Invalid argument! - not a permutation!
Tim Stitt timothy.stitt at ichec.ie
Thu Oct 25 14:11:13 CDT 2007
Cheers Matthew...that worked now.
Matthew Knepley wrote:
> I think you need to tell use that the IS is a permutation:
> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/IS/ISSetPermutation.html
>    Matt
> On 10/25/07, Tim Stitt <timothy.stitt at ichec.ie> wrote:
>> Hi all,
>> Following on from some help I got a few days ago with respect to
>> MatLUFactorSymbolic() usage in Fortran...I think I now have all the
>> parts in place but keep getting the following runtime error upon execution:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Invalid argument!
>> [0]PETSC ERROR: not a permutation!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ISInvertPermutation() line 183 in
>> src/vec/is/interface/index.c
>> [0]PETSC ERROR: MatLUFactorSymbolic_SeqAIJ() line 276 in
>> src/mat/impls/aij/seq/aijfact.c
>> [0]PETSC ERROR: MatLUFactorSymbolic() line 2178 in
>> src/mat/interface/matrix.c
>> [localhost.localdomain:24730] MPI_ABORT invoked on rank 0 in
>> communicator MPI_COMM_WORLD with errorcode 62
>> Here is the portion of  the offending code (I think):
>>   call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
>>   call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
>>   call ISCreateGeneral(PETSC_COMM_WORLD,order,columnIndices,
>> indexSet,error);CHKERRQ(error)
>>   call MatFactorInfoInitialize(info,error);CHKERRQ(error)
>>   call
>> MatLUFactorSymbolic(A,indexSet,indexSet,info,factorMat,error);CHKERRQ(error)
>> order - number of rows/columns in square matrix A
>> columnIndices - 1D array containing values 0-->order-1
>> All types are set correctly as far as I can tell.
>> Can anyone suggest why the execution falls over during the
>> MatLUFactorSymbolic() call?
>> Thanks again,
>> Tim.
>> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
>> HPC Application Consultant - ICHEC (www.ichec.ie)
>> Dublin Institute for Advanced Studies
>> 5 Merrion Square - Dublin 2 - Ireland
>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
