HYPRE with multiple variables
Shaman Mahmoudi shma7099 at student.uu.se
Mon May 7 11:14:03 CDT 2007
You mentioned that your preconditioner is boomerAMG. What solver are
you using?
What type of matrix are you trying to solve? Is it SPD and sparse?
Either way, if your solver is not AMG and you are using AMG as a
preconditioner, I would suggest that you use a stopping criteria for
AMG such as a relative residual convergence of say 1e-03 for the
preconditioner, and the solvers relative convergence 1e-05 as in your
example, and disregard a stopping criteria which involves maximum
number of iterations for AMG, set that to something high. Maybe you
will get better results that way. In the end, I guess it is a lot of
testing and fine-tuning.
With best regards, Shaman Mahmoudi
On May 7, 2007, at 4:50 PM, Nicolas Bathfield wrote:
> Hi Allison, Barry, and PETSc users,
> The nodal relaxation leads to a nice solution! Thanks a lot for
> your help
> on this!
> Even though I get a satisfactory result, I can not explain why
> hypre is
> performing what looks like several outer loops (see below for an
> abstract
> of the output from -pc_hypre_boomeramg_print_statistics).
> Here is the list of options I used:
> -pc_hypre_boomeramg_tol 1e-5
> -pc_type hypre -pc_hypre_type boomeramg
> -pc_hypre_boomeramg_grid_sweeps_all 20
> -pc_hypre_boomeramg_max_iter 6
> -pc_hypre_boomeramg_relax_weight_all 0.6
> -pc_hypre_boomeramg_outer_relax_weight_all 0.6
> -pc_hypre_boomeramg_nodal_coarsen 1
> I would expect the preconditioner to be executed once only (in my case
> this includes 6 V cycles).
> As you can see from the print_statistic option, boomeramg is exectuted
> several times (many more times than displyed here, it was too long
> to copy
> everything). Is this normal? If yes, why is it so?
> Best regards,
> Nicolas
> BoomerAMG SOLVER PARAMETERS:
>   Maximum number of cycles:         6
>   Stopping Tolerance:               1.000000e-05
>   Cycle type (1 = V, 2 = W, etc.):  1
>   Relaxation Parameters:
>    Visiting Grid:                     down   up  coarse
>             Number of partial sweeps:   20   20     1
>    Type 0=Jac, 3=hGS, 6=hSGS, 9=GE:      6    6     6
>    Point types, partial sweeps (1=C, -1=F):
>                   Pre-CG relaxation (down):   1  -1   1  -1   1
> -1   1
> -1   1  -1   1  -1   1  -1   1  -1   1  -1   1  -1   1
> -1   1  -1   1  -1
>                    Post-CG relaxation (up):  -1   1  -1   1  -1
> 1  -1
> 1  -1   1  -1   1  -1   1  -1   1  -1   1  -1   1  -1
> 1  -1   1  -1   1
>                              Coarsest grid:   0
>  Relaxation Weight 0.600000 level 0
>  Outer relaxation weight 0.600000 level 0
>  Output flag (print_level): 3
> AMG SOLUTION INFO:
>                                             relative
>                residual        factor       residual
>     Initial    4.430431e-03                 1.000000e+00
>     Cycle  1   4.540275e-03    1.024793     1.024793e+00
>     Cycle  2   4.539148e-03    0.999752     1.024539e+00
>     Cycle  3   4.620010e-03    1.017814     1.042790e+00
>     Cycle  4   5.196532e-03    1.124788     1.172918e+00
>     Cycle  5   6.243043e-03    1.201386     1.409128e+00
>     Cycle  6   7.310008e-03    1.170905     1.649954e+00
>  NOTE: Convergence tolerance was not achieved
>       within the allowed 6 V-cycles
>  Average Convergence Factor = 1.087039
>      Complexity:    grid = 1.000000
>                 operator = 1.000000
>                    cycle = 1.000000
> -1   1
> -1   1  -1   1  -1
> 1  -1
> 1  -1   1  -1   1
>                              Coarsest grid:   0
> AMG SOLUTION INFO:
