How to configure Compaq visual fortran for PETSc w/o mpi
Ben Tay zonexo at gmail.com
Sun Mar 4 21:49:26 CST 2007
Thanks alot!. It worked.
On 3/5/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Ben,
>   Sounds like you are using your own makefiles with your own list
> of link libraries. Instead of removing the mpich.lib from the linking
> options you must replace it with the mpiuni library (which is a stub
> library for one process) libmpiuni.lib
> Barry
> On Mon, 5 Mar 2007, Ben Tay wrote:
> > Hi,
> > I've managed to use PETSc in Compaq visual fortran using
> > --download-blas-lapack=1 with mpi installed.
> > Now I tried to recompile PETSc with --with-mpi=0. I then tried to remove
> > mpich.lib from the linking options. compiling is ok but during linking,
> I
> > got these error msg:
> > linking...
> > global.obj : error LNK2001: unresolved external symbol _MPI_DUP_FN
> > petsc_sub.obj : error LNK2001: unresolved external symbol _MPI_DUP_FN
> _MPI_NULL_DELETE_FN
> > _MPI_NULL_DELETE_FN
> > global.obj : error LNK2001: unresolved external symbol _MPI_NULL_COPY_FN
> _MPI_NULL_COPY_FN
> > libpetsc.lib(eventLog.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(dmouse.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(petscvu.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(pdisplay.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(fretrieve.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(mpiu.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(mpiuopen.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(dtri.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(sseenabled.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(random.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(axis.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(mtr.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(sysio.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(psplit.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(mpimesg.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(init.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(pbarrier.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(tagm.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(dupl.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(draw.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(options.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(dscatter.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(mprint.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(view.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(verboseinfo.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(plog.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(lg.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(binv.o) : error LNK2001: unresolved external symbol
> _MPIUNI_TMP
> > libpetsc.lib(drawv.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(pinit.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(filev.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(comb.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(pf.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(zstart.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(zutils.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(vpscat.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(pdvec.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(pvec2.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(shvec.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(vecstash.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(dlregisvec.o) : error LNK2001: unresolved external
> symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(dvec2.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(vecio.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(isltog.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(pmap.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(pbvec.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(block.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(index.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(general.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(stride.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(iscomp.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(vinv.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(bvec2.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(vscat.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(iscoloring.o) : error LNK2001: unresolved external
> symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mmsbaij.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(baijov.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(vector.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscvec.lib(rvector.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mpibaij.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(aijtype.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(maij.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(sbaijov.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(bdiag.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mpibdiag.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(sbaij.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mpisbaij.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(partition.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(fdmatrix.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mscatter.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mpiadj.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(fdmpiaij.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mpiov.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mpicsrperm.o) : error LNK2001: unresolved external
> symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mmdense.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(baij.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(matstash.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mpiptap.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mpimatmatmult.o) : error LNK2001: unresolved external
> symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mpiaij.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(dense.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(mpidense.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(aij.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(comm.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(gs.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(matrix.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscmat.lib(axpy.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(mg.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(lu.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(bjacobi.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(pbjacobi.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(eige.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(nn.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(redundant.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(asm.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(itcreate.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(xmon.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(itfunc.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetscksp.lib(precon.o) : error LNK2001: unresolved external symbol
> > _MPIUNI_TMP
> > libpetsc.lib(errstop.o) : error LNK2001: unresolved external symbol
> > _Petsc_MPI_Abort
> > libpetsc.lib(fp.o) : error LNK2001: unresolved external symbol
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > libpetsc.lib(signal.o) : error LNK2001: unresolved external symbol
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > libpetsc.lib(err.o) : error LNK2001: unresolved external symbol
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> symbol
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> symbol
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > libpetscksp.lib(error.o) : error LNK2001: unresolved external symbol
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _Petsc_MPI_Abort
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> symbol
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _MPIUNI_Memcpy
> > _Petsc_MPI_Attr_put
> > _Petsc_MPI_Attr_put
> > _Petsc_MPI_Attr_put
> > _Petsc_MPI_Attr_put
> > _Petsc_MPI_Attr_put
> > _Petsc_MPI_Attr_put
> > libpetsc.lib(vcreatea.o) : error LNK2001: unresolved external symbol
> > _Petsc_MPI_Attr_put
> > _Petsc_MPI_Attr_put
> > _Petsc_MPI_Attr_get
> > _Petsc_MPI_Attr_get
> > _Petsc_MPI_Attr_get
> > _Petsc_MPI_Attr_get
> > _Petsc_MPI_Attr_get
> > _Petsc_MPI_Attr_get
> > _Petsc_MPI_Attr_get
> > _Petsc_MPI_Attr_get
> > _Petsc_MPI_Keyval_create
> > _MPI_INIT at 4
> > _Petsc_MPI_Initialized
> > _Petsc_MPI_Finalize
> > _Petsc_MPI_Finalize
> > libpetsc.lib(adebug.o) : error LNK2001: unresolved external symbol
> > _Petsc_MPI_Finalize
> > _Petsc_MPI_Comm_free
> > _Petsc_MPI_Comm_dup
> > _Petsc_MPI_Comm_dup
> > _Petsc_MPI_Comm_dup
> > _Petsc_MPI_Attr_delete
> > Debug/ns2d_c.exe : fatal error LNK1120: 15 unresolved externals
> > Error executing link.exe.
> > ns2d_c.exe - 221 error(s), 0 warning(s)
> > How can I resolve these errors?
> > Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070305/d5884be5/attachment.htm>
