HYPRE with multiple variables
Wed May 9 10:12:36 CDT 2007
  Yes. Make sure you give BoomerAMG enough iterations to
solve the system as accurately as you need with
-pc_hypre_boomeramg_max_iter and -pc_hypre_boomeramg_rtol
   Barry
On Tue, 8 May 2007, Nicolas Bathfield wrote:
> Hi,
> Boomeramg is used as preconditioner, and I use default gmres to solve the
> equations. I did not expect the preconditioner to be used at every
> iteration, but I now understand better what's going on.
> I solve a spase matrix with 5 diagonals.
> I tried to use boomeramg as a solver only. To achieve this, I had to
> comment out the command  ierr = KSPSetInitialGuessNonzero(ksp,PETSC_TRUE),
> and I used the option -ksp_preonly. Is it the right way to do?
> Best regards,
> Nicolas
> > Hi,
> > You mentioned that your preconditioner is boomerAMG. What solver are
> > you using?
> > What type of matrix are you trying to solve? Is it SPD and sparse?
> > Either way, if your solver is not AMG and you are using AMG as a
> > preconditioner, I would suggest that you use a stopping criteria for
> > AMG such as a relative residual convergence of say 1e-03 for the
> > preconditioner, and the solvers relative convergence 1e-05 as in your
> > example, and disregard a stopping criteria which involves maximum
> > number of iterations for AMG, set that to something high. Maybe you
> > will get better results that way. In the end, I guess it is a lot of
> > testing and fine-tuning.
> > With best regards, Shaman Mahmoudi
> > On May 7, 2007, at 4:50 PM, Nicolas Bathfield wrote:
> >> Hi Allison, Barry, and PETSc users,
> >> The nodal relaxation leads to a nice solution! Thanks a lot for
> >> your help
> >> on this!
> >> Even though I get a satisfactory result, I can not explain why
> >> hypre is
> >> performing what looks like several outer loops (see below for an
> >> abstract
> >> of the output from -pc_hypre_boomeramg_print_statistics).
> >> Here is the list of options I used:
> >> -pc_hypre_boomeramg_tol 1e-5
> >> -pc_type hypre -pc_hypre_type boomeramg
> >> -pc_hypre_boomeramg_grid_sweeps_all 20
> >> -pc_hypre_boomeramg_max_iter 6
> >> -pc_hypre_boomeramg_relax_weight_all 0.6
> >> -pc_hypre_boomeramg_outer_relax_weight_all 0.6
> >> -pc_hypre_boomeramg_nodal_coarsen 1
> >> I would expect the preconditioner to be executed once only (in my case
> >> this includes 6 V cycles).
> >> As you can see from the print_statistic option, boomeramg is exectuted
> >> several times (many more times than displyed here, it was too long
> >> to copy
> >> everything). Is this normal? If yes, why is it so?
> >> Best regards,
> >> Nicolas
> >> BoomerAMG SOLVER PARAMETERS:
> >>   Maximum number of cycles:         6
> >>   Stopping Tolerance:               1.000000e-05
> >>   Cycle type (1 = V, 2 = W, etc.):  1
> >>   Relaxation Parameters:
> >>    Visiting Grid:                     down   up  coarse
> >>             Number of partial sweeps:   20   20     1
> >>    Type 0=Jac, 3=hGS, 6=hSGS, 9=GE:      6    6     6
> >>    Point types, partial sweeps (1=C, -1=F):
> >>                   Pre-CG relaxation (down):   1  -1   1  -1   1
> >> -1   1
> >> -1   1  -1   1  -1   1  -1   1  -1   1  -1   1  -1   1
> >> -1   1  -1   1  -1
> >>                    Post-CG relaxation (up):  -1   1  -1   1  -1
> >> 1  -1
> >> 1  -1   1  -1   1  -1   1  -1   1  -1   1  -1   1  -1
> >> 1  -1   1  -1   1
> >>                              Coarsest grid:   0
> >>  Relaxation Weight 0.600000 level 0
> >>  Outer relaxation weight 0.600000 level 0
> >>  Output flag (print_level): 3
> >> AMG SOLUTION INFO:
> >>                                             relative
> >>                residual        factor       residual
> >>     Initial    4.430431e-03                 1.000000e+00
> >>     Cycle  1   4.540275e-03    1.024793     1.024793e+00
> >>     Cycle  2   4.539148e-03    0.999752     1.024539e+00
> >>     Cycle  3   4.620010e-03    1.017814     1.042790e+00
