PETSc CG solver uses more iterations than other CG solver
Knut Erik Teigen knutert at stud.ntnu.no
Tue Mar 13 04:08:13 CDT 2007
On Sat, 2007-03-10 at 11:55 -0600, Matthew Knepley wrote:
> Something is obviously wrong. CG has a simple definition and so does ICC(0).
> So I would suggest
>   1) Make sure you are comparing apples to apples. Usually, the other solver
>       will have something you have not turned on, like scaling.
>   2) Compare the iterates exactly. I do this all the time, and it is
> the best way
>       to compare differences.
Is there an easy way to do this with PETSc, or do I have to add print
sentences to the source code and recompile?
-Knut Erik-
>    Matt
> On 3/10/07, knutert at stud.ntnu.no <knutert at stud.ntnu.no> wrote:
> > Thank you for your reply.
> > One boundary cell is defined to have constant pressure, since that
> > makes the equation system have a unique solution. I tried your
> > command, and it lowered the number of iterations for most of the time
> > steps, but for some it reached the maximum number of iterations
> > (10000) without converging.
> > I also tried making all the boundaries von Neumann and using your
> > command. That made the number of iterations more constant, instead of
> > varying between 700 and 2000, it stayed on around 1200. But it
> > actually increased the average number of iterations somewhat. Still
> > far from the performance of the other solver.
> > I've also checked the convergence criteria, and it is the same for
> > both solvers.
> > Siterer Lisandro Dalcin <dalcinl at gmail.com>:
> > > On 3/9/07, Knut Erik Teigen <knutert at stud.ntnu.no> wrote:
> > >> To solve the Navier-Stokes equations, I use an explicit Runge-Kutta
> > >> method with Chorin's projection method,
> > >> so a Poisson equation with von Neumann boundary conditions for the
> > >> pressure has to be solved at every time-step.
> > > All boundary conditions are Neumann type? In that case, please try to
> > > run your program with the following command line option:
> > > -ksp_constant_null_space
> > > and let me know if this corrected your problem.
> > > The equation system is
> > >> positive definite, so I use the CG solver with the ICC preconditioner.
> > >> The problem is that the PETSc solver seems to need a lot more iterations
> > >> to reach the solution than another CG solver I'm using. On a small test
> > >> problem(a rising bubble) with a 60x40 grid, the PETSc solver needs over
> > >> 1000 iterations on average, while the other solver needs less than 100.
> > >> I am using KSPSetInitialGuessNonzero, without this the number of
> > >> iterations is even higher.
> > >> I have also tried applying PETSc to a similar problem, solving the
> > >> Poisson equation with von Neumann boundaries and a forcing function of
> > >> f=sin(pi * x)+sin(pi *y). For this problem, the number of iterations is
> > >> almost exactly the same for PETSc and the other solver.
> > >> Does anyone know what the problem might be? Any help is greatly
> > >> appreciated. I've included the -ksp_view of one of the time steps
> > >> and the -log_summary below.
> > >> Regards,
> > >> Knut Erik Teigen
> > >> MSc student
> > >> Norwegian University of Science and Technology
> > >> Output from -ksp_view:
> > >> KSP Object:
> > >>  type: cg
> > >>  maximum iterations=10000
> > >>  tolerances:  relative=1e-06, absolute=1e-50, divergence=10000
> > >>  left preconditioning
> > >> PC Object:
> > >>  type: icc
> > >>    ICC: 0 levels of fill
> > >>    ICC: factor fill ratio allocated 1
> > >>    ICC: factor fill ratio needed 0.601695
> > >>         Factored matrix follows
> > >>        Matrix Object:
> > >>          type=seqsbaij, rows=2400, cols=2400
> > >>          total: nonzeros=7100, allocated nonzeros=7100
> > >>              block size is 1
> > >>  linear system matrix = precond matrix:
> > >>  Matrix Object:
> > >>    type=seqaij, rows=2400, cols=2400
> > >>    total: nonzeros=11800, allocated nonzeros=12000
> > >>      not using I-node routines
> > >> Poisson converged after 1403 iterations
> > >> Output from -log_summary
> > >> ---------------------------------------------- PETSc Performance
> > >> Summary: ----------------------------------------------
> > >> ./run on a gcc-ifc-d named iept0415 with 1 processor, by knutert Fri Mar
> > >> 9 17:06:05 2007
> > >> Using Petsc Release Version 2.3.2, Patch 8, Tue Jan  2 14:33:59 PST 2007
> > >> HG revision: ebeddcedcc065e32fc252af32cf1d01ed4fc7a80
> > >>                         Max       Max/Min        Avg      Total
> > >> Time (sec):           5.425e+02      1.00000   5.425e+02
> > >> Objects:              7.000e+02      1.00000   7.000e+02
> > >> Flops:                6.744e+10      1.00000   6.744e+10  6.744e+10
> > >> Flops/sec:            1.243e+08      1.00000   1.243e+08  1.243e+08
> > >> Memory:               4.881e+05      1.00000              4.881e+05
> > >> MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
> > >> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
> > >> MPI Reductions:       1.390e+03      1.00000
> > >> Flop counting convention: 1 flop = 1 real number operation of type
> > >> (multiply/divide/add/subtract)
> > >>                            e.g., VecAXPY() for real vectors of length N
> > >> --> 2N flops
> > >>                            and VecAXPY() for complex vectors of length
> > >> N --> 8N flops
> > >> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
> > >> ---  -- Message Lengths --  -- Reductions --
> > >>                        Avg     %Total     Avg     %Total   counts   %
> > >> Total     Avg         %Total   counts   %Total
> > >> 0:      Main Stage: 5.4246e+02 100.0%  6.7437e+10 100.0%  0.000e+00
> > >> 0.0%  0.000e+00        0.0%  1.390e+03 100.0%
> > >> See the 'Profiling' chapter of the users' manual for details on
> > >> interpreting output.
