compiling PETSC with mvapich
Randall Mackie randy at geosystem.us
Thu Jun 28 13:50:52 CDT 2007
I am trying to build PETSC with mvapich, and in the configure step, I am getting the message
                     UNABLE to EXECUTE BINARIES for config/configure.py
Cannot run executables created with C. It is likely that you will need to configure using --with-batch which allows
configuration without interactive sessions.
So if I add the --with-batch, and then --with-mpi-shared=1, then I get the following messages:
     Since your compute nodes require use of a batch system or mpiexec you must:
  1) Submit ./conftest to 1 processor of your batch system or system you are
     cross-compiling for; this will generate the file reconfigure.py
  2) Run ./reconfigure.py (to complete the configure process).
However, using mvapich requires at least 2 processors, so I appear to be stuck.
Any advice?
Thanks, Randy
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
San Francisco, CA 94114-1600
Tel (415) 469-8649
Fax (415) 469-5044
California Registered Geophysicist
License No. GP 1034
