need help with makefile
P. Aaron Lott palott at ipst.umd.edu
Sat Mar 3 12:32:24 CST 2007
All of the source files are first compiled using
mpif90 -C -g  -qdpc -qautodbl=dbl4 -qinitauto -Wl,-framework -
Wl,vecLib  -c  file.f90
On each file, this creates the appropriate .o and .mod files. Also,
these are compiled in order such that if a file B depends on a module
defined in another file A, then A would be compiled before B
Then the executable is created by running
Wl,vecLib  -o executable  all_object_files.o
I'm attaching the Makefile here
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070303/e24ec155/attachment.obj>
-Aaron
On Mar 3, 2007, at 12:36 PM, Satish Balay wrote:
> What is the command that correctly compiles this file? [from your
> original makefile]
> Satish
> On Sat, 3 Mar 2007, P. Aaron Lott wrote:
>> Hi Satish,
>> I tried the order of the use statements and the include, but it
>> didn't seem to
>> matter. I really don't know much about make files or the linking
>> process with
>> compilers but it seems like the compiler statement
>> /usr/local/mpich-1.2.5.2/bin/mpif90 -c  -I. -g  __unsteady_ex.F -o
>> unsteady_ex.o
>> is trying to make an object file unsteady_ex.o
>> However, unsteady_ex.F depends on many other object files before
>> this can be
>> compiled. During the make process the first file dealt with is
>> unsteady_ex.F,
>> which before using petsc, unsteady_ex.f90 was the last to be
>> compiled. It
>> seems like there should be some way to compile the rest of my
>> program first
>> and then perform this step at the end.
>> I'm not sure if there's some way to rearrange things in the
>> makefile command
>> in order to do this or not. Do you have any ideas?
>> Thanks,
>> -Aaron
>> $(CMD)  : $(SOBJS)
>> 	-${FLINKER} $(FLAGS)  -o $(EXENAME) $(SOBJS)
>> On Mar 3, 2007, at 12:07 PM, Satish Balay wrote:
>>> I can't spot any obvious issues here.. Is it possible that the
>>> #include should go after the 'use statements'? [I don't know enough
>>> about f90 issues here]
>>> Satish
>>>> Hi Satish,
>>>> I'm attaching the file to this e-mail.
>>>> Thanks,
>>>> -Aaron
>> P. Aaron Lott
>> Ph.D. Candidate
>> 4239 Computer and Space Sciences Building
>> University of Maryland
>> College Park, MD 20742-4015
>> http://www.lcv.umd.edu/~palott
>> Office: 301.405.4894
>> Fax:      301.314.0827
P. Aaron Lott
Ph.D. Candidate
Fax:      301.314.0827
