OpenMPI, PETSc and petsc4py in a Mac Intel
Felipe Cruz refac at bristol.ac.uk
Mon Sep 10 10:59:47 CDT 2007
Hi all,
During the past weeks I was trying to install the Python bindings for
PETSc (petsc4py) for
Mac Intel (a black Macbook and an Aluminium iMac, both with OS X
10.4.10)
I succeeded and "how I did it"  might be helpful for some others
Python-PETSc-Mac-Users.
Before to start the installation you'll need to have installed:
* XcodeTools:
It is IMPORTANT to get the latest version directly from Apple's
website (http://connect.apple.com), the version
that comes with the installation CD have some issues (or not so nice
"features".) I recommend to upgrade
your XcodeTools before trying to install anything.
* Python 2.5, Numpy, Scipy (optional - scientific lib) and Matplotlib
(optional -matlab style graphics):
I followed the installation of this packages from: http://
www.scipy.org/Download
I installed MacPython2.5 and the SuperPack. For some reason
Matplotlib didn't work after the installation
of the superpack, so I manually installed it again from: http://
matplotlib.sourceforge.net/
INSTALLATION
I'll describe the whole installation of OpenMPI, PETSc and petsc4py.
OpenMpi
Download OpenMPI source from:
http://www.open-mpi.org/software/ompi/v1.2/
Decompress the downloaded tar.gz file and from a terminal "cd" into
the openMpi folder.
'$' indicates a terminal command, e.g;
$ tar -xzvf openmpi-1.2.3.tar.gz
$ cd openmpi-1.2.3
Now you can compile openmpi
$ ./configure --prefix=/usr/local/openmpi --with-fortran --enable-
shared --disable-static --with-xgrid
$ sudo make
$ sudo make install
Add the next line at the END of /etc/profile, so the path will be
available for all the users:
export PATH=$PATH:/usr/local/openmpi/bin
PETSc
First you need to make sure that OpenMPI is properly installed! check
that
mpicc and mpif77 are in your $PATH before running the PETSc
configure.py!
(if you added the export PATH to /etc/profile you can close your
terminal and
open a new terminal, the PATH should be working now, otherwise, you
can just type
in your terminal:
I installed PETSc on /opt/petsc
$ sudo mkdir /opt
$ sudo mkdir /opt/petsc
Set permissions for user and group.
$ sudo chown user:group /opt/petsc
In my case I added the user 'felipe' and the group 'admin' (sudo
chown felipe:admin /opt/petsc)
Download PETSc from:
http://www-unix.mcs.anl.gov/petsc/petsc-as/download/index.html
Save the downloaded tar.gz on /opt/petsc
Decompress the file
$ cd /opt/petsc
$ tar -xzvf petsc-2.3.3-p5.tar.gz
I installed petscy for shared libraries and without X, beside this
everything is normal:
$ cd petsc-2.3.3-p5
$ export PETSC_ARCH=darwin8.10.1-c-debug
$ export PETSC_DIR=/opt/petsc/petsc-2.3.3-p5
$ ./config/configure.py --with-mpi-dir=/usr/local/openmpi --with-
shared=1 --with-x=0
$ make all test
At the end of /etc/profile add (so it will be available for all the
users):
# variables for petsc
petsc4py
Open a new terminal so the variables PETSC_ARCH and PETSC_DIR will be
available.
I installed petsc4py in /opt/petsc/petsc4py
In a terminal
$ cd /opt/petsc/petsc4py
Get a copy of petsc4py from: http://code.google.com/p/petsc4py/
and save it at /opt/petsc/petsc4py
$ tar -xvf petsc4py-0.7.5.tar
$ cd petsc4py-0.7.5
$ python setup.py install --home=/opt/petsc/petsc4py
# Add at the end of /etc/profile (it will be available for all the
users)
export PYTHONPATH=/opt/petsc/petsc4py/lib/python/
Now is possible to open a new terminal and test petsc4py:
$python
 >>> from petsc4py import PETSc
 >>> A = PETSc.Mat()
 >>> A
 >>> A.createSeqAIJ(1000)
Hope that this info is helpful! I tested the installation in my
MacBook (Dual-core), in an aluminium iMac (Dual-core),
and I hope to test the installation on a Mac pro (with two quad-core)
some time this week!
I'm quite new to the list so I'm sorry if you have already discussed
this topic.
Best regards,
Felipe Cruz
