Further question about PC with Jaocbi Row Sum
Fri Apr 11 16:04:54 CDT 2008
On Fri, Apr 11, 2008 at 3:56 PM, Shi Jin <jinzishuai at yahoo.com> wrote:
> Thank you.
>  Suppose I have a diagonal matrix, what is the best way to invert it in PETSc?
If you have a diagonal matrix, you just use -ksp_type preonly -pc_type jacobi
   Matt
>  Do I have to install the external packages superlu_dist or mumps?
>  I realized that LU or Cholesky decomposition does not work with MPIAIJ matrices.
>  I also know the best way is probably to directly call Vector operations directly.
>  However, I want to keep the same KSPSolve structure so that the same code can be used  for non-diagonal MPIAIJ matrices without changing each call to KSPSolve.
>  Thank you very much.
>  Shi
>  > Then you may try direct sparse linear solver,
>  > sequential run:
>  > -ksp_type preonly -pc_type cholesky
>  > parallel run (install external packages superlu_dist or mumps):
>  > -ksp_type preonly -pc_type lu -mat_type superlu_dist
>  > or
>  > -ksp_type preonly -pc_type cholesky -mat_type sbaijmumps
>  > Hong
>  __________________________________________________
>  Do You Yahoo!?
>  Tired of spam?  Yahoo! Mail has the best spam protection around
>  http://mail.yahoo.com
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
