matrix inversion
Randall Mackie randy at geosystem.us
Fri Sep 21 09:58:10 CDT 2007
I have a collegue who is considering to use PETSc for programming
his problem. He would like to know if you can get the actual
inverse of a matrix, because this inverse is embedded in another
larger system that is then solved.
I suppose that if you solve the system directly, say with SuperLU
or MUMPS, you could get the actual inverse? I looked briefly through
the manual and documentation, but it didn't jump out at me.
Any advice here?
Thanks, Randy
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
San Francisco, CA 94114-1600
Tel (415) 469-8649
Fax (415) 469-5044
California Registered Geophysicist
License No. GP 1034
