Symbol SNESGetNumberLinearIterations not defined
Wed Oct 10 13:54:41 CDT 2007
On Wed, 10 Oct 2007, Trivedi, Jagruti CIV 470000D, 474300D wrote:
> Thank you. Do you want me to replace this new function for
>  "SNESGetNumberLinearIterations"?.
yes.
> Can you explain why the Changes says, this function
> SNESGetNumberLinearIterations() function is added? I do not want to
> change the interface if possible.
The changes file you are refering to is petsc-2.0.7.
so SNESGetNumberLinearIterations() was added in petsc-2.0.7. This
function is changed to SNESGetLinearSolveIterations() [perhaps in
2.3.3 - but didn't get documented in the changes file for that
version]
Satish
