 2008 at 5:49 AM, Ben Tay <zonexo at gmail.com> wrote:
>>>>>> Thank you Matthew. Sorry to trouble you again.
>>>>>>  I tried to run it with -log_summary output and I found that there's
>>>> some
>>>>>> errors in the execution. Well, I was busy with other things and I
>> just
>>>> came
>>>>>> back to this problem. Some of my files on the server has also been
>>>> deleted.
>>>>>> It has been a while and I  remember that  it worked before, only
>> much
>>>>>> slower.
>>>>>>  Anyway, most of the serial code has been updated and maybe it's
>> easier
>>>> to
>>>>>> convert the new serial code instead of debugging on the old parallel
>>>> code
>>>>>> now. I believe I can still reuse part of the old parallel code.
>> However,
>>>> I
>>>>>> hope I can approach it better this time.
>>>>>>  So supposed I need to start converting my new serial code to
>> parallel.
>>>>>> There's 2 eqns to be solved using PETSc, the momentum and poisson. I
>>>> also
>>>>>> need to parallelize other parts of my code. I wonder which route is
>> the
>>>>>> best:
>>>>>>  1. Don't change the PETSc part ie continue using PETSC_COMM_SELF,
>>>> modify
>>>>>> other parts of my code to parallel e.g. looping, updating of values
>> etc.
>>>>>> Once the execution is fine and speedup is reasonable, then modify
>> the
>>>> PETSc
>>>>>> part - poisson eqn 1st followed by the momentum eqn.
>>>>>>  2. Reverse the above order ie modify the PETSc part - poisson eqn
>> 1st
>>>>>> followed by the momentum eqn. Then do other parts of my code.
>>>>>>  I'm not sure if the above 2 mtds can work or if there will be
>>>> conflicts. Of
>>>>>> course, an alternative will be:
>>>>>>  3. Do the poisson, momentum eqns and other parts of the code
>>>> separately.
>>>>>> That is, code a standalone parallel poisson eqn and use samples
>> values
>>>> to
>>>>>> test it. Same for the momentum and other parts of the code. When
>> each of
>>>>>> them is working, combine them to form the full parallel code.
>> However,
>>>> this
>>>>>> will be much more troublesome.
>>>>>>  I hope someone can give me some recommendations.
>>>>>>  Thank you once again.
>>>>>>> 1) There is no way to have any idea what is going on in your code
>>>>>>>  without -log_summary output
>>>>>>> 2) Looking at that output, look at the percentage taken by the
>> solver
>>>>>>>  KSPSolve event. I suspect it is not the biggest component,
>> because
>>>>>>>  it is very scalable.
>>>>>>>  Matt
>>>>>>> On Sun, Apr 13, 2008 at 4:12 AM, Ben Tay <zonexo at gmail.com> wrote:
>>>>>>>> Hi,
>>>>>>>> I've a serial 2D CFD code. As my grid size requirement
>> increases,
>>>> the
>>>>>>>> simulation takes longer. Also, memory requirement becomes a
>> problem.
>>>>>> Grid
>>>>>>>> size 've reached 1200x1200. Going higher is not possible due to
>>>> memory
>>>>>>>> problem.
>>>>>>>> I tried to convert my code to a parallel one, following the
>> examples
>>>>>> given.
>>>>>>>> I also need to restructure parts of my code to enable parallel
>>>> looping.
>>>>>> I
>>>>>>>> 1st changed the PETSc solver to be parallel enabled and then I
>>>>>> restructured
>>>>>>>> parts of my code. I proceed on as longer as the answer for a
>> simple
>>>> test
>>>>>>>> case is correct. I thought it's not really possible to do any
>> speed
>>>>>> testing
>>>>>>>> since the code is not fully parallelized yet. When I finished
>> during
>>>>>> most of
>>>>>>>> the conversion, I found that in the actual run that it is much
>>>> slower,
>>>>>>>> although the answer is correct.
>>>>>>>> So what is the remedy now? I wonder what I should do to check
>> what's
>>>>>> wrong.
>>>>>>>> Must I restart everything again? Btw, my grid size is 1200x1200.
>> I
>>>>>> believed
>>>>>>>> it should be suitable for parallel run of 4 processors? Is that
>> so?
>>>>>>>> Thank you.