> >>     Cycle  4   5.196532e-03    1.124788     1.172918e+00
> >>     Cycle  5   6.243043e-03    1.201386     1.409128e+00
> >>     Cycle  6   7.310008e-03    1.170905     1.649954e+00
> >>  NOTE: Convergence tolerance was not achieved
> >>       within the allowed 6 V-cycles
> >>  Average Convergence Factor = 1.087039
> >>      Complexity:    grid = 1.000000
> >>                 operator = 1.000000
> >>                    cycle = 1.000000
> >> -1   1
> >> -1   1  -1   1  -1
> >> 1  -1
> >> 1  -1   1  -1   1
> >>                              Coarsest grid:   0
> >> AMG SOLUTION INFO:
> >>                                             relative
> >>     Initial    7.914114e-03                 1.000000e+00
> >>     Cycle  1   8.320104e-03    1.051300     1.051300e+00
> >>     Cycle  2   7.767803e-03    0.933618     9.815126e-01
> >>     Cycle  3   6.570752e-03    0.845896     8.302575e-01
> >>     Cycle  4   5.836166e-03    0.888204     7.374377e-01
> >>     Cycle  5   6.593214e-03    1.129717     8.330956e-01
> >>     Cycle  6   8.191117e-03    1.242356     1.035001e+00
> >>  Average Convergence Factor = 1.005750
> >>                 operator = 1.000000
> >>                    cycle = 1.000000
> >> -1   1
> >> -1   1  -1   1  -1
> >> 1  -1
> >> 1  -1   1  -1   1
> >>                              Coarsest grid:   0
> >> AMG SOLUTION INFO:
> >>                                             relative
> >>     Initial    5.553016e-03                 1.000000e+00
> >>     Cycle  1   6.417482e-03    1.155675     1.155675e+00
> >>     Cycle  2   7.101926e-03    1.106653     1.278931e+00
> >>     Cycle  3   7.077471e-03    0.996556     1.274527e+00
> >>     Cycle  4   6.382835e-03    0.901853     1.149436e+00
> >>     Cycle  5   5.392392e-03    0.844827     9.710744e-01
> >>     Cycle  6   4.674173e-03    0.866809     8.417359e-01
> >>  Average Convergence Factor = 0.971694
> >>                 operator = 1.000000
> >>                    cycle = 1.000000
> >> -1   1
> >> -1   1  -1   1  -1
> >> 1  -1
> >> 1  -1   1  -1   1
> >>                              Coarsest grid:   0
> >> AMG SOLUTION INFO:
> >>                                             relative
> >>     Initial    3.846663e-03                 1.000000e+00
> >>     Cycle  1   4.136662e-03    1.075390     1.075390e+00
> >>     Cycle  2   4.463861e-03    1.079097     1.160450e+00
> >>     Cycle  3   4.302262e-03    0.963798     1.118440e+00
> >>     Cycle  4   4.175328e-03    0.970496     1.085441e+00
> >>     Cycle  5   4.735871e-03    1.134251     1.231163e+00
> >>     Cycle  6   5.809054e-03    1.226607     1.510154e+00
> >>  Average Convergence Factor = 1.071117
> >>                 operator = 1.000000
> >>                    cycle = 1.000000
> >>>   Nicolas,
> >>>    I have added support for both 1 and/or 2 to petsc-dev
> >>> http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html
> >>> The two new options are -pc_hypre_boomeramg_nodal_coarsen and
> >>> -pc_hypre_boomeramg_nodal_relaxation <optional:n) where the optional
> >>> argument n indicates the levels which the SmoothNumLevels() sets.
> >>> I have not tested the code so please let me know what problems you
> >>> have.
> >>>   Allison,
> >>>     Thank you very much for the clarifications.
> >>>    Barry
> >>> On Wed, 25 Apr 2007, Allison Baker wrote:
> >>>> Hi Barry and Nicolas,
> >>>> To clarify,
> >>>> HYPRE_BoomerAMGSetNumFunctions(solver, int num_functions) tells
> >>>> AMG to
> >>>> solve a
> >>>> system of equations with the specified number of functions/
> >>>> unknowns. The
> >>>> default AMG scheme to solve a PDE system is the "unknown"
> >>>> approach. (The
> >>>> coarsening and interpolation are determined by looking at each
> >>>> unknown/function independently - therefore you can imagine that the
> >>>> coarse
> >>>> grids are generally not the same for each variable. This approach
> >>>> generally
> >>>> works well unless you have strong coupling between unknowns.)