>                                             relative
>     Initial    7.914114e-03                 1.000000e+00
>     Cycle  1   8.320104e-03    1.051300     1.051300e+00
>     Cycle  2   7.767803e-03    0.933618     9.815126e-01
>     Cycle  3   6.570752e-03    0.845896     8.302575e-01
>     Cycle  4   5.836166e-03    0.888204     7.374377e-01
>     Cycle  5   6.593214e-03    1.129717     8.330956e-01
>     Cycle  6   8.191117e-03    1.242356     1.035001e+00
>  Average Convergence Factor = 1.005750
>                 operator = 1.000000
>                    cycle = 1.000000
> -1   1
> -1   1  -1   1  -1
> 1  -1
> 1  -1   1  -1   1
>                              Coarsest grid:   0
> AMG SOLUTION INFO:
>                                             relative
>     Initial    5.553016e-03                 1.000000e+00
>     Cycle  1   6.417482e-03    1.155675     1.155675e+00
>     Cycle  2   7.101926e-03    1.106653     1.278931e+00
>     Cycle  3   7.077471e-03    0.996556     1.274527e+00
>     Cycle  4   6.382835e-03    0.901853     1.149436e+00
>     Cycle  5   5.392392e-03    0.844827     9.710744e-01
>     Cycle  6   4.674173e-03    0.866809     8.417359e-01
>  Average Convergence Factor = 0.971694
>                 operator = 1.000000
>                    cycle = 1.000000
> -1   1
> -1   1  -1   1  -1
> 1  -1
> 1  -1   1  -1   1
>                              Coarsest grid:   0
> AMG SOLUTION INFO:
>                                             relative
>     Initial    3.846663e-03                 1.000000e+00
>     Cycle  1   4.136662e-03    1.075390     1.075390e+00
>     Cycle  2   4.463861e-03    1.079097     1.160450e+00
>     Cycle  3   4.302262e-03    0.963798     1.118440e+00
>     Cycle  4   4.175328e-03    0.970496     1.085441e+00
>     Cycle  5   4.735871e-03    1.134251     1.231163e+00
>     Cycle  6   5.809054e-03    1.226607     1.510154e+00
>  Average Convergence Factor = 1.071117
>                 operator = 1.000000
>                    cycle = 1.000000
>>   Nicolas,
>>    I have added support for both 1 and/or 2 to petsc-dev
>> http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html
>> The two new options are -pc_hypre_boomeramg_nodal_coarsen and
>> -pc_hypre_boomeramg_nodal_relaxation <optional:n) where the optional
>> argument n indicates the levels which the SmoothNumLevels() sets.
>> I have not tested the code so please let me know what problems you
>> have.
>>   Allison,
>>     Thank you very much for the clarifications.
>>    Barry
>> On Wed, 25 Apr 2007, Allison Baker wrote:
>>> Hi Barry and Nicolas,
>>> To clarify,
>>> HYPRE_BoomerAMGSetNumFunctions(solver, int num_functions) tells
>>> AMG to
>>> solve a
>>> system of equations with the specified number of functions/
>>> unknowns. The
>>> default AMG scheme to solve a PDE system is the "unknown"
>>> approach. (The
>>> coarsening and interpolation are determined by looking at each
>>> unknown/function independently - therefore you can imagine that the
>>> coarse
>>> grids are generally not the same for each variable. This approach
>>> generally
>>> works well unless you have strong coupling between unknowns.)
>>> HYPRE_BOOMERAMGSetNodal(solver, int nodal ) tells AMG to coarsen
>>> such
>>> that
>>> each variable has the same coarse grid - sometimes this is more
>>> "physical" for
>>> a particular problem. The value chosen here for nodal determines how
>>> strength
>>> of connection is determined between the coupled system.  I suggest
>>> setting
>>> nodal = 1, which uses a Frobenius norm.  This does NOT tell AMG
>>> to use
>>> nodal
>>> relaxation.
