Petsc Error
Tue Oct 9 10:28:57 CDT 2007
On 10/9/07, Berend van Wachem <berend at chalmers.se> wrote:
> Hi,
> I ran the same command again, running top, and got the result
> Mem:   6220940k total,  5879056k used,   341884k free,   143992k buffers
> Swap:  1951888k total,     2584k used,  1949304k free,  2363516k cached
>    PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
> 19117 berend    25   0 3037m 2.5g 3508 R  100 41.4   0:44.96 MultiFlow
> just before it crashed. I have a 2 processor machine with total 6 GB of
> memory (2 times 3 gb?), so I don't think it should be out of memory. How
> can I verify this for sure?
Run in the debugger and break on mal.c:61. malloc() is returning a null, but
you can look at errno to see if something crazy is happening.
  Matt
> Thanks,
> Berend.
> >> Hi,
> >> On the command
> >>   ierr = DACreateLocalVector(da,g); CHKERRQ(ierr);
> >> I get the error
> >> [0]PETSC ERROR: PetscMallocAlign() line 61 in src/sys/memory/mal.c
> >> Memory requested 6050600
> >> [0]PETSC ERROR: PETSC: Attaching gdb to Debug/MultiFlow of pid 19087 on
> >> display :0.0 on machine tfdpc102
> >> What does it mean exactly? Out of memory?
> > Yes. This is strange. The line above these two should read "Out of memory".
> >   Matt
> >> Thanks,
> >> Berend.
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
