Problems porting code to an IBM power5+ machine
Knut Erik Teigen knutert at stud.ntnu.no
Mon Mar 19 08:29:17 CDT 2007
Hello
I have got a working code on my local machine( Pentium 4), but when I
try to run the code on a power5+ machine, the equation solver won't
converge. It seems like it calculates the wrong right hand side norm.
Below is the result with run-time options
"-ksp_type cg -pc_type icc -ksp_monitor -ksp_view -info
First with the code running on the power5+ machine, then on my local
machine. I've also printed the right hand side, jacobian matrix and
solution for a small 3x3 grid.
Can anyone help me figure out what's wrong?
Knut Erik Teigen
Code running on Power5+:
rhs:
980
980
980
-0
-0
-0
-980
-980
-980
jacobian:
row 0: (0, 20)  (1, -10)  (3, -10)
row 1: (0, -10)  (1, 30)  (2, -10)  (4, -10)
row 2: (1, -10)  (2, 20)  (5, -10)
row 3: (0, -10)  (3, 30)  (4, -10)  (6, -10)
row 4: (1, -10)  (3, -10)  (4, 40)  (5, -10)  (7, -10)
row 5: (2, -10)  (4, -10)  (5, 30)  (8, -10)
row 6: (3, -10)  (6, 20)  (7, -10)
row 7: (4, -10)  (6, -10)  (7, 30)  (8, -10)
row 8: (5, -10)  (7, -10)  (8, 20)
[0] PCSetUpSetting up new PC
[0] PetscCommDuplicateDuplicating a communicator 1 4 max tags =
1073741823
[0] PetscCommDuplicateUsing internal PETSc communicator 1 4
  0 KSP Residual norm 7.410163701832e+28
  1 KSP Residual norm 6.464393707520e+11
[0] KSPDefaultConvergedLinear solver has converged. Residual norm
6.46439e+11 is less than relative tolerance 1e-07 times initial right
hand side norm 7.41016e+28 at iteration 1
KSP Object:
  type: cg
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
  left preconditioning
PC Object:
  type: icc
    ICC: 0 levels of fill
    ICC: factor fill ratio allocated 1
    ICC: factor fill ratio needed 0.636364
         Factored matrix follows
        Matrix Object:
          type=seqsbaij, rows=9, cols=9
          total: nonzeros=21, allocated nonzeros=21
              block size is 1
  linear system matrix = precond matrix:
  Matrix Object:
    type=seqaij, rows=9, cols=9
    total: nonzeros=33, allocated nonzeros=45
      not using I-node routines
solution:
6.37205e-09
7.13167e-09
7.49911e-09
-2.48277e-09
-4.56885e-10
0
0
0
0
Code running on local machine:
rhs:
980
980
980
-0
-0
-0
-980
-980
-980
jacobian:
[0] PCSetUp(): Setting up new PC
[0] PetscCommDuplicate(): Duplicating a communicator 1140850689
-2080374783 max tags = 2147483647
[0] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
-2080374783
-2080374783
  0 KSP Residual norm 2.505507810276e+02
  1 KSP Residual norm 3.596555656581e+01
  2 KSP Residual norm 2.632672485513e+00
  3 KSP Residual norm 1.888285055287e-01
  4 KSP Residual norm 7.029433008806e-03
  5 KSP Residual norm 3.635267067420e-14
[0] KSPDefaultConverged(): Linear solver has converged. Residual norm
3.63527e-14 is less than relative tolerance 1e-07 times initial right
hand side norm 250.551 at iteration 5
KSP Object:
  type: cg
PC Object:
  type: icc
        Matrix Object:
              block size is 1
  Matrix Object:
solution:
92.3023
92.3023
92.3023
-5.69767
-5.69767
-5.69767
-103.698
-103.698
-103.698
