lgcc_s not found error
Tue May 8 00:55:20 CDT 2007
On Tue, 8 May 2007, Ben Tay wrote:
> /lsftmp/g0306332/petsc-2.3.2-p8/lib/atlas3-noshared/libpetsc.a(ghome.o)(.text+0x16):
> In function `PetscGetHomeDirectory':
> : warning: Using 'getpwuid' in statically linked applications requires at
> runtime the shared libraries from the glibc version used for linking
> /lsftmp/g0306332/petsc-2.3.2-p8/lib/atlas3-noshared/libpetsc.a(send.o)(.text+0xafc):
> In function `SOCKCall_Private':
> : warning: Using 'gethostbyname' in statically linked applications requires
> at runtime the shared libraries from the glibc version used for linking
I guess you could ignore these warnings and see if the binary does not
crash at runtime.
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/libstdc++.a(eh_alloc.o)(.text.__cxa_allocate_exception+0xc8):
> In function `__cxa_allocate_exception':
> : undefined reference to `pthread_mutex_unlock'
I think you removed -lpthread from the link options.
Satish
