Slow assembly
John R. Wicks jwicks at cs.brown.edu
Fri Oct 26 14:49:04 CDT 2007
I have confirmed that I am calling MatSetValues() for local rows only and am
only setting each value exactly once.
Because of how the matrix was partitioned for another non-Petsc program,
each partition is partitioned (by columns) into 32 blocks (corresponding to
the row partitions).  I enter the data for each block one row at a time,
i.e., for any one SetValues call, the entries are sorted by increasing
column index.  Does that mean I can use
MatrixSetOption(A,MAT_COLUMNS_SORTED).  Should that help?
P.S.: I tried it, and it still seems to be taking quite a long time.
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov
> [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: Friday, October 26, 2007 3:04 PM
> To: petsc-users at mcs.anl.gov
> Subject: Re: Slow assembly
> On Fri, 26 Oct 2007, John R. Wicks wrote:
> > I am working on computing PageRank for a web scale graph
> which uses a
> > square matrix which is 1.2x10^8 dimensional with about 10^9
> entries.
> > I have partitioned the matrix for 32 processors myself into my own
> > ascii format, and I know the memory allocation, so I:
> > 1) create the matrix with "A = MatCreateMPIAIJ(*n, *n, *N,
> *N, 0, nnz,
> > 0, onnz)",
> > 2) load the entries by repeatedly calling
> > "MatSetValues(A,1,&row,links,cols,vals,INSERT_VALUES)", and
> > 3) call MatAssemblyBegin/End.
> > Steps 1 and 2 complete in a couple minutes, but step 3 is taking
> > several hours.  What is going on?  Is there a way to speed
> up matrix
> > assembly?
> Are you makeing sure that you call MatGetOwnershipRange() -
> and calling MatSetValues() for mostly local rows only?
> Also can you confirm that multiple processes [for eg: proc-0
> and proc-1 etc..]  are not setting the same value [i.e both
> of them calling MatSetValues(row=0,col=0)]
> Satish
