How to zero all values on a particular row?
Ben Tay zonexo at gmail.com
Wed Jun 20 03:40:40 CDT 2007
I tried to do it in 2 ways:
A:
1.Do initial sweep:
do j=1,size_y
 do i=1,size_x
  matsetvalue ....
 end do
end do"
2.matssemblybegin/end
3 do a loop using matzerorows to zeros the particular rows
4. do loop and use matsetvalues to insert values into those rows which I had
zeroed previously
5 matssemblybegin/end
6 solve
B:
1. Same as A
2 use matsetvalues to put zeros into those location where I earlier insert
in the 1st full i,j sweep
3. insert correct value using matsetvalues
4. finally matassemblybegin/end - just once.
5. solve
l realised that B is about  3 times faster than A. May I know why this is
so? In A, I only call matssemblybegin/end once more. Is it so serious to the
performance?
Thanks
On 6/11/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mon, 11 Jun 2007, Ben Tay wrote:
> > Thanks Barry,
> > I managed to get it working. I realise that I had to call
> > matssemblybegin/end each time after I zero a particular row. I also
> tried
> > MatSetOption(mat,MAT_KEEP_ZEROED_ROWS) as what you 've suggested.
> > So do I have to callMatSetOption(mat,MAT_KEEP_ZEROED_ROWS) everytime
> just
> > before I need to zero it or just once ie after the 1st
> matassemblybegin/end?
> Call it once when  the matrix is created is fine.
> > Calling matassemblybegin/end each time before matzerorows gives me the
> > impression that it is very inefficient. Is that so?
> Yes, if you do this a bunch of imes
> > In that case, I wonder if it is better for me to :
> > 1 use matsetvalues to put zeros into those location where I earlier
> insert
> > 2. insert correct value using matsetvalues
> > 3. finally matassemblybegin/end - just once.
> You can do this
> > Lastly, is MatZeroRowsIS exactly the same as matzerorows, except that it
> is
> > meant for just 1 row instead of consecutive no. of rows?
> They are the same but one takes an array of integers while the other
> takes an IS. Neither require "consecutive no. of rows" you can zero
> whatever rows you want together.
>   Barry
> > Thanks again
> > > On Sun, 10 Jun 2007, Ben Tay wrote:
> > > > Hi,
> > > > I need to insert values into a matrix and then solve this poisson
> eqn as
> > > > part of my cfd code. For efficiency sake, I  simply use
> > > > "do j=1,size_y
> > > > do i=1,size_x
> > > >  matsetvalue ....
> > > > end do
> > > > end do"
> > > > to insert values into all the cells
> > > > Then for specific cells, I need to enter some other values. In other
> > > words,
> > > > for specific rows of the matrix, I need to zero the whole row and
> insert
> > > new
> > > > values. How can I do that?
> > > > I tried to use MatZeroRows but it says it's not for unassembled
> matrix.
> > > But
> > > > I need to zero the particular row, insert values, and then finally
> > > assembly
> > > > it. Is there a command to do this?
> > >   matzerorows
> > >   matsetvalues, matsetvalues, matsetvalue
> > >   matssemblybegin/end
> > >   For improved efficiency you will want to call
> > >   MatSetOption(mat,MAT_KEEP_ZEROED_ROWS); before the matzerorows()
> > > > Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070620/43ccdb89/attachment.htm>
