Slow speed after changing from serial to parallel
Ben Tay zonexo at gmail.com
Tue Apr 15 10:33:20 CDT 2008
I have converted the poisson eqn part of the CFD code to parallel. The
grid size tested is 600x720. For the momentum eqn, I used another serial
linear solver (nspcg) to prevent mixing of results. Here's the output
summary:
--- Event Stage 0: Main Stage
MatMult             8776 1.0 1.5701e+02 2.2 2.43e+08 2.2 1.8e+04 4.8e+03
0.0e+00 10 11100100  0  10 11100100  0   217
MatSolve            8777 1.0 2.8379e+02 2.9 1.73e+08 2.9 0.0e+00 0.0e+00
0.0e+00 17 11  0  0  0  17 11  0  0  0   120
MatLUFactorNum         1 1.0 2.7618e-02 1.2 8.68e+07 1.2 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   140
MatILUFactorSym        1 1.0 2.4259e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
1.0e+00  0  0  0  0  0   0  0  0  0  0     0
*MatAssemblyBegin       1 1.0 5.6334e+01853005.4 0.00e+00 0.0 0.0e+00
0.0e+00 2.0e+00  3  0  0  0  0   3  0  0  0  0     0*
MatAssemblyEnd         1 1.0 4.7958e-02 1.0 0.00e+00 0.0 2.0e+00 2.4e+03
7.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 1.0 3.0994e-06 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 3.8640e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
2.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         1 1.0 1.8353e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
KSPGMRESOrthog      8493 1.0 6.2636e+02 1.3 2.32e+08 1.3 0.0e+00 0.0e+00
8.5e+03 50 72  0  0 49  50 72  0  0 49   363
KSPSetup               2 1.0 1.0490e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve               1 1.0 9.9177e+02 1.0 1.59e+08 1.0 1.8e+04 4.8e+03
1.7e+04 89100100100100  89100100100100   317
PCSetUp                2 1.0 5.5893e-02 1.2 4.02e+07 1.2 0.0e+00 0.0e+00
3.0e+00  0  0  0  0  0   0  0  0  0  0    69
PCSetUpOnBlocks        1 1.0 5.5777e-02 1.2 4.03e+07 1.2 0.0e+00 0.0e+00
PCApply             8777 1.0 2.9987e+02 2.9 1.63e+08 2.9 0.0e+00 0.0e+00
0.0e+00 18 11  0  0  0  18 11  0  0  0   114
VecMDot             8493 1.0 5.3381e+02 2.2 2.36e+08 2.2 0.0e+00 0.0e+00
8.5e+03 35 36  0  0 49  35 36  0  0 49   213
*VecNorm             8777 1.0 1.8237e+0210.2 2.13e+0810.2 0.0e+00
0.0e+00 8.8e+03  9  2  0  0 51   9  2  0  0 51    42*
*VecScale            8777 1.0 5.9594e+00 4.7 1.49e+09 4.7 0.0e+00
0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   636*
VecCopy              284 1.0 4.2563e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet              9062 1.0 1.5833e+01 2.6 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY              567 1.0 1.4142e+00 2.8 4.90e+08 2.8 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   346
VecMAXPY            8777 1.0 2.6692e+02 2.7 6.15e+08 2.7 0.0e+00 0.0e+00
0.0e+00 16 38  0  0  0  16 38  0  0  0   453
VecAssemblyBegin       2 1.0 1.6093e-04 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
6.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         2 1.0 4.7684e-06 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
*VecScatterBegin     8776 1.0 6.6898e-01 6.7 0.00e+00 0.0 1.8e+04
4.8e+03 0.0e+00  0  0100100  0   0  0100100  0     0*
*VecScatterEnd       8776 1.0 1.7747e+0130.1 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0*
*VecNormalize        8777 1.0 1.8366e+02 7.7 2.39e+08 7.7 0.0e+00
0.0e+00 8.8e+03  9  4  0  0 51   9  4  0  0 51    62*
Memory usage is given in bytes:
Object Type          Creations   Destructions   Memory  Descendants' Mem.
              Matrix     4              4   49227380     0
       Krylov Solver     2              2      17216     0
      Preconditioner     2              2        256     0
           Index Set     5              5    2596120     0
                 Vec    40             40   62243224     0
         Vec Scatter     1              1          0     0
Average time to get PetscTime(): 4.05312e-07
Average time for MPI_Barrier(): 7.62939e-07
Average time for zero size MPI_Send(): 2.02656e-06
OptionTable: -log_summary
The PETSc manual states that ratio should be close to 1. There's quite a
few *(in bold)* which are >1 and MatAssemblyBegin seems to be very big.
So what could be the cause?
I wonder if it has to do the way I insert the matrix. My steps are:
(cartesian grids, i loop faster than j, fortran)
For matrix A and rhs
Insert left extreme cells values belonging to myid
if (myid==0) then
    insert corner cells values
    insert south cells values
    insert internal cells values
else if (myid==num_procs-1) then
    insert north cells values
else
end if
Insert right extreme cells values belonging to myid
All these values are entered into a big_A(size_x*size_y,5) matrix. int_A
stores the position of the values. I then do
call MatZeroEntries(A_mat,ierr)
    do k=ksta_p+1,kend_p   !for cells belonging to myid
        do kk=1,5
            II=k-1
            JJ=int_A(k,kk)-1
            call MatSetValues(A_mat,1,II,1,JJ,big_A(k,kk),ADD_VALUES,ierr)
        end do
    end do
    call MatAssemblyBegin(A_mat,MAT_FINAL_ASSEMBLY,ierr)
    call MatAssemblyEnd(A_mat,MAT_FINAL_ASSEMBLY,ierr)
I wonder if the problem lies here.I used the big_A matrix because I was
migrating from an old linear solver. Lastly, I was told to widen my
window to 120 characters. May I know how do I do it?