> > >> Phase summary info:
> > >>   Count: number of times phase was executed
> > >>   Time and Flops/sec: Max - maximum over all processors
> > >>                       Ratio - ratio of maximum to minimum over all
> > >> processors
> > >>   Mess: number of messages sent
> > >>   Avg. len: average message length
> > >>   Reduct: number of global reductions
> > >>   Global: entire computation
> > >>   Stage: stages of a computation. Set stages with PetscLogStagePush()
> > >> and PetscLogStagePop().
> > >>      %T - percent time in this phase         %F - percent flops in this
> > >> phase
> > >>      %M - percent messages in this phase     %L - percent message
> > >> lengths in this phase
> > >>      %R - percent reductions in this phase
> > >>   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
> > >>      #                          WARNING!!!                    #
> > >>      #   This code was compiled with a debugging option,      #
> > >>      #   To get timing results run config/configure.py        #
> > >>      #   using --with-debugging=no, the performance will      #
> > >>      #   be generally two or three times faster.              #
> > >>      #                          WARNING!!!                    #
> > >>      #   This code was run without the PreLoadBegin()         #
> > >>      #   macros. To get timing results we always recommend    #
> > >>      #   preloading. otherwise timing numbers may be          #
> > >>      #   meaningless.                                         #
> > >> Event                Count      Time (sec)     Flops/sec
> > >> --- Global ---  --- Stage ---   Total
> > >>                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> > >> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> > >> --- Event Stage 0: Main Stage
> > >> VecDot           1668318 1.0 1.9186e+01 1.0 4.17e+08 1.0 0.0e+00 0.0e+00
> > >> 0.0e+00  4 12  0  0  0   4 12  0  0  0   417
> > >> VecNorm           835191 1.0 1.0935e+01 1.0 3.67e+08 1.0 0.0e+00 0.0e+00
> > >> 0.0e+00  2  6  0  0  0   2  6  0  0  0   367
> > >> VecCopy              688 1.0 1.6126e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > >> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > >> VecAXPY          1667630 1.0 2.4141e+01 1.0 3.32e+08 1.0 0.0e+00 0.0e+00
> > >> 0.0e+00  4 12  0  0  0   4 12  0  0  0   332
> > >> VecAYPX           833815 1.0 1.9062e+01 1.0 2.10e+08 1.0 0.0e+00 0.0e+00
> > >> 0.0e+00  4  6  0  0  0   4  6  0  0  0   210
> > >> VecAssemblyBegin     688 1.0 8.5354e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > >> VecAssemblyEnd       688 1.0 7.8177e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > >> MatMult           834503 1.0 1.5044e+02 1.0 1.18e+08 1.0 0.0e+00 0.0e+00
> > >> 0.0e+00 28 26  0  0  0  28 26  0  0  0   118
> > >> MatSolve          835191 1.0 1.8130e+02 1.0 1.42e+08 1.0 0.0e+00 0.0e+00
> > >> 0.0e+00 33 38  0  0  0  33 38  0  0  0   142
> > >> MatCholFctrNum         1 1.0 1.1630e-03 1.0 2.06e+06 1.0 0.0e+00 0.0e+00
> > >> 0.0e+00  0  0  0  0  0   0  0  0  0  0     2
> > >> MatICCFactorSym        1 1.0 2.9588e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > >> 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > >> MatAssemblyBegin     688 1.0 2.6343e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > >> MatAssemblyEnd       688 1.0 1.0964e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > >> MatGetOrdering         1 1.0 2.6798e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > >> KSPSetup               1 1.0 2.7585e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > >> 6.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > >> KSPSolve             688 1.0 4.2809e+02 1.0 1.58e+08 1.0 0.0e+00 0.0e+00
> > >> 1.4e+03 79100  0  0100  79100  0  0100   158
> > >> PCSetUp                1 1.0 1.7900e-03 1.0 1.34e+06 1.0 0.0e+00 0.0e+00
> > >> 4.0e+00  0  0  0  0  0   0  0  0  0  0     1
> > >> PCApply           835191 1.0 1.8864e+02 1.0 1.36e+08 1.0 0.0e+00 0.0e+00
> > >> 0.0e+00 35 38  0  0  0  35 38  0  0  0   136
> > >> Memory usage is given in bytes:
> > >> Object Type          Creations   Destructions   Memory  Descendants'
> > >> Mem.
