Help! Installing PETSc?
Wed Mar 14 13:39:04 CDT 2007
this issues is followed up at petsc-maint [with configure.log]
Satish
On Wed, 14 Mar 2007, Bin wrote:
> Thanks, it works. But when I try to configure PETSc with --with-shared
> > options,
> > > config/configure.py \
> > >   --with-cc=mpicc \
> > >   --with-fc=mpif90 \
> > >   --with-mpi-dir=/opt/hpmpi/lib/linux_amd64/ \
> > >   --with-mpi-shared=yes \
> > >   LIBS=-lpgf90rtl \
> > >   --with-debugging=yes \
> > >   --download-superlu=no \
> > >   --download-superlu_dist=no \
> > >   --with-shared
> >  I got the following errors:
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.logfor
> > details):
> > > C compiler you provided with -with-cc=mpicc does not work
> > Do you know why?
> > Thank you.
> > On 3/14/07, Shaman Mahmoudi <shma7099 at student.uu.se> wrote:
> > > Hi,
> > > try mpirun -np 1 ./conftest
> > > With best regards, Shaman Mahmoudi
> > >  On Mar 14, 2007, at 6:56 AM, Bin wrote:
> > > mpirun -np 1 conftest
> > Yours truly,
> > Bin Xu
