DA question
Amit.Itagi at seagate.com Amit.Itagi at seagate.com
Thu Apr 10 08:10:34 CDT 2008
Randy/Sean/Matt,
Thanks for the suggestions. I will try to implement the algorithm on the
suggested lines.
Rgds,
Amit
             Randall Mackie
             <rlmackie862 at gmai
             l.com>                                                     To
             Sent by:                  petsc-users at mcs.anl.gov
             owner-petsc-users                                          cc
             @mcs.anl.gov
             No Phone Info                                         Subject
             Available                 Re: DA question
             04/09/2008 06:44
             PM
             Please respond to
                  nl.gov
Amit,
I have a staggered grid with H defined along the edges and E as normals
across the block faces. So if you have l x m x n blocks, then you need
to define your DA as l+1, m+1, n+1, to handle the extra grid point you
need for the staggered grid. I use 3 degrees of freedom (for Hx, Hy, and
Hz), and all my local calculations just need the box stencil.
Randy
Sean Dettrick wrote:
> To elaborate on Matt's suggestion, a staggered grid/Yee mesh code
> could use a single DA with one degree-of-freedom per component of H
> and E.  The extra overlap required for staggered guard cells at the
> domain boundaries could be dealt with by having a bigger-than-usual
> stencil width.  For the 2nd order 3D case, this suggests the
> DACreate3d routine would have arguments dof=6, s=2, and
> stencil_type=DA_STENCIL_STAR.
> It is just a suggestion - I have not tried it.
> Sean
> On Wed, Apr 9, 2008 at 5:06 PM,  <Amit.Itagi at seagate.com> wrote:
>> Randy,
>>  I guess, since you are doing a frequency domain calculation, you
eventually
>>  end up with a single matrix equation.
>>  I am planning to work in the time domain. Will that change things ?
>>  Thanks
>>  Rgds,
>>  Amit
>>              Randall Mackie
>>              l.com>
To
>>              owner-petsc-users
cc
>>              @mcs.anl.gov
>>              No Phone Info
Subject
>>              04/09/2008 04:09
>>              PM
>>              Please respond to
>>                   nl.gov
>>  Hi Amit,
>>  Why do you need two staggered grids? I do EM finite difference
frequency
>>  domain modeling on a staggered grid using just one DA. Works perfectly
>>  fine.
>>  There are some grid points that are not used, but you just set them to
zero
>>  and put a 1 on the diagonal of the coefficient matrix.
>>  Randy
>>  Amit.Itagi at seagate.com wrote:
>>  > Hi Berend,
>>  > A detailed explanation of the finite difference scheme is given here
>>  > http://en.wikipedia.org/wiki/Finite-difference_time-domain_method
>>  > Thanks
>>  > Rgds,
>>  > Amit
>>  >              Berend van Wachem
>>  >              <berend at chalmers.
>>  >              se>
>>  To
>>  >              owner-petsc-users
>>  cc
>>  >              @mcs.anl.gov
>>  >              No Phone Info
>>  Subject
>>  >              04/09/2008 02:59
>>  >              PM
>>  >              Please respond to
>>  >                   nl.gov
>>  > Dear Amit,
>>  > Could you explain how the two grids are attached?
>>  > I am using multiple DA's for multiple structured grids glued
together.
>>  > I've done the gluing with setting up various IS objects. From the
>>  > multiple DA's, one global variable vector is formed. Is that what you
>>  > are looking for?
>>  > Best regards,
>>  > Berend.
>>  >> Hi,
>>  >> Is it possible to use DA to perform finite differences on two
staggered
>>  >> regular grids (as in the electromagnetic finite difference time
domain
>>  >> method) ? Surrounding nodes from one grid are used to update the
value
>>  in
>>  >> the dual grid. In addition, local manipulations need to be done on
the
>>  >> nodal values.
>>  >> Thanks
>>  >> Rgds,
>>  >> Amit