> > >>           Index Set     2              2      19640     0
> > >>                 Vec   694            693     299376     0
> > >>              Matrix     2              2      56400     0
> > >>       Krylov Solver     1              1         36     0
> > >>      Preconditioner     1              1        108     0
> > >> Average time to get PetscTime(): 2.86102e-07
> > >> OptionTable: -ksp_type cg
> > >> OptionTable: -log_summary -ksp_view
> > >> OptionTable: -pc_type icc
> > >> Compiled without FORTRAN kernels
> > >> Compiled with full precision matrices (default)
> > >> sizeof(short) 2 sizeof(int) 4 sizeof(long) 4 sizeof(void*) 4
> > >> sizeof(PetscScalar) 8
> > >> Configure run at: Thu Mar  8 11:54:22 2007
> > >> Configure options: --with-cc=gcc --with-fc=ifort
> > >> --download-f-blas-lapack=1 --download-mpich=1 --with-debugging=1
> > >> --with-shared=0
> > >> Libraries compiled on Thu Mar  8 12:08:22 CET 2007 on iept0415
> > >> Machine characteristics: Linux iept0415 2.6.16.21-0.8-default #1 Mon Jul
> > >> 3 18:25:39 UTC 2006 i686 i686 i386 GNU/Linux
> > >> Using PETSc directory: /opt/petsc-2.3.2-p8
> > >> Using PETSc arch: gcc-ifc-debug
> > >> Using C compiler: gcc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
> > >> -g3
> > >> Using Fortran compiler: ifort -fPIC -g
> > >> Using include paths: -I/opt/petsc-2.3.2-p8
> > >> -I/opt/petsc-2.3.2-p8/bmake/gcc-ifc-debug -I/opt/petsc-2.3.2-p8/include
> > >> -I/opt/petsc-2.3.2-p8/externalpackages/mpich2-1.0.4p1/gcc-ifc-debug/include
> > >>  -I/usr/X11R6/include
> > >> Using C linker: gcc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -g3
> > >> Using Fortran linker: ifort -fPIC -g
> > >> Using libraries: -Wl,-rpath,/opt/petsc-2.3.2-p8/lib/gcc-ifc-debug
> > >> -L/opt/petsc-2.3.2-p8/lib/gcc-ifc-debug -lpetscts -lpetscsnes -lpetscksp
> > >> -lpetscdm -lpetscmat -lpetscvec -lpetsc
> > >> -Wl,-rpath,/opt/petsc-2.3.2-p8/externalpackages/mpich2-1.0.4p1/gcc-ifc-debug/lib -L/opt/petsc-2.3.2-p8/externalpackages/mpich2-1.0.4p1/gcc-ifc-debug/lib -lmpich -lnsl -lrt -L/usr/X11R6/lib -lX11 -Wl,-rpath,/opt/petsc-2.3.2-p8/externalpackages/fblaslapack/gcc-ifc-debug -L/opt/petsc-2.3.2-p8/externalpackages/fblaslapack/gcc-ifc-debug -lflapack -Wl,-rpath,/opt/petsc-2.3.2-p8/externalpackages/fblaslapack/gcc-ifc-debug -L/opt/petsc-2.3.2-p8/externalpackages/fblaslapack/gcc-ifc-debug -lfblas -lm -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0 -L/usr/lib/gcc/i586-suse-linux/4.1.0 -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -L/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../.. -L/usr/lib/gcc/i586-suse-linux/4.1.0/../../.. -ldl -lgcc_s -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0 -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib
> > >> -Wl,-rpath,/usr/lib/gcc/!
> > > i5!
> > >> 86-suse-linux/4.1.0/../../.. -Wl,-rpath,/opt/intel/fc/9.1.036/lib
> > >> -L/opt/intel/fc/9.1.036/lib
> > >> -L/usr/lib/gcc/i586-suse-linux/4.1.0/../../../ -lifport -lifcore
> > >> -limf -lm -lipgo -lirc -lirc_s
> > >> -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../.. -lm  -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0 -L/usr/lib/gcc/i586-suse-linux/4.1.0 -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -L/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../.. -L/usr/lib/gcc/i586-suse-linux/4.1.0/../../.. -ldl -lgcc_s
> > >> -ldl
> > > Lisandro Dalc�n
> > > Centro Internacional de M�todos Computacionales en Ingenier�a (CIMEC)
> > > Instituto de Desarrollo Tecnol�gico para la Industria Qu�mica (INTEC)
> > > Consejo Nacional de Investigaciones Cient�ficas y T�cnicas (CONICET)
> > > PTLC - G�emes 3450, (3000) Santa Fe, Argentina
> > > Tel/Fax: +54-(0)342-451.1594