>>> If you want to use nodal relaxation in hypre there are two choices:
>>> (1) If you call  HYPRE_BOOMERAMGSetNodal, then you can
>>> additionally do
>>> nodal
>>> relaxation via the schwarz smoother option in hypre.  I did not
>>> implement this
>>> in the Petsc interface, but it could be done easy enough. The
>>> following
>>> four
>>> functions need to be called:
>>>      HYPRE_BoomerAMGSetSmoothType(solver, 6);
>>>      HYPRE_BoomerAMGSetDomainType(solver, 1);
>>>      HYPRE_BoomerAMGSetOverlap(solver, 0);
>>>      HYPRE_BoomerAMGSetSmoothNumLevels(solver, num_levels);  (Set
>>> num_levels
>>> to number of levels on which you  want nodal smoothing, i.e.
>>> 1=just the
>>> fine
>>> grid, 2= fine grid and the grid below, etc.  I find that doing nodal
>>> relaxation on just the finest level is generally sufficient.)
>>> Note that
>>> the
>>> interpolation scheme used will be the same as in the unknown
>>> approach -
>>> so
>>> this is what we call a hybrid systems method.
>>> (2) You can do both nodal smoothing and a nodal interpolation
>>> scheme.
>>> While
>>> this is currently implemented in 2.0.0, it is not advertised (i.e.,
>>> mentioned
>>> at all in the user's manual) because it is not yet implemented very
>>> efficiently (the fine grid matrix is converted to a block matrix
>>> - and
>>> both
>>> are stored), and we have not found it to be as effective as
>>> advertised
>>> elsewhere (this is an area of current research for us)..... If
>>> you want
>>> to try
>>> it anyway, let me know and I will provide more info.
>>> Hope this helps,
>>> Allison
>>> Barry Smith wrote:
>>>>   Nicolas,
>>>> On Wed, 25 Apr 2007, Nicolas Bathfield wrote:
>>>>> Dear Barry,
>>>>> Using MatSetBlockSize(A,5) improved my results greatly. Boomemramg
>>> is now
>>>>> solving the system of equations.
>>>>    Good
>>>>> Still, the equations I solve are coupled, and my discretization
>>> scheme is
>>>>> meant for a non-segregated solver. As a consequence (I believe),
>>> boomeramg
>>>>> still diverges.
>>>>   How can "Boomeramg be now solving the system of equations" but
>>>> also
>>>> diverge? I am so confused.
>>>>>  I would therefore like to use the nodal relaxation in
>>>>> boomeramg (the hypre command is HYPRE_BOOMERAMGSetNodal) in
>>>>> order to
>>>>> couple the coarse grid choice for all my variables.
>>>>   I can add this this afternoon.
>>>>   I have to admit I do not understand the difference between
>>>> HYPRE_BOOMERAMGSetNodal() and hypre_BoomerAMGSetNumFunctions(). Do
>>> you?
>>>>    Barry
>>>>> How can I achieve this from PETSc?
>>>>> Best regards,
>>>>> Nicolas
>>>>>>   From PETSc MPIAIJ matrices you need to set the block size of
>>>>>> the
>>>>>> matrix
>>>>>> with MatSetBlockSize(A,5) after you have called MatSetType() or
>>>>>> MatCreateMPIAIJ(). Then HYPRE_BoomerAMGSetNumFunctions() is
>>>>>> automatically
>>>>>> called by PETSc.
>>>>>>    Barry
>>>>>> The reason this is done this way instead of as
>>>>>> -pc_hypre_boomeramg_block_size <bs> is the idea that hypre will
>>> use the
>>>>>> properties of the matrix it is given in building the
>>> preconditioner so
>>>>>> the user does not have to pass those properties in seperately
>>> directly
>>>>>> to hypre.
