PETSC error
Shaman Mahmoudi shma7099 at student.uu.se
Thu Mar 15 12:33:14 CDT 2007
I got that problem when
1) The time you are allowed to be in the system exceeded and batch-
system killed your processes.
2) I did not exit the program properly
3) One of the MPI installs afaik was a bit un-steady or not
configured properly and caused error messages like this pop up after
the program had exited (properly).
With best regards, Shaman Mahmoudi
On Mar 15, 2007, at 5:56 PM, Matt Funk wrote:
> Hi,
> i am getting the following error message in a program that uses PETSC:
> "Caught signal number 15 "Terminate: Somet process (or the batch
> system) has
> told this process to end"
> Does any body know what that means or what could possibly cause this?
> thanks
> mat
