building petsc on a POWER5+ machine
Thomas Geenen geenen at gmail.com
Fri Mar 16 13:57:09 CDT 2007
dear petsc users,
I build petsc on a POWER5+ machine.
now i would like to add mumps.
if i do that the way it should de done i end up with a version in
which mumps hangs during the factorization phase.
If i build mumps standalone linking to essl and pessl i get a working
version of mumps.
I tried telling the petsc configuration to use essl and pessl instead
of scalapack and blacs like this
--with-scalapack=yes --with-scalapack-lib=/usr/lib/libpessl.a
--with-blacs=yes --with-blacs-lib=/usr/lib/libessl.a
--with-scalapack-include=/usr/include/
with-blacs-include=/usr/include/
resulting in
TESTING: check from
config.libraries(/ptmp/huangwei/petsc-2.3.2-p8/python/BuildSystem/config/libraries.py:108)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
--with-blacs-lib=['/usr/lib/libessl.a'] and
--with-blacs-include=/usr/include/ did not work
so how can i either link my working version of mumps to petsc without
having a scalapack or blacs lib or include,
or use essl and pessl as substitute for scalapack and blacs and rebuild petsc
cheers
Thomas
complete config option list
./config/configure.py --with-memcmp-ok --with-endian=big
--sizeof_char=1 --sizeof_void_p=8 --sizeof_short=2 --sizeof_int=4
--sizeof_long=8 --sizeof_long_long=8 --sizeof_float=4
--sizeof_double=8 --bits_per_byte=8 --sizeof_MPI_Comm=4
--sizeof_MPI_Fint=4 --with-batch --with-shared=0
--with-mpirun=mpirun.lsf --with-mpi-dir=/usr/lpp/ppe.poe/
--with-mpi-shared=yes --with-fc=mpxlf_r --with-cc=mpcc_r
--with-hypre=yes --with-mumps=yes
--with-hypre-dir=/blhome/geenen/source/petsc-2.3.2-p8/externalpackages/hypre-1.11.1b/src/hypre/
--with-mumps-dir=/blhome/geenen/source/petsc-2.3.2-p8/externalpackages/MUMPS_4.6.3/