>>>>>> On Fri, 13 Apr 2007, Shaman Mahmoudi wrote:
>>>>>>> Hi,
>>>>>>> int HYPRE_BoomerAMGSetNumFunctions (.....)
>>>>>>> sets the size of the system of PDEs.
>>>>>>> On Apr 13, 2007, at 2:04 PM, Shaman Mahmoudi wrote:
>>>>>>>> Hi Nicolas,
>>>>>>>> You are right. hypre has changed a lot since the version I
>>> used.
>>>>>>>> I found this interesting information:
>>>>>>>> int HYPRE_BOOMERAMGSetNodal(....)
>>>>>>>> Sets whether to use the nodal systems version. Default is 0.
>>>>>>>> Then information about smoothers:
>>>>>>>> One interesting thing there is this,
>>>>>>>> HYPRE_BoomerAMGSetDomainType(....)
>>>>>>>> 0 - each point is a domain (default)
>>>>>>>> 1 each node is a domain (only of interest in systems AMG)
>>>>>>>> 2 ....
>>>>>>>> I could not find how you define the nodal displacement
>>> ordering. But
>>>>>>> it
>>>>>>>> should be there somewhere.
>>>>>>>> I read the reference manual for hypre 2.0
>>>>>>>> On Apr 13, 2007, at 1:40 PM, Nicolas Bathfield wrote:
>>>>>>>>> Dear Shaman,
>>>>>>>>> As far as I could understand, there is a BoomerAMG?s systems
>>> AMG
>>>>>>> version
>>>>>>>>> available. This seems to be exactly what I am looking for,
>>> but I
>>>>>>> just
>>>>>>>>> don't know how to access it, either through PETSc or
>>> directly.
>>>>>>>>> Best regards,
>>>>>>>>> Nicolas
>>>>>>>>>> Hi,
>>>>>>>>>> You want to exploit the structure of the model?
>>>>>>>>>> As far as I know, boomeramg can not treat a set of rows or
>>>>>>>>>> blocks
>>>>>>> as
>>>>>>>>>> a molecule,  a so called block-smoother?
>>>>>>>>>> ML 2.0 smoothed aggregation does support it.
>>>>>>>>>> On Apr 13, 2007, at 10:45 AM, Nicolas Bathfield wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> I am solving the Navier-stokes equations and try to use
>>> Hypre
>>>>>>>>>>> as
>>>>>>>>>>> preconditioner.
>>>>>>>>>>> Until now, I used PETSc as non-segregated solver and it
>>> worked
>>>>>>>>>>> perfectly.
>>>>>>>>>>> Things got worse when I decided to use Boomeramg
>>> (Hypre).
>>>>>>>>>>> As I solve a system of PDEs,  each cell is represented
>>> by 5
>>>>>>>>>>> rows
>>>>>>> in my
>>>>>>>>>>> matrix (I solve for 5 variables). PETSc handles that
>>> without
>>>>>>> problem
>>>>>>>>>>> apparently, but the coarsening scheme of Boomeramg needs
>>> more
>>>>>>> input in
>>>>>>>>>>> order to work properly.
>>>>>>>>>>> Is there an option in PETSc to tell HYPRE that we are
>>> dealing
>>>>>>> with a
>>>>>>>>>>> system of PDEs? (something like:
>>> -pc_hypre_boomeramg_...)
>>>>>>>>>>> Thanks for your help.
>>>>>>>>>>> Best regards,
>>>>>>>>>>> Nicolas
>>>>>>>>>>> Nicolas BATHFIELD
>>>>>>>>>>> Chalmers University of Technology
>>>>>>>>>>> Shipping and Marine Technology
>>>>>>>>>>> phone: +46 (0)31 772 1476
>>>>>>>>>>> fax:   +46 (0)31 772 3699
>>>>>>>>> Nicolas BATHFIELD
> Nicolas BATHFIELD
