question about total allocated memory
li pan li76pan at yahoo.com
Fri Jun 29 09:09:35 CDT 2007
hi Satish,
thanx for your quick answer. I'm testing my code at a
PC with 32bits 2GB memory and a PC with 64 bits CPU
4GB memory. Both are runing linux system. I heard that
windows system doesn't allow 32 bits CPU allocating
more than 2GB. Is it also true under linux system?
pan
On Fri, 29 Jun 2007, li pan wrote:
> Dear developers,
> I have a question about total allocated memory:
> I run my code under a PC with 2GB memory and got
> following error
> [0]PETSC ERROR: PetscMallocAlign() line 62 in
> src/sys/src/memory/mal.c
> [0]PETSC ERROR: Out of memory. This could be due to
> allocating
> [0]PETSC ERROR: too large an object or bleeding by
not
> properly
> [0]PETSC ERROR: destroying unneeded objects.
> [0]PETSC ERROR: Memory allocated 1234050304 Memory
> used by process 1099702272
> [0]PETSC ERROR: Try running with -malloc_dump or
> -malloc_log for info.
> [0]PETSC ERROR: Memory requested 766976840!
> Then I run it at another PC with 4GB memory. But got
> the same error.
Are these 2 machines in 32bit mode? Most 32bit OSes
don't let a single
processes use more than 2GB of RAM [even if you have
4GB total]
> My question is, what the total memory
> needed. Is that 1234050304 + 766976840 ?
This is an estimate of the memory PETSc is keeping
track of. The app
could be using more memory that the above number [for
eg: if it uses
malloc() not PetscMalloc() etc..].
However normally memory available = RAM + swap [but
due to this 2GB
limit on most 32bit OSes, the swap also doesn't help
here]
Satish
____________________________________________________________________________________
Bored stiff? Loosen up...
Download and play hundreds of games for free on Yahoo! Games.
http://games.yahoo.com/games/front