> >>>> HYPRE_BOOMERAMGSetNodal(solver, int nodal ) tells AMG to coarsen
> >>>> such
> >>>> that
> >>>> each variable has the same coarse grid - sometimes this is more
> >>>> "physical" for
> >>>> a particular problem. The value chosen here for nodal determines how
> >>>> strength
> >>>> of connection is determined between the coupled system.  I suggest
> >>>> setting
> >>>> nodal = 1, which uses a Frobenius norm.  This does NOT tell AMG
> >>>> to use
> >>>> nodal
> >>>> relaxation.
> >>>> If you want to use nodal relaxation in hypre there are two choices:
> >>>> (1) If you call  HYPRE_BOOMERAMGSetNodal, then you can
> >>>> additionally do
> >>>> nodal
> >>>> relaxation via the schwarz smoother option in hypre.  I did not
> >>>> implement this
> >>>> in the Petsc interface, but it could be done easy enough. The
> >>>> following
> >>>> four
> >>>> functions need to be called:
> >>>>      HYPRE_BoomerAMGSetSmoothType(solver, 6);
> >>>>      HYPRE_BoomerAMGSetDomainType(solver, 1);
> >>>>      HYPRE_BoomerAMGSetOverlap(solver, 0);
> >>>>      HYPRE_BoomerAMGSetSmoothNumLevels(solver, num_levels);  (Set
> >>>> num_levels
> >>>> to number of levels on which you  want nodal smoothing, i.e.
> >>>> 1=just the
> >>>> fine
> >>>> grid, 2= fine grid and the grid below, etc.  I find that doing nodal
> >>>> relaxation on just the finest level is generally sufficient.)
> >>>> Note that
> >>>> the
> >>>> interpolation scheme used will be the same as in the unknown
> >>>> approach -
> >>>> so
> >>>> this is what we call a hybrid systems method.
> >>>> (2) You can do both nodal smoothing and a nodal interpolation
> >>>> scheme.
> >>>> While
> >>>> this is currently implemented in 2.0.0, it is not advertised (i.e.,
> >>>> mentioned
> >>>> at all in the user's manual) because it is not yet implemented very
> >>>> efficiently (the fine grid matrix is converted to a block matrix
> >>>> - and
> >>>> both
> >>>> are stored), and we have not found it to be as effective as
> >>>> advertised
> >>>> elsewhere (this is an area of current research for us)..... If
> >>>> you want
> >>>> to try
> >>>> it anyway, let me know and I will provide more info.
> >>>> Hope this helps,
> >>>> Allison
> >>>> Barry Smith wrote:
> >>>>>   Nicolas,
> >>>>> On Wed, 25 Apr 2007, Nicolas Bathfield wrote:
> >>>>>> Dear Barry,
> >>>>>> Using MatSetBlockSize(A,5) improved my results greatly. Boomemramg
> >>>> is now
> >>>>>> solving the system of equations.
> >>>>>    Good
> >>>>>> Still, the equations I solve are coupled, and my discretization
> >>>> scheme is
> >>>>>> meant for a non-segregated solver. As a consequence (I believe),
> >>>> boomeramg
> >>>>>> still diverges.
> >>>>>   How can "Boomeramg be now solving the system of equations" but
> >>>>> also
> >>>>> diverge? I am so confused.
> >>>>>>  I would therefore like to use the nodal relaxation in
> >>>>>> boomeramg (the hypre command is HYPRE_BOOMERAMGSetNodal) in
> >>>>>> order to
> >>>>>> couple the coarse grid choice for all my variables.
> >>>>>   I can add this this afternoon.
> >>>>>   I have to admit I do not understand the difference between
> >>>>> HYPRE_BOOMERAMGSetNodal() and hypre_BoomerAMGSetNumFunctions(). Do
> >>>> you?
> >>>>>    Barry
> >>>>>> How can I achieve this from PETSc?
> >>>>>> Best regards,
> >>>>>> Nicolas
> >>>>>>>   From PETSc MPIAIJ matrices you need to set the block size of
> >>>>>>> the
> >>>>>>> matrix
> >>>>>>> with MatSetBlockSize(A,5) after you have called MatSetType() or
> >>>>>>> MatCreateMPIAIJ(). Then HYPRE_BoomerAMGSetNumFunctions() is
> >>>>>>> automatically
> >>>>>>> called by PETSc.
> >>>>>>>    Barry
> >>>>>>> The reason this is done this way instead of as
> >>>>>>> -pc_hypre_boomeramg_block_size <bs> is the idea that hypre will
> >>>> use the
> >>>>>>> properties of the matrix it is given in building the
> >>>> preconditioner so
> >>>>>>> the user does not have to pass those properties in seperately
> >>>> directly
> >>>>>>> to hypre.
