MatCreateMPIAIJ Pre-allocation Query
Tim Stitt timothy.stitt at ichec.ie
Sun Jun 17 12:12:17 CDT 2007
Matt,
We are investigating 32-qubit fault-tolerant quantum computation which results
in 2^32 basis states and hence our large Hamiltonian matrix.
I just ran into problems passing 2^32 in as the global row an column argument
so I assumed I need to rebuild PETSc to accept 64-bit integers.
Tim.
On Sunday 17 June 2007 17:54, Matthew Knepley wrote:
> On 6/17/07, Tim Stitt <timothy.stitt at ichec.ie> wrote:
> > Actually my sparse matrix has >2^32 rows and columns hence the global row
> > and column arguments need to be 64-bit.
> Cool. What problem is that big?
>   Matt
> > On Sunday 17 June 2007 17:36, Barry Smith wrote:
> > >   If your problem is so big that you need integers that represent
> > > numbers more than about 2 billion then yes you will need to rebuild
> > > PETSc.
> > >   Barry
> > > You'll be the first PETSc user who solves a problem with more than
> > > 2 billion unknowns.
> > > On Sun, 17 Jun 2007, Tim Stitt wrote:
> > > > Thanks for that Matt...will check it out.
> > > > Incidentally, I need to pass a 64-bit integer to MatCreateMPIAIJ. Do
> > > > I need to rebuild PETSc using a 64-bit integer option switch?
> > > > Tim.
> > > > > > Hi All,
> > > > > > Currently I am using MatCreateMPIAIJ to create a distributed
> > > > > > sparse matrix for use in my parallel sparse eigensolver. If I
> > > > > > understand things correctly, it is important to specify the
> > > > > > correct pre-allocation values for (o_nz,d_nz) or (o_nnz, d_nnz)
> > > > > > respectively to obtain optimum memory usage per node.
> > > > > > For information my matrix redistribution routine generates each
> > > > > > row in the sparse matrix (associated with a given node)
> > > > > > "on-the-fly" and then uses MatSetValues to apply the elements.
> > > > > > My question is: does anyone have a standard code template for the
> > > > > > calculating the d_nz or d_nnz values (along with o_nz or o_nnz
> > > > > > respectively) so that optimum pre-allocation is obtained? Is
> > > > > > there a simple way of determining if a given non-zero value in a
> > > > > > row is part of the diagonal or off-diagonal regions for a given
> > > > > > distributed topology?
> > > > > > Any assistance gratefully received.
> > > > > Basically, you run through the construction algorithm once to
> > > > > calculate d_nnz and o_nnz, and then again to set values. You can
> > > > > see my code for doing it in preallocateOperator() in
> > > > > src/dm/mesh/mesh.c.
> > > > >    Matt
> > > > > > Thanks in advance,
> > > > > > Tim.
> > > > > > Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
> > > > > > HPC Application Consultant - ICHEC (www.ichec.ie)
> > > > > > Dublin Institute for Advanced Studies
> > > > > > 5 Merrion Square - Dublin 2 - Ireland
> > > > > > +353-1-6621333 (tel) / +353-1-6621477 (fax) / +353-874195427
> > > > > > (mobile)
> > +353-1-6621333 (tel) / +353-1-6621477 (fax) / +353-874195427 (mobile)
