Preconditioner for bicg
Thu Oct 11 19:46:50 CDT 2007
[bsmith:~] bsmith% cd Src/petsc-dev/src/ksp/ksp/impls
[bsmith:ksp/ksp/impls] bsmith% grep ApplyTranspose */*.c
bicg/bicg.c:  ierr = KSP_PCApplyTranspose(ksp,Rl,Zl);CHKERRQ(ierr);
[bsmith:ksp/ksp/impls] bsmith% grep ApplyTranspose */*/*.c
cg/cgne/cgne.c:  ierr = PCApplyTransposeExists(ksp->pc,&transpose_pc);CHKERRQ(ierr);
cg/cgne/cgne.c:    ierr = KSP_PCApplyTranspose(ksp,T,Z);CHKERRQ(ierr);
  These are the two methods that require the transpose operation.
  I have documented both of their manual pages to indicate this.
   Barry
On Thu, 11 Oct 2007, Keita Teranishi wrote:
> Hi Barry,
> Could you suggest any other KSP solvers that have the same type of problems?
> Thanks,
>  Keita Teranishi
>  Math Software Group
>  Cray Inc.
>  keita at cray.com
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Barry Smith
> Sent: Thursday, October 11, 2007 4:50 PM
> To: petsc-users at mcs.anl.gov
> Subject: Re: Preconditioner for bicg
>   For some preconditioners it is simply not easily possible to apply the
> transpose of the preconditioner. Even multigrid requires some work to do this.
>    Barry
> > Hi,
> > I'd like to make sure preconditioners supported for bicg. I found bicg only accepts preconditioners that is interfaced through PCApplyTranspose.
> > For this reason, I see several preconditioners fails with bicg.
> > Thanks,
> >  Keita Teranishi
> >  Math Software Group
> >  Cray Inc.
> >  keita at cray.com
