compiling PETSC with mvapich
Randall Mackie randy at geosystem.us
Thu Jun 28 14:19:19 CDT 2007
I was able to run it on one processor, using the mpirun_rsh command as follows:
/usr/local/ofed/mpi/intel/mvapich-0.9.7-mlx2.2.0/bin/mpirun_rsh -np 1 hpcluster.local ./conftest
I am now running ./reconfigure.py as instructed.
What I don't understand is why the configure tool is unable to execute binaries created
with C.
Has anyone else used mvapich? (this is for use on infiniband).
Randy
Matthew Knepley wrote:
> On 6/28/07, Randall Mackie <randy at geosystem.us> wrote:
>> I am trying to build PETSC with mvapich, and in the configure step, I
>> am getting the message
>>                      UNABLE to EXECUTE BINARIES for config/configure.py
>> Cannot run executables created with C. It is likely that you will need
>> to configure using --with-batch which allows
>> configuration without interactive sessions.
>> So if I add the --with-batch, and then --with-mpi-shared=1, then I get
>> the following messages:
>>      Since your compute nodes require use of a batch system or mpiexec
>> you must:
>>   1) Submit ./conftest to 1 processor of your batch system or system
>> you are
>>      cross-compiling for; this will generate the file reconfigure.py
>>   2) Run ./reconfigure.py (to complete the configure process).
>> However, using mvapich requires at least 2 processors, so I appear to
>> be stuck.
> Wow, that sounds like a really broken way to operate. However, running
> on two
> processors might be alright, depending on whether the file system is
> shared. Each
> process will open 'reconfigure.py'. If they do not overwrite each
> other, you are fine.
> Are you sure things cnanot be run on 1 proc?
>  Thanks,
>   Matt
>> Any advice?
>> Thanks, Randy
>> Randall Mackie
>> GSY-USA, Inc.
>> PMB# 643
>> 2261 Market St.,
>> San Francisco, CA 94114-1600
>> Tel (415) 469-8649
>> Fax (415) 469-5044
>> California Registered Geophysicist
>> License No. GP 1034
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
Tel (415) 469-8649
Fax (415) 469-5044
License No. GP 1034