Thank you very much.
Matthew Knepley wrote:
> On Mon, Apr 14, 2008 at 8:43 AM, Ben Tay <zonexo at gmail.com> wrote:
>> Hi Matthew,
>>  I think you've misunderstood what I meant. What I'm trying to say is
>> initially I've got a serial code. I tried to convert to a parallel one. Then
>> I tested it and it was pretty slow. Due to some work requirement, I need to
>> go back to make some changes to my code. Since the parallel is not working
>> well, I updated and changed the serial one.
>>  Well, that was a while ago and now, due to the updates and changes, the
>> serial code is different from the old converted parallel code. Some files
>> were also deleted and I can't seem to get it working now. So I thought I
>> might as well convert the new serial code to parallel. But I'm not very sure
>> what I should do 1st.
>>  Maybe I should rephrase my question in that if I just convert my poisson
>> equation subroutine from a serial PETSc to a parallel PETSc version, will it
>> work? Should I expect a speedup? The rest of my code is still serial.
> You should, of course, only expect speedup in the parallel parts
>   Matt
>>> I am not sure why you would ever have two codes. I never do this. PETSc
>>> is designed to write one code to run in serial and parallel. The PETSc
>> part
>>> should look identical. To test, run the code yo uhave verified in serial
>> and
>>> output PETSc data structures (like Mat and Vec) using a binary viewer.
>>> Then run in parallel with the same code, which will output the same
>>> structures. Take the two files and write a small verification code that
>>> loads both versions and calls MatEqual and VecEqual.
>>>  Matt
>>> On Mon, Apr 14, 2008 at 5:49 AM, Ben Tay <zonexo at gmail.com> wrote:
>>>> Thank you Matthew. Sorry to trouble you again.
>>>>  I tried to run it with -log_summary output and I found that there's
>> some
>>>> errors in the execution. Well, I was busy with other things and I just
>> came
>>>> back to this problem. Some of my files on the server has also been
>> deleted.
>>>> It has been a while and I  remember that  it worked before, only much
>>>> slower.
>>>>  Anyway, most of the serial code has been updated and maybe it's easier
>> to
>>>> convert the new serial code instead of debugging on the old parallel
>> code
>>>> now. I believe I can still reuse part of the old parallel code. However,
>> I
>>>> hope I can approach it better this time.
>>>>  So supposed I need to start converting my new serial code to parallel.
>>>> There's 2 eqns to be solved using PETSc, the momentum and poisson. I
>> also
>>>> need to parallelize other parts of my code. I wonder which route is the
>>>> best:
>>>>  1. Don't change the PETSc part ie continue using PETSC_COMM_SELF,
>> modify
>>>> other parts of my code to parallel e.g. looping, updating of values etc.
>>>> Once the execution is fine and speedup is reasonable, then modify the
>> PETSc
>>>> part - poisson eqn 1st followed by the momentum eqn.
>>>>  2. Reverse the above order ie modify the PETSc part - poisson eqn 1st
>>>> followed by the momentum eqn. Then do other parts of my code.
>>>>  I'm not sure if the above 2 mtds can work or if there will be
>> conflicts. Of
>>>> course, an alternative will be:
>>>>  3. Do the poisson, momentum eqns and other parts of the code
>> separately.
>>>> That is, code a standalone parallel poisson eqn and use samples values
>> to
>>>> test it. Same for the momentum and other parts of the code. When each of
>>>> them is working, combine them to form the full parallel code. However,
>> this
>>>> will be much more troublesome.
>>>>  I hope someone can give me some recommendations.
>>>>  Thank you once again.
>>>>> 1) There is no way to have any idea what is going on in your code
>>>>>   without -log_summary output
>>>>> 2) Looking at that output, look at the percentage taken by the solver
>>>>>   KSPSolve event. I suspect it is not the biggest component, because
>>>>>  it is very scalable.
>>>>>  Matt
>>>>> On Sun, Apr 13, 2008 at 4:12 AM, Ben Tay <zonexo at gmail.com> wrote:
>>>>>> Hi,
>>>>>> I've a serial 2D CFD code. As my grid size requirement increases,
>> the
>>>>>> simulation takes longer. Also, memory requirement becomes a problem.
>>>> Grid
>>>>>> size 've reached 1200x1200. Going higher is not possible due to
>> memory
>>>>>> problem.
>>>>>> I tried to convert my code to a parallel one, following the examples
>>>> given.
>>>>>> I also need to restructure parts of my code to enable parallel
>> looping.
>>>> I
>>>>>> 1st changed the PETSc solver to be parallel enabled and then I
>>>> restructured
>>>>>> parts of my code. I proceed on as longer as the answer for a simple
>> test
>>>>>> case is correct. I thought it's not really possible to do any speed
>>>> testing
>>>>>> since the code is not fully parallelized yet. When I finished during
>>>> most of
>>>>>> the conversion, I found that in the actual run that it is much
>> slower,
>>>>>> although the answer is correct.
>>>>>> So what is the remedy now? I wonder what I should do to check what's
>>>> wrong.
>>>>>> Must I restart everything again? Btw, my grid size is 1200x1200. I
>>>> believed
>>>>>> it should be suitable for parallel run of 4 processors? Is that so?
>>>>>> Thank you.