> >>>>>>> On Fri, 13 Apr 2007, Shaman Mahmoudi wrote:
> >>>>>>>> Hi,
> >>>>>>>> int HYPRE_BoomerAMGSetNumFunctions (.....)
> >>>>>>>> sets the size of the system of PDEs.
> >>>>>>>> On Apr 13, 2007, at 2:04 PM, Shaman Mahmoudi wrote:
> >>>>>>>>> Hi Nicolas,
> >>>>>>>>> You are right. hypre has changed a lot since the version I
> >>>> used.
> >>>>>>>>> I found this interesting information:
> >>>>>>>>> int HYPRE_BOOMERAMGSetNodal(....)
> >>>>>>>>> Sets whether to use the nodal systems version. Default is 0.
> >>>>>>>>> Then information about smoothers:
> >>>>>>>>> One interesting thing there is this,
> >>>>>>>>> HYPRE_BoomerAMGSetDomainType(....)
> >>>>>>>>> 0 - each point is a domain (default)
> >>>>>>>>> 1 each node is a domain (only of interest in systems AMG)
> >>>>>>>>> 2 ....
> >>>>>>>>> I could not find how you define the nodal displacement
> >>>> ordering. But
> >>>>>>>> it
> >>>>>>>>> should be there somewhere.
> >>>>>>>>> I read the reference manual for hypre 2.0
> >>>>>>>>> On Apr 13, 2007, at 1:40 PM, Nicolas Bathfield wrote:
> >>>>>>>>>> Dear Shaman,
> >>>>>>>>>> As far as I could understand, there is a BoomerAMG?s systems
> >>>> AMG
> >>>>>>>> version
> >>>>>>>>>> available. This seems to be exactly what I am looking for,
> >>>> but I
> >>>>>>>> just
> >>>>>>>>>> don't know how to access it, either through PETSc or
> >>>> directly.
> >>>>>>>>>> Best regards,
> >>>>>>>>>> Nicolas
> >>>>>>>>>>> Hi,
> >>>>>>>>>>> You want to exploit the structure of the model?
> >>>>>>>>>>> As far as I know, boomeramg can not treat a set of rows or
> >>>>>>>>>>> blocks
> >>>>>>>> as
> >>>>>>>>>>> a molecule,  a so called block-smoother?
> >>>>>>>>>>> ML 2.0 smoothed aggregation does support it.
> >>>>>>>>>>> On Apr 13, 2007, at 10:45 AM, Nicolas Bathfield wrote:
> >>>>>>>>>>>> Hi,
> >>>>>>>>>>>> I am solving the Navier-stokes equations and try to use
> >>>> Hypre
> >>>>>>>>>>>> as
> >>>>>>>>>>>> preconditioner.
> >>>>>>>>>>>> Until now, I used PETSc as non-segregated solver and it
> >>>> worked
> >>>>>>>>>>>> perfectly.
> >>>>>>>>>>>> Things got worse when I decided to use Boomeramg
> >>>> (Hypre).
> >>>>>>>>>>>> As I solve a system of PDEs,  each cell is represented
> >>>> by 5
> >>>>>>>>>>>> rows
> >>>>>>>> in my
> >>>>>>>>>>>> matrix (I solve for 5 variables). PETSc handles that
> >>>> without
> >>>>>>>> problem
> >>>>>>>>>>>> apparently, but the coarsening scheme of Boomeramg needs
> >>>> more
> >>>>>>>> input in
> >>>>>>>>>>>> order to work properly.
> >>>>>>>>>>>> Is there an option in PETSc to tell HYPRE that we are
> >>>> dealing
> >>>>>>>> with a
> >>>>>>>>>>>> system of PDEs? (something like:
> >>>> -pc_hypre_boomeramg_...)
> >>>>>>>>>>>> Thanks for your help.
> >>>>>>>>>>>> Best regards,
> >>>>>>>>>>>> Nicolas
> >>>>>>>>>>>> Nicolas BATHFIELD
> >>>>>>>>>>>> Chalmers University of Technology
> >>>>>>>>>>>> Shipping and Marine Technology
> >>>>>>>>>>>> phone: +46 (0)31 772 1476
> >>>>>>>>>>>> fax:   +46 (0)31 772 3699
> >>>>>>>>>> Nicolas BATHFIELD
> >> Nicolas BATHFIELD
