memory problem at parallel on a linux cluster
Tue Sep 4 12:06:36 CDT 2007
Are you trying to set all the values from a single processor?
  Matt
On 9/4/07, li pan <li76pan at yahoo.com> wrote:
> Dear all,
> I recently installed Petsc on a linux cluster and
> tried to solve a linear equation in parallel way. I
> used 3D Hex mesh. Mesh dimension is 181, 181, 41. The
> number of Dofs are 1343201.
> In serial run, there was no problem. But at parallel
> run, there was memory allocation problem.
> [0]PETSC ERROR: PetscMallocAlign() line 62 in
> src/sys/src/memory/mal.c
> [0]PETSC ERROR: Out of memory. This could be due to
> allocating
> [0]PETSC ERROR: too large an object or bleeding by not
> properly
> [0]PETSC ERROR: destroying unneeded objects.
> [3]PETSC ERROR: MatSetValues() line 702 in
> src/mat/interface/matrix.c
> [3]PETSC ERROR: User provided function() line 312 in
> unknowndirectory/src/numerics/petsc_matrix.C
> [cli_3]: aborting job:
> application called MPI_Abort(comm=0x84000000, 55) -
> process 3
> [0]PETSC ERROR: Memory allocated 865987336 Memory used
> by process 1591005184
> [0]PETSC ERROR: Try running with -malloc_dump or
> -malloc_log for info.
> [0]PETSC ERROR: Memory requested 1310720296!
> [0]PETSC ERROR: PetscTrMallocDefault() line 188 in
> src/sys/src/memory/mtr.c
> [0]PETSC ERROR: MatStashExpand_Private() line 240 in
> src/mat/utils/matstash.c
> [0]PETSC ERROR: MatStashValuesRow_Private() line 276
> in src/mat/utils/matstash.c
> [0]PETSC ERROR: MatSetValues_MPIAIJ() line 199 in
> src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: MatSetValues() line 702 in
> [0]PETSC ERROR: User provided function() line 312 in
> [cli_0]: aborting job:
> process 0
> rank 3 in job 1  hpc16_44261   caused collective abort
> of all ranks
>   exit status of rank 3: return code 55
> I checked memory on all the nodes. Each of them has
> more than  2.5 GB before program starts.
> What could be the reason?
> thanx
> pan
> ____________________________________________________________________________________
> Building a website is a piece of cake. Yahoo! Small Business gives you all the tools to get online.
> http://smallbusiness.yahoo.com/webhosting
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
